I am happy to announce the release of SbK Mate-Compiz 24.0.0.
In case you havent noticed since its spring this is a flower themed release series. SbK spins have used flower based themes in the past, some of the earliest series were plant/flower based.
- The 6.6.30 LTS kernel.
- Compiz 9 with the rotating cube for virtual desktops, faded windows in the background, wobbly windows, and other effects.
- The New KoraSpin-Orange7 icon theme with light and dark versions of the control icons. It is part of the KoraSpin-24.0.0 package.
- The new SpinThemeDarkOrange8 matching Gtk and Kvantum themes in one package.
- The new Usplash-24.0.0 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The iso’s are up to date as of 5/17/2024
- An optional Firefox theme, SbK Dark Orange8 that matches the color scheme is available here, Firefox Themes just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed. AUR packages are not supported by Arch or Manjaro.
- A signed iso. For information on checking signed iso’s visit Check ISO Check ISO
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. To get any SbK packages like themes, icons, and other goodies you will have to add the SbK Repository Repository after install.
- A basic Conky with a color scheme to match the other themes.
Jim
