I am happy to announce the release of SbK Openbox 24.2.0.
This is the initial release of SbK Openbox. For this release it uses the Mate 24.2.0 theme package. It took some work to get it functional. But I think its good enough for a first release. Please try it out and let me know if there are any issues you find or improvements you think should be made. There is no system tray, I would like to find a way to add one.
This is a first step in refocusing the SbK project. I want to build low resource desktops and desktops that Manjaro isnt focusing on.
- The 6.6.63 LTS kernel.
- The New KoraSpin-Green8 icon theme with light and dark versions of the control icons. It is part of the KoraSpin-24.2.0 package.
- The new SpinThemeDarkGreen17 matching Gtk and Kvantum themes in one package.
- The new Usplash-24.2.0 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The iso’s are up to date as of 12/11/2024.
- An optional Firefox theme, SbK Dark Green17 that matches the color scheme is available here, Firefox Themes, just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed. AUR packages are not supported by Arch or Manjaro.
- A basic Conky with a color scheme to match the other themes.
Jim
