I would like to put my post-install configuration such as selecting the Layout in a bash script, to easily return to my personalised desktop after a clean install (and share my personalisation with others).
To gather the commands, for example to change layouts I do this:
- Open the app (like Layouts)
- Run
dconf watch /
in Terminal - Then in Layouts switch from “Manjaro” layout to “Unity”
ISSUE 1:
dconf watch /
does not work for everything, for example Dash to Panel Settings. How can I capture those commands while making changes in the Dash to Panel Settings window?
ISSUE 2:
For the Layout: The output I have to modify slightly (add the command, change / to dots etc), remove the doubles, this is the result, I save it to a file layout.sh
gsettings set org.gnome.shell.extensions.dash-to-dock dock-position 'LEFT'
gsettings set org.gnome.shell.extensions.dash-to-dock extend-height true
gsettings set org.gnome.shell.extensions.dash-to-dock dock-fixed true
gsettings set org.gnome.shell.extensions.arcmenu menu-layout 'Unity'
gsettings set org.gnome.shell.extensions.arcmenu remove-menu-arrow true
gsettings set org.gnome.shell.extensions.arcmenu arc-menu-placement 'DASH'
gsettings set org.gnome.shell.extensions.arcmenu menu-button-icon 'Distro_Icon'
gsettings set org.gnome.shell.extensions.arcmenu distro-icon 3
gsettings set org.gnome.desktop.wm.preferences button-layout ':minimize,maximize,close'
gsettings set org.gnome.shell.extensions.unite window-buttons-theme 'default'
gsettings set org.gnome.shell disabled-extensions "['appindicatorsupport@rgcjonas.gmail.com']"
gsettings set org.gnome.mutter overlay-key 'Super_L'
gsettings set org.gnome.desktop.wm.keybindings panel-main-menu "['<Alt>F1']"
gsettings set org.gnome.shell.extensions.arcmenu available-placement "[false, false, true]"
gsettings set org.gnome.shell enabled-extensions "['pamac-updates@manjaro.org', 'dash-to-dock@micxgx.gmail.com', 'gnome-ui-tune@itstime.tech', 'x11gestures@joseexposito.github.io', 'unite@hardpixel.eu', 'arcmenu@arcmenu.com', 'vertical-overview@RensAlthuis.github.com', 'ding@rastersoft.com']"
gsettings set org.gnome.desktop.wm.keybindings switch-to-workspace-down "['<Super><Alt>Down', '<Control><Alt>Down', '<Super>s']"
gsettings set org.gnome.desktop.wm.keybindings move-to-workspace-down "['<Super><Alt><Shift>Down', '<Control><Alt><Shift>Down', '<Super><Shift>s']"
gsettings set org.gnome.desktop.wm.keybindings move-to-workspace-up "['<Super><Alt><Shift>Up', '<Control><Alt><Shift>Up', '<Super><Shift>w']"
gsettings set org.gnome.desktop.wm.keybindings switch-to-workspace-up "['<Super><Alt>Up', '<Control><Alt>Up', '<Super>w']"
gsettings set org.gnome.shell disable-user-extensions false
gsettings set org.gnome.shell.extensions.arcmenu pinned-app-list "['Firefox', '', 'firefox.desktop', 'Terminal', '', 'org.gnome.Terminal.desktop', 'ArcMenu Settings', 'ArcMenu_ArcMenuIcon', 'gnome-extensions prefs arcmenu@arcmenu.com']"
gsettings set org.gnome.shell.extensions.arcmenu unity-pinned-app-list "['Home', 'ArcMenu_Home', 'ArcMenu_Home', 'Documents', 'ArcMenu_Documents', 'ArcMenu_Documents', 'Downloads', 'ArcMenu_Downloads', 'ArcMenu_Downloads', 'Software', 'system-software-install-symbolic', 'org.manjaro.pamac.manager.desktop', 'Files', 'system-file-manager', 'org.gnome.Nautilus.desktop', 'Log Out', 'application-exit-symbolic', 'ArcMenu_LogOut', 'Lock', 'changes-prevent-symbolic', 'ArcMenu_Lock', 'Power Off', 'system-shutdown-symbolic', 'ArcMenu_PowerOff']"
This works: I switch back to Manjaro, log off/log on, run the above script. I can log off/on again to be sure.
Issue: Even though I am using Layout “Unity”, the Layout app still has Manjaro selected.
How come? What can I do more to ensure the Layout app shows the actual currently running layout?
