I am happy to announce the release of SbK Mate-Compiz 21.1.5.
- The 5.10.70 LTS kernel.
- Compiz 9 with the rotating cube for virtual desktops, faded windows in the background, wobbly windows, and other effects.
- The New FlatRemixSpin-Brown icon theme with light and dark versions of the control icons.
- The new KvSpinDarkBrown matching Gtk and Kvantum themes in one package.
- The new Usplash-21.1.5 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- Lots of updates since the 21.1.3 release. The iso’s are up to date as of 10/11/2021.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed.
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK Repository after install. http://spins.tuxfamily.org/repo.html
Jim
