I am happy to announce the release of SbK Pantheon 22.0.0.1.
Pantheon uses a lot of the Gnome desktop . Some of the files that Gnome uses had to be changed or removed to create a working Manjaro installer. Because of this it is really not possible to install Gnome as a second desktop in the installed OS.
- The 5.15.76 LTS kernel.
- The New KoraSpin-Aqua2 icon theme with light and dark versions.
- The new SpinThemeDarkAqua11 matching Gtk and Kvantum themes in one package.
- The new Usplash-22.0.0.1 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The iso’s are up to date as of 11/05/2022.
- An optional Firefox theme, SbK Dark Aqua11, that matches the color scheme is available at https://spins.tuxfamily.org/ffthemes.html just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed…
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK http://spins.tuxfamily.org/repo.html after install.
Jim
Cinnamon and Talking Mate remain for this release cycle. I will try and get one out tonight. I cant do it tomorrow because I am an election judge and tomorrow is election day.
