I am happy to announce the release of SbK Gnome 21.3.1.
Here is one for the LibAdwiata theme.
The last release, 22.1.b, was numbered wrong. I misread a post on the Manjaro forum and thought the 22 series was next. It ended up being the 21.3 series.
- The 5.15.49 LTS kernel.
- The following Gnome shell extensions are installed and used:
Dash to Dock
Hide Top bar (The top bar is hiddin by default. Moving the cursor to the top edge will show it.)
Desktop Icons NG (It is enabled. But end users will have to manually set for launchers to be executable, or trusted. Until then they will have the generic launcher icon and will only open as a text file.) - Minimize and Maximize window controls.
- The Pink shell theme based on Rounded Rectangle thats been heavily modified.
- The New FlatRemixSpin-Teal5 icon theme with light and dark versions.
- The new SpinThemeDarkTeal6 matching Gtk and Kvantum themes in one package.
- The new Usplash-21.3.1 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- LightDM instead of GDM with lightlocker screen locking.
- The iso’s are up to date as of 6/27/2022.
- Gnome icon in dock to bring up applications. Its color matches the shell theme.
- A LibAdwaita Teal6 theme. Please visit https://spins.tuxfamily.org/libadwaita.html for more information and other color options.
- An optional Firefox theme, SbK Dark Teal6, that matches the color scheme is available at https://spins.tuxfamily.org/ffthemes.html just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed…
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK http://spins.tuxfamily.org/repo.html after install.
Jim
