I am happy to announce the release of SbK Cinnamon 21.2.0.
Finally the screenshot of the minimal panel iso.
The Cinnamon desktop had theme work on the Nemo file manager to match the rest of the applications. The places sidebar is now the same color as the top of the window. Hover and select highlights now work correctly on the places sidebar.
- The 5.10.79 LTS kernel.
- The New FlatRemixSpin-Turquoise2 icon theme with light and dark versions of the control icons.
- The new KvSpinDarkTurquoise2 matching Gtk and Kvantum themes in one package.
- The new Usplash-21.2.0 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The Cinnamon theme in the panel iso is new. It removes the white line on the panel in the old theme and it will be the default theme design going forward.
- Lots of updates since the 21.1.5 release. The iso’s are up to date as of 11/23/2021.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed…
- A signed iso. For information on checking signed iso’s visit Checking
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK Repository after install.
Jim
