I am very happy to announce the release of SbK IceWM 425.
As detailed in this post the release date for future spins will be about the 15th of the month. This post details the new version number.
If you would like a panel instead of a dock download this file. Rename the original at ~/.config/icewm/preferences and replace it with the one you downloaded, then reboot.
If you find you liked the dock more, delete the ~/.config/icewm/preferences and rename the preferences file you renamed back to preferences, and reboot.
- The 6.12.21 LTS kernel.
- The New KoraSpin-icolor icon theme with light and dark versions of the control icons. It is part of the KoraSpin-425 package that includes all colors in the series.
- The new SpinThemePeach8 matching Gtk and Kvantum themes in one package.
- The new Usplash-425 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The menu icon in the dock is the Xfce mouse icon and it is color matched to the other themes.
- The iso’s are up to date as of 4/13/2025…
- An optional Firefox theme, SbK Dark Peach8, that matches the color scheme is available here, Firefox Themes just click on the image in Firefox to install it.
- The latest LTS kernel.
- The AUR is available in pamac. Please read the AUR section of the SbK Best Practices page before using the AUR. AUR packages are not supported by Arch or Manjaro.
- A basic Conly with matching color theme.
Jim
