I am happy to announce the release of SbK LXQt 21.2.2.
It looks great imho, fitting for the 16th release of SbK LXQt.
- The 5.15.16 LTS kernel.
- The New FlatRemixSpin-Green4 icon theme with light and dark versions of the control icons.
- The new SpinThemeDarkGreen5 matching Gtk and Kvantum themes in one package was used.
- The new Usplash-21.2.2 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The iso’s are up to date as of 1/27/2022.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed…
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK http://spins.tuxfamily.org/repo.html after install.
- A basic Conky with a color theme that matches the desktop themes.
Jim
