I am happy to announce the release of SbK Mate-Compiz 21.2.0.
The Mate desktop had theme work on the Caja file manager to match the rest of the applications. The places sidebar is now the same color as the top of the window. Hover and select highlights now work correctly on the places sidebar.
- The 5.10.79 LTS kernel.
- Compiz 9 with the rotating cube for virtual desktops, faded windows in the background, wobbly windows, and other effects.
- The New FlatRemixSpin-Orange icon theme with light and dark versions of the control icons.
- The new KvSpinDarkOrange2 matching Gtk and Kvantum themes in one package.
- The new Usplash-21.2.0 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- Lots of updates since the 21.1.5 release. The iso’s are up to date as of 11/21/2021.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed.
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK http://spins.tuxfamily.org/repo.html after install.
- A basic Conky with a color scheme to match the other themes.
Jim
