I am pleased to announce the re-release of SbK Xfce-Compiz 21.1.2 as 21.1.3. Its a sharp one.
The 21.1.2 release was made the same day as a big update and a move to 21.1.3 by Manjaro. This is an update release for new installs. Those with the 21.1.2 release installed will have the same package base at this point in time.
- The 5.10.63 LTS kernel.
- Compiz 9 with the rotating cube for virtual desktops, faded windows in the background, wobbly windows, and other effects.
- The New FlatRemixSpin-Green icon theme with light and dark versions of the control icons.
- The new KvSpinDarkGreen2 matching Gtk and Kvantum themes in one package.
- The new Usplash-21.1.2 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- Lots of updates since the 21.1 release. The iso’s are up to date as of 9/18/2021.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed.
- A signed iso. For information on signed iso’s visit the checking webpage.
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK Repository after install.
- Timeshift autosnap installed. It takes a snapshot before upgrading so any bad upgrades can be
easily reversed.
Jim
