I am happy to announce the release of SbK Mate-Compiz 22.1.1.
This release series was all about new themes. This release is about 6 hours late because of the Lightdm theme. I logged out while testing and found it was ugly. I fixed the issue, created updated packages, and rebuilt the iso. The LXQt and Gnome packages are also fixed, so after an update and reboot they will look good as well.
- The 6.1.26 LTS kernel.
- Compiz 9 with the rotating cube for virtual desktops, faded windows in the background, wobbly windows, and other effects.
- The New KoraSpin-Lime2 icon theme with light and dark versions of the control icons. It is part of the KoraSpin-22.1.1 package.
- The new SpinThemeDarkLime5 matching Gtk and Kvantum themes in one package.
- The new Usplash-22.1.1 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The iso’s are up to date as of 5/9/2023
- An optional Firefox theme, SbK Dark Lime5 that matches the color scheme is available at https://spins.tuxfamily.org/ffthemes.html just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed.
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. To get any SbK packages like themes, icons, and other goodies you will have to add the SbK http://spins.tuxfamily.org/repo.html after install.
- A basic Conky with a color scheme to match the other themes.
Jim
