I am happy to announce the release of SbK LXQt 24.2.0.
This is one of the best themes I have done in a bit It looks great on LXQt and will likely replace my current theme soon.
- The 6.6.63 LTS kernel.
- LXQt 2.0.
- The New KoraSpin-Lime12 icon theme with light and dark versions of the control icons. They are part of the KoraSpin-24.2.0 package.
- The new SpinThemeDarkLime15 matching Gtk and Kvantum themes in one package was used.
- The new Usplash-24.2.0 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The iso’s are up to date as of 12/1/2024. Lots of updates since the last release.
- An optional Firefox theme, SbK Dark Lime15, that matches the color scheme, is available at Firefox Themes, Just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed. AUR packages are not supported by Arch or Manjaro.
- A basic Conky with a color theme that matches the desktop themes.
Jim
This finishes the 24.2.0 series.
