SbK Manjaro IceWM 126
I am very happy to announce the release of SbK Manjaro IceWM 126.
If you would like a panel instead of a dock download this file. Rename the original at ~/.config/icewm/preferences and replace it with the one you downloaded, then reboot.
If you find you liked the dock more, delete the ~/.config/icewm/preferences and rename the preferences file you renamed back to preferences, and reboot.
  1. The 6.12.64 LTS kernel.
  2. The New KoraSpin-icolor icon theme with light and dark versions of the control icons. It is part of the KoraSpin-126 package that includes all colors in the series.
  3. The new SpinThemeLavender17 matching Gtk and Kvantum themes in one package.
  4. The new Usplash-126 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
  6. The menu icon in the dock is color matched to the other themes.
  7. The iso’s are up to date as of 1/14/2026..
  1. The latest LTS kernel.
Jim
