I am very happy to announce the release of SbK IceWM 825.
I was able to get the 825 series done a little early. So over the rest of the day I will be posting releases as they finsh uploading.
If you would like a panel instead of a dock download this file. Rename the original at ~/.config/icewm/preferences and replace it with the one you downloaded, then reboot.
If you find you liked the dock more, delete the ~/.config/icewm/preferences and rename the preferences file you renamed back to preferences, and reboot.
- The 6.12.41 LTS kernel.
- The New KoraSpin-icolor icon theme with light and dark versions of the control icons. It is part of the KoraSpin-825 package that includes all colors in the series.
- The new SpinThemeSlate4 matching Gtk and Kvantum themes in one package.
- The new Usplash-825 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The menu icon in the dock is the Xfce mouse icon and it is color matched to the other themes.
- The iso’s are up to date as of 8/13/2025…
- An optional Firefox theme, SbK Dark Slate4, that matches the color scheme is available here, Firefox Themes just click on the image in Firefox to install it.
- The latest LTS kernel.
- The AUR is available in pamac. Please read the AUR section of the SbK https://spinsbykilz.com/best.html page before using the AUR. AUR packages are not supported by Arch or Manjaro.
Jim
