SbK state of the project
I am disabled and live on a fixed income. The SbK project is a labor of love that keeps me sane. To make the spins I have been using ancient hardware most people would have tossed away a long time ago. The build server has a Core 2 Quad (2007). My main computer has a FX 6300 (2012), both have 6gb of ram. Its a testament to Linux that hardware this old is still usable in some way.
Awhile back I signed up for “Buy Me a Coffee” as a way to upgrade the hardware the project uses. There havent been a lot of donations, but a slow trickle over time. I am thankful for each and every one. Its not enough to buy new modern computers, but I have finally been able to upgrade the hardware a little.
I found that I qualify for discount hardware from PC’s for people. Today I went and got 2 computers. Both have an i5 6500 (2015) with 8gb of ram. I know they are old, but the Skylake processors are a big upgrade.
The next release is Debian 825 on the 1st. I am going to setup the new to me hardware after that. Its just to soon to a release to be messing with things and still get it out. That should leave plenty of time before the 825 Manjaro release on the 15th.
The hardware upgrade is finished. Its a good thing I waited till after a release. I started on the first and finished fixing all software issues a few minutes ago. The Manjaro build partition on the build system had to be completely reinstalled and setup. But to be honest it was an old install with issues from past failed upgrades. The Debian build partition took a day to redo all the broken symlinks and get it working.
The good thing is it shaved about two minutes off of building an iso. When building 5 or more desktops with multiple iso’s that adds up fast.
Everything should be set for the Manjaro 825 series on the 15th.
A discussion in the SbK IceWM 925 release thread on the Manjaro forum got me thinking. A server spin might be a good idea. I have a few days to kill before starting on the Debian 1025 series so I started making the packages for a Manjaro server spin. Its going to be a little different than most of the spins. Since servers are usually headless the theming aspect isnt as important. But I do want to make it easy to install. To do that I am going to use IceWM as an install desktop. The theming is going to be based on the SbK website background. It wont change when new releases come out. It will also only be released every other release cycle like Talking Mate.
The minimal iso will be bare bones. After install users will boot into a command line. The full iso will likely have a IceWM desktop that can be started from the command line on occasion to make it easier to do some things for those not 100% comfortable with the command line. Both versions will have Cockpit installed so the server can be controlled in a browser on another computer if the server is headless.
Its still early in the server spin development, so it may take some time before iso’s are released if all goes to plan.
I am taking a look at the Manjaro lineup of spins again. 6 monthly spins is is a lot and now there are two that are every other month. Since there are now two every other month that makes 7 releases a month.
As in the past I have noticed that the spins that take the most work are downloaded the least. In this case its Mate Compiz.
I do like the eye candy, and I love Mate because I ran it for a few years in the past. Sadly Compiz is in the AUR and it has to be rebuilt a lot whenever an update happens that updates libraries Compiz relies on. Since I dont run it, it may be weeks for those using it without the eye candy.
I am thinking of doing what I do with the Debian Talking Mate release. Giving simple easy to follow instructions to convert it to a standard Mate desktop and a link to download a conky file. I may even create a script that will convert it by clicking on it.
If you have any suggestions or comments on this plan please post them here as I am still not sure what direction I will go.
If I were you, I’d drop the MATE/Compiz spin, Jim. As you say, it’s a lot of work due to compiz being in the AUR. People who’d want it should be willing to build it themselves.
Thanks for the reply. I think you are right, and Mate Compiz is now out of the lineup. Mainly because I cant really tell when Compiz stops working making me rebuild it every update.
I will still have a Mate spin in Talking Mate which with the deletion of one file becomes a standard Mate desktop.
This is probably adding work, and probably quite a bit, so it would be understandable if you did not see it as a viable idea, but have you thought of a Manjaro Media spin similar to Ubuntu Studio.
I used to use Ubuntu Studio, but a few things recently put me off, and I am now using Manjaro with the Software I need for Recording Music.
I havent really thought about it. But it doesnt sound all that hard once a package list is made. What desktop would be best for it, and what applications would it use/need? About the only desktop I dont like building is KDE.
Well Ubuntu Studio now uses KDE, and I think so does The Fedora spin, and I’m using KDE on my Manajro machine. But it doesn’t really matter.
Ubuntu Studio used to use XFCE, but other than GNOME, pretty much any really.
Cinnamon would look good, and I personally would like using it… and I could dig out my scripts that make Cinnamon work a lot like KDE.
Cinnamon would be ok, I have a base buildiso profile for it. I would also be ok with a Mate desktop as long as it dooesnt use AUR packages. What I would need next is a list of the software thats needed. I do not create music, so I am nott really knowlagable about what software is used. Also sound config, is pipewire ok or is there an audio server that is better for a studio desktop.
I primarily use Audacity for my recording, so for me pipewire, or whatever is standard on Manjaro is just fine.
For those who use other DAWs I really can’t say. There may be dependencies on Jack and jackCTL, and there are other tools for wiring devices. Ill have to check that out too.
there is another user on here who is using Manajaro as a Recording Studio base. But I have forgotten who they are.
In the mean time I’ll check out other DAWs and Audio Tools, and get back to you on that.
BTW, even IceWM would work. But the desktop may also influence other’s desire to try a Manjaro Studio OS.
Also as a point of Information Ubuntu Studio offers 3 Media Options.
Audio as in Recording Studio and Electronic Music
Video as in Video Processing
Graphic as in Drawing and Digital Art
Like I said it could be more than you have the resources to do. So might not be viable.
EDIT:
Here’s a rundown of the primary applications on Ubuntu Studio (as discovered via AI search)
Audio Applications
Ardour: Professional digital audio workstation (DAW)
Audacity: Audio recording and editing software
JACK Audio Connection Kit: Professional sound server
Hydrogen: Advanced drum machine/sequencer
Mixxx: DJ mixing software
Video Applications
Kdenlive: Professional video editing software
OpenShot: User-friendly video editor
Blender: 3D animation and video editing
OBS Studio: Screen recording and streaming
Graphics Applications
GIMP: Advanced image manipulation program
Inkscape: Vector graphics editor
Krita: Digital painting and illustration software
Scribus: Desktop publishing software
Photography Applications
Darktable: RAW image processor
RawTherapee: Advanced photo editing software
Hugin: Panorama photo stitching tool
EDIT:
Here’s a non comprehensive list of list of Audio tools
Digital Audio Workstations (DAWs)
Ardour
LMMS
Reaper
Recording and Editing
Audacity
Ocenaudio
Audio Routing and Management
PulseAudio
Specialized Audio Tools
Hydrogen (Drum Machine)
Mixxx (DJ Software)
Synthesizers and Virtual Instruments
Helm
ZynAddSubFX
Yoshimi
Hexter
Padthv1
Qsynth
Audio Programming Environments
Pure Data (Pd)
SuperCollider
ChucK
Sonic Pi
Additional Utilities
Carla
Rakarrack
Guitarix
Analysis and Measurement
Sonic Visualiser
Baudline
RNNoise
Audio Conversion
SoX (Sound eXchange)
FFmpeg
MIDI Tools
VMPK (Virtual MIDI Piano Keyboard)
QMidiRoute
Network and Collaborative Tools
Netjack
Ninjam
I have adapted a buildiso profile from LXQt. It will likely continue to use the LXQt themes when released. A few packages you suggested have issues
AUR packages
Rakarrack
Ninjam
Ocenaudio
Not found
Netjack
Baudline
I would rather not use AUR packages as it adds to getting out the spin by having to build the updated apps and any AUR required packages. If the packages are not in the repos or AUR its hard to include them
As I am speaking the first iso is compressing so this is likely all the packages with issues. I will post a link to the test iso in this thread once I upload it.
Eventually I would like to add a panel on the left that autohides with a selection of apps. Any suggestions on the 5 or 6 apps would be helpful.
I have built a first iso, it can be downloaded here. Its 3.9 gb, which is smaller than the 7.9 gb of Ubuntu Studio.
It says its a minimal iso, but I used to minimal iso package list to cut out a lot of applications that may not be necessary. I think in the future there will only be one iso, a full version.
Let me know what you think and if there are any additions still needed. Its a big iso at 3.9 gb, but as long as we stay in the 4 - 4.5 gb size it should be ok.
I agree. Not using AUR is preferable. it’s better if the user locates flatpak packages.
I’ll grab that and check it out.
Ubuntu Studio also contains packages for Photography and Video editing, so yes it will be big. The person installing usually gets to choose which branch they want.
I did include the video and photography apps you suggested above in this post. If you think something else needs to be added, just let me know. There is still room to add applications.
I had a quick look at it on my Studio computer. But I will have to install it to be sure of everything. My Favourite Audacity works fine, but when I ttried Yoshimi, which I use for my MIDI keyborad I wasn’t able to get it working.
So until I install, I can’t really say what’s missing, or needs to be done.
No hurry, it may just be a config that needs to be added. Also things dont always work in VM’s.
This project is a learning experience. To make the spins better I have learned a lot over its lifespan. To make the Manjaro server better I got the opportunity to learn more about Systemd. The reason is I wanted to have some of the services already enabled like the new Debian server.
The problem is Manjaro, like Arch which its based on, turns all services off by default unless expressly enabled. The way around that to use a service to enable the other services. But that requires at least the new service to be enabled. That is done with systemd-presets and an install script in the package. A crash course on writing Systemd services was the answer to create those new services.
I likely would never have taken as deep a dive into Systemd if this project didnt exist. But it looks like I have automated turning on the services for the server spin. A side benefit is cleaning up the buildiso profiles to remove various work arounds I had scripted because I couldnt get my services enabled on install in the past. While they worked they were not as clean and easy as creating services to do things I wanted during boot like reordering the loading of broadcom kernel modules in a specific order to make the internet work on my old build server when testing an iso.
