I am happy to announce the release of SbK Gnome 21.2.2.
- The 5.15.16 LTS kernel.
- The following Gnome shell extensions are installed and used:
Dash to Dock
Hide Top bar (The top bar is hiddin by default. Moving the cursor to the top edge will show it.)
Desktop Icons NG (It is enabled. But end users wil have to manually set for launchers to be executable, or trusted. Until then they will have the generic launcher icon and will only open as a text file.) - Minimize and Maximixe window controls.
- The Mint shell theme based on Rounded Rectangle thats been heavly modified.
- The New FlatRemixSpin-Lime3 icon theme with light and dark versions.
- The new SpinThemeDarkLime3 matching Gtk and Kvantum themes in one package.
- The new Usplash-21.2.2 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- LightDM instead of GDM with lightlocker screen locking.
- The iso’s are up to date as of 1/31/2022.
- Gnome icon in dock to bring up applications. Its color matches the shell theme.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed…
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK . http://spins.tuxfamily.org/repo.html after install
Xfce-Compiz iso’s are already done and in testing, they are next for release.
Jim
