I am happy to announce the release of SbK Gnome 23.1.0.1.
With the stable update this morning I rebuilt the iso’s and uploaded the new ones before posting this release announcement.
- The 6.6.6 LTS kernel.
- The following Gnome shell extensions are installed and used:
Dash to Dock
Hide Top bar (The top bar is hiddin by default. Moving the cursor to the top edge will show it.)
Desktop Icons NG (It is enabled. But end users will have to manually set for launchers to be executable, or trusted. Until then they will have the generic launcher icon and will only open as a text file.) - Minimize and Maximize window controls.
- The Green15 shell theme based on Rounded Rectangle thats been heavily modified.
- The New KoraSpin-Green6 icon theme with light and dark versions.
- The new SpinThemeDarkGreen15 matching Gtk and Kvantum themes in one package.
- The new Usplash-23.1.0.1 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- LightDM instead of GDM with lightlocker screen locking.
- The iso’s are up to date as of 12/15/2023.
- Gnome icon in dock to bring up applications. Its color matches the shell theme.
- A LibAdwaita Green15 theme. Please visit LibAdwaita for more information and other color options.
- An optional Firefox theme, SbK Dark Green15, that matches the color scheme is available at Firefox Themes just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed. AUR packages are not supported by Arch or Manjaro.
Jim
If you found the iso’s and downloaded and installed them last night before this announcement, there is no need to download the new ones and reinstall, just update.
