Hi Hi,
Its been some time since the last SbK release. To kick off the 20.1 series I am pleased to announce SbK Deepin 20.1.
I mentioned a Deepin release awhile back on the old forum. Since Deepin has upgraded since then I thought it was time to make a Deepin spin.
This release includes
- The 5.4.64 linux kernel which is a LTS kernel.
- There is a new grub and matching lightdm theme that matches the desktop wallpaper/theme. Users of other SbK spin installs can use the new themes, search for “sbk 201” without quotes to find the new lightdm and grub theme (dont use the live one).
- This spin uses the Waterfox current browser. I have been using Waterfox current for over a year and like it a lot. It will become the default browser of other gtk based desktop spins. It is based on Firefox with no tracking.
- 5 new wallpapers have been added. One is used for the grub, login, and desktop.
- The dark Deepin theme is enabled by default.
It also contains the standard SbK features.
- A Manjaro stable install that is also AUR compatible.
- Multiarch by default to make running wine games and other 32bit software you may run easier.
A full and minimal iso can be downloaded here…
The package selection of most spins is being looked at and I am looking at making it similar between spins that use the same toolkit. Deepin uses both Gtk and Qt, so it will likely be a lot different than the rest.
Sadly I was unable to sign in on my old account on this site and couldnt remake it with the same name. So this is the new one. Same sites elsewhere.
As always comments, questions, and suggestions are welcome, just post below.
Jim
