I am happy to announce the release of SbK Gnome 24.0.7.
- The 6.6.46 LTS kernel.
- The following Gnome shell extensions are installed and used:
Dash to Dock
Hide top panel
Desktop Icons NG (It is enabled. But end users will have to manually set for launchers to be executable, or trusted. Until then they will have the generic launcher icon and will only open as a text file.) - Minimize and Maximize window controls.
- The Brown3 shell theme based on Rounded Rectangle thats been heavily modified.
- The New KoraSpin-Brown1 icon theme with light and dark versions.
- The new SpinThemeDarkBrown3 matching Gtk and Kvantum themes in one package.
- The new Usplash-24.0.7 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- LightDM instead of GDM with lightlocker screen locking.
- The iso’s are up to date as of 8/22/2024.
- Gnome icon in dock to bring up applications. Its color matches the shell theme.
- A LibAdwaita Brown3 theme. Please visit LibAdwaita for more information and other color options.
- An optional Firefox theme, SbK Dark Brown3, that matches the color scheme is available here Firefox Themes just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed. AUR packages are not supported by Arch or Manjaro.
Jim
I am liking what I see from the Cosmic desktop. Its still in alpha so not ready to make spins of. But at some point it will likely replace the gnome spin.
