SbK Manjaro Talking Mate 426
I am happy to announce the release of SbK Manjaro Talking Mate 426
Talking Mate is one of the few SbK releases to use a panel. It is designed for users with vision issues. I came to the conclusion that making them learn a new dock wasnt a good idea. It also has only one iso, the full version, again to make it easier for its intended users.
If you just want a Mate desktop with this theme, or there is another user of the computer that doesnt need the screen reader Just delete the screen reader file from /home/“username”/config/autostart and reboot.
While Conky isnt installed a configuration that matches the other themes is included. If you install Conky it will use it.
This release includes:
  1. The 6.18.18 LTS linux kernel.
  2. The KoraSpin-Dark-Rose9 theme, with light and dark variants. It is part of the KoraSpin-426 package
  3. The SpinThemeDarkRose9 package with kvantum theme and matching gtk theme in one package.
  4. The grub and login screen use the same wallpaper (part of the Usplash-4266 package) and themes as the desktop.
  5. A lot of package updates since the last SbK Talking Mate release. The release is up to date as of 4/14/2026.
  6. Conky isnt sinstalled by default because the desktop is aimed at visually impaired users, and the screen reader cant read it. But a basic conky config with matching theme is already present, just install and start conky.
It also contain the standard SbK features.
  1. The latest LTS kernel.
  8. Flatpacks and snaps are not installed. The back ends are also not installed but can be installed by the user.
You can download the iso here.
As always comments, suggestions, and requests are always welcome, just post below.
Jim
