I am happy to announce the release of SbK LXQt 21.3.7.
This is the first series that uses the KoraSpin icons. They are forked from the Kora Icon set.
An update to 21.3.7 happened today, 8/16/22. Since the release series only had lxqt done I rebuilt the isos to 21.3.7. They were just re-uploaded. The download links now point to the new iso’s. If you already installed 21.3.6 you dont need to reinstall, just update it.
- The 5.15.60 LTS kernel.
- The New KoraSpin-Turquoise4 icon theme with light and dark versions of the control icons. They are part of the KoraSpin-21.3.6 package.
- The new SpinThemeDarkTurquoise4 matching Gtk and Kvantum themes in one package was used.
- The new Usplash-21.3.6 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The iso’s are up to date as of 8/13/2022.
- An optional Firefox theme, SbK Dark Turquoise4, that matches the color scheme, is available at https://spins.tuxfamily.org/ffthemes.html. Just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed…
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK http://spins.tuxfamily.org/repo.html after install.
- A basic Conky with a color theme that matches the desktop themes.
Jim
