I am happy to announce the release of SbK Gnome 23.1.0.
The Hide top bar gnome extension is installed but had not been updated by upstream to work with the current Gnome version. It will get updated at some point and start auto hiding the top bar.
- The 6.6.1 LTS kernel.
- The following Gnome shell extensions are installed and used:
Dash to Dock
Hide Top bar (The top bar is hidden by default. Moving the cursor to the top edge will show it.)
Desktop Icons NG (It is enabled. But end users will have to manually set for launchers to be executable, or trusted. Until then they will have the generic launcher icon and will only open as a text file.) - Minimize and Maximize window controls.
- The Lemon2 shell theme based on Rounded Rectangle thats been heavily modified.
- The New KoraSpin-Lemon icon theme with light and dark versions.
- The new SpinThemeDarkLemon2 matching Gtk and Kvantum themes in one package.
- The new Usplash-23.1.0 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- LightDM instead of GDM with lightlocker screen locking.
- The iso’s are up to date as of 11/24/2023.
- Gnome icon in dock to bring up applications. Its color matches the shell theme.
- A LibAdwaita Lemon2 theme. Please visit https://spinsbykilz.com/libadwaita.html for more information and other color options.
- An optional Firefox theme, SbK Dark Lemon2, that matches the color scheme is available at https://spinsbykilz.com/ffthemes.html just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed…
- A signed iso. For information on checking signed iso’s visit https://spinsbykilz.com/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK http://spinsbykilz.com/repo.html after install.
Jim
Pantheon is next, and its looking sharp.
