I am happy to announce the release of SbK Mate-Compiz 21.3.7. It might be the best of the release series.
At present the SpinsbyKilz website is down because of problems with the host. Some of the links may not work, but the download link is working.
This release series was supposed to be 21.3.6 but an update happened during the release cycle with only LXQt released. Lxqt was updated to 21.3.7 by rebuilding the iso’s. The rest of the iso’s will be built as 21.3.7. The theme package names may say 21.3.6 but they are for this release cycle as recreating them just for a name change isnt worth it.
This is the first series that uses the KoraSpin icons. They are forked from the Kora Icon set.
- The 5.15.60 LTS kernel.
- Compiz 9 with the rotating cube for virtual desktops, faded windows in the background, wobbly windows, and other effects.
- The New KoraSpin-Pink6 icon theme with light and dark versions of the control icons. It is part of the KoraSpin-21.3.6 package.
- The new SpinThemeDarkPink6 matching Gtk and Kvantum themes in one package.
- The new Usplash-21.3.6 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The iso’s are up to date as of 8/16/2022.
- An optional Firefox theme, SbK Dark Pink6, that matches the color scheme is available at https://spins.tuxfamily.org/ffthemes.html just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed.
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK http://spins.tuxfamily.org/repo.html after install.
- A basic Conky with a color scheme to match the other themes.
Jim
