I’ve been going crazy trying to get this monitor to output 5120x1440 @ 240 hz in Linux. It works fine in Windows, but I even tried replacing my 2080 ti with a 6900 xt thinking that the problem was perhaps with the proprietary drivers not supporting Display Stream Compression. In Linux, the best I can do is 5120x1440 @ 120 hz. Anyway, here’s my current xorg.conf:
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Samsung"
    ModelName      "LC49G95T"
    HorizSync       31.5 - 356.5
    VertRefresh     60 - 240.0
    Option         "DPMS"
    Modeline "5120x1440_60.00"  624.50  5120 5496 6048 6976  1440 1443 1453 1493 -hsync +vsync
    Modeline "5120x1440_120.00"  1322.75  5120 5560 6128 7136  1440 1443 1453 1545 -hsync +vsync
    Modeline "5120x1440_240.00"  2885.25  5120 5600 6176 7232  1440 1443 1453 1663 -hsync +vsync
    Modeline "2560x1440_60.00"  312.25  2560 2752 3024 3488  1440 1443 1448 1493 -hsync +vsync
    Modeline "2560x1440_120.00"  661.25  2560 2784 3064 3568  1440 1443 1448 1545 -hsync +vsync
    Modeline "2560x1440_240.00"  1442.50  2560 2800 3088 3616  1440 1443 1448 1663 -hsync +vsync
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "amdgpu"
    BusID       "PCI:11:0:0"
    Option         "ModeValidation" "NoVesaModes,NoXServerModes,AllowNonEdidModes"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    Option         "metamodes" "DisplayPort-0: 5120x1440+0+0 {ForceCompositionPipeline=On}"
    #Option         "metamodes" "DisplayPort-0: 5120x1440+0+0"
    SubSection     "Display"
    Depth       24
        Modes      "5120x1440" "3840x1080"
        Virtual    5120 1440
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
And here’s my last Xorg log (though maybe a pastebin is easier to look at so find it here: gist dot githubusercontent dot com/Lutzy/3a9f524301ec0d2227c9e67deafa8fb5/raw/00efd654aa907894f8be77d3b26ae55b04784f9b/gistfile1.txt )
[   890.740] (--) Log file renamed from "/var/log/Xorg.pid-10590.log" to "/var/log/Xorg.0.log"
[   890.740]
X.Org X Server 1.20.10
[   890.740] Build Operating System: Linux Manjaro Linux
[   890.740] Current Operating System: Linux ryan-manjaro 5.11.6-1-MANJARO #1 SMP PREEMPT Thu Mar 11 19:05:51 UTC 2021 x86_64
[   890.740] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=158fb6fb-ff11-4f77-9fa8-6b1bf8a187b6 rw quiet acpi_enforce_resources=lax
[   890.740] Build Date: 16 December 2020  10:33:32PM
[   890.740]
[   890.740] Current version of pixman: 0.40.0
[   890.741] 	Before reporting problems, check http://wiki.x.org
[   890.741] Markers: (--) probed, (**) from config file, (==) default setting,
[   890.741] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Mar 23 21:12:18 2021
[   890.741] (==) Using config file: "/etc/X11/xorg.conf"
[   890.741] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   890.741] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   890.741] (==) ServerLayout "Layout0"
[   890.741] (**) |-->Screen "Screen0" (0)
[   890.741] (**) |   |-->Monitor "Monitor0"
[   890.741] (**) |   |-->Device "Device0"
[   890.741] (**) |-->Input Device "Keyboard0"
[   890.741] (**) |-->Input Device "Mouse0"
[   890.741] (**) Option "Xinerama" "0"
[   890.741] (==) Automatically adding devices
[   890.741] (==) Automatically enabling devices
[   890.741] (==) Automatically adding GPU devices
[   890.741] (==) Automatically binding GPU devices
[   890.741] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   890.741] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   890.741] 	Entry deleted from font path.
[   890.741] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[   890.741] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[   890.741] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF,
	/usr/share/fonts/OTF
[   890.741] (==) ModulePath set to "/usr/lib/xorg/modules"
[   890.741] (**) Extension "COMPOSITE" is enabled
[   890.741] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[   890.741] (WW) Disabling Keyboard0
[   890.741] (WW) Disabling Mouse0
[   890.741] (II) Module ABI versions:
[   890.741] 	X.Org ANSI C Emulation: 0.4
[   890.741] 	X.Org Video Driver: 24.1
[   890.741] 	X.Org XInput driver : 24.1
[   890.741] 	X.Org Server Extension : 10.0
[   890.741] (++) using VT number 1
[   890.741] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   890.742] (II) xfree86: Adding drm device (/dev/dri/card0)
[   890.744] (--) PCI:*(11@0:0:0) 1002:73bf:148c:2408 rev 192, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfcc00000/1048576, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[   890.744] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   890.744] (II) LoadModule: "glx"
[   890.744] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   890.744] (II) Module glx: vendor="X.Org Foundation"
[   890.744] 	compiled for 1.20.10, module version = 1.0.0
[   890.744] 	ABI class: X.Org Server Extension, version 10.0
[   890.744] (II) LoadModule: "amdgpu"
[   890.744] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[   890.745] (II) Module amdgpu: vendor="X.Org Foundation"
[   890.745] 	compiled for 1.20.8, module version = 19.1.0
[   890.745] 	Module class: X.Org Video Driver
[   890.745] 	ABI class: X.Org Video Driver, version 24.1
[   890.745] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[   890.745] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[   890.746] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[   890.746] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[   890.746] (==) AMDGPU(0): Default visual is TrueColor
[   890.746] (==) AMDGPU(0): RGB weight 888
[   890.746] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[   890.746] (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x73bf)
[   890.746] (II) Loading sub module "fb"
[   890.746] (II) LoadModule: "fb"
[   890.746] (II) Loading /usr/lib/xorg/modules/libfb.so
[   890.746] (II) Module fb: vendor="X.Org Foundation"
[   890.746] 	compiled for 1.20.10, module version = 1.0.0
[   890.746] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   890.746] (II) Loading sub module "dri2"
[   890.746] (II) LoadModule: "dri2"
[   890.746] (II) Module "dri2" already built-in
[   890.764] (II) Loading sub module "glamoregl"
[   890.764] (II) LoadModule: "glamoregl"
[   890.764] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[   890.766] (II) Module glamoregl: vendor="X.Org Foundation"
[   890.766] 	compiled for 1.20.10, module version = 1.0.1
[   890.766] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   890.770] (II) AMDGPU(0): glamor X acceleration enabled on AMD SIENNA_CICHLID (DRM 3.40.0, 5.11.6-1-MANJARO, LLVM 11.1.0)
[   890.770] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[   890.770] (==) AMDGPU(0): TearFree property default: auto
[   890.770] (==) AMDGPU(0): VariableRefresh: disabled
[   890.770] (II) AMDGPU(0): KMS Pageflipping: enabled
[   890.771] (II) AMDGPU(0): Output DisplayPort-0 using monitor section Monitor0
[   890.771] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[   890.771] (II) AMDGPU(0): Output DisplayPort-2 has no monitor section
[   890.771] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[   890.771] (II) AMDGPU(0): EDID for output DisplayPort-0
[   890.772] (II) AMDGPU(0): Manufacturer: SAM  Model: 7053  Serial#: 1129858103
[   890.772] (II) AMDGPU(0): Year: 2020  Week: 51
[   890.772] (II) AMDGPU(0): EDID Version: 1.4
[   890.772] (II) AMDGPU(0): Digital Display Input
[   890.772] (II) AMDGPU(0): 10 bits per channel
[   890.772] (II) AMDGPU(0): Digital interface is DisplayPort
[   890.772] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 119  vert.: 34
[   890.772] (II) AMDGPU(0): Gamma: 2.20
[   890.772] (II) AMDGPU(0): DPMS capabilities: Off
[   890.772] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[   890.772] (II) AMDGPU(0): First detailed timing is preferred mode
[   890.772] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[   890.772] (II) AMDGPU(0): Display is continuous-frequency
[   890.772] (II) AMDGPU(0): redX: 0.694 redY: 0.293   greenX: 0.274 greenY: 0.659
[   890.772] (II) AMDGPU(0): blueX: 0.148 blueY: 0.057   whiteX: 0.313 whiteY: 0.329
[   890.772] (II) AMDGPU(0): Supported established timings:
[   890.772] (II) AMDGPU(0): 720x400@70Hz
[   890.772] (II) AMDGPU(0): 640x480@60Hz
[   890.772] (II) AMDGPU(0): 640x480@67Hz
[   890.772] (II) AMDGPU(0): 640x480@72Hz
[   890.772] (II) AMDGPU(0): 640x480@75Hz
[   890.772] (II) AMDGPU(0): 800x600@56Hz
[   890.772] (II) AMDGPU(0): 800x600@60Hz
[   890.772] (II) AMDGPU(0): 800x600@72Hz
[   890.772] (II) AMDGPU(0): 800x600@75Hz
[   890.772] (II) AMDGPU(0): 832x624@75Hz
[   890.772] (II) AMDGPU(0): 1024x768@60Hz
[   890.772] (II) AMDGPU(0): 1024x768@70Hz
[   890.772] (II) AMDGPU(0): 1024x768@75Hz
[   890.772] (II) AMDGPU(0): 1280x1024@75Hz
[   890.772] (II) AMDGPU(0): 1152x864@75Hz
[   890.772] (II) AMDGPU(0): Manufacturer's mask: 0
[   890.772] (II) AMDGPU(0): Supported standard timings:
[   890.772] (II) AMDGPU(0): #0: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[   890.772] (II) AMDGPU(0): #1: hsize: 1280  vsize 800  refresh: 60  vid: 129
[   890.772] (II) AMDGPU(0): #2: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[   890.772] (II) AMDGPU(0): #3: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[   890.772] (II) AMDGPU(0): #4: hsize: 1600  vsize 900  refresh: 60  vid: 49321
[   890.772] (II) AMDGPU(0): #5: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[   890.772] (II) AMDGPU(0): #6: hsize: 1440  vsize 900  refresh: 60  vid: 149
[   890.772] (II) AMDGPU(0): #7: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[   890.772] (II) AMDGPU(0): Supported detailed timing:
[   890.772] (II) AMDGPU(0): clock: 549.0 MHz   Image Size:  1193 x 336 mm
[   890.772] (II) AMDGPU(0): h_active: 3840  h_sync: 3888  h_sync_end 3920 h_blank_end 4000 h_border: 0
[   890.772] (II) AMDGPU(0): v_active: 1080  v_sync: 1083  v_sync_end 1093 v_blanking: 1144 v_border: 0
[   890.772] (II) AMDGPU(0): Ranges: V min: 60 V max: 240 Hz, H min: 357 H max: 357 kHz, PixClock max 1945 MHz
[   890.772] (II) AMDGPU(0): Monitor name: LC49G95T
[   890.772] (II) AMDGPU(0): Serial No: H4ZNC00966
[   890.772] (II) AMDGPU(0): clock: 241.5 MHz   Image Size:  1193 x 336 mm
[   890.772] (II) AMDGPU(0): h_active: 2560  h_sync: 2608  h_sync_end 2640 h_blank_end 2720 h_border: 0
[   890.772] (II) AMDGPU(0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1481 v_border: 0
[   890.772] (II) AMDGPU(0): clock: 198.0 MHz   Image Size:  1193 x 336 mm
[   890.772] (II) AMDGPU(0): h_active: 2560  h_sync: 2808  h_sync_end 2852 h_blank_end 3000 h_border: 0
[   890.772] (II) AMDGPU(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1100 v_border: 0
[   890.772] (II) AMDGPU(0): clock: 266.5 MHz   Image Size:  1193 x 336 mm
[   890.772] (II) AMDGPU(0): v_active: 1080  v_sync: 1083  v_sync_end 1093 v_blanking: 1111 v_border: 0
[   890.772] (II) AMDGPU(0): clock: 497.8 MHz   Image Size:  1193 x 336 mm
[   890.772] (II) AMDGPU(0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1525 v_border: 0
[   890.772] (II) AMDGPU(0): Number of EDID sections to follow: 2
[   890.772] (II) AMDGPU(0): EDID (in hex):
[   890.772] (II) AMDGPU(0): 	00ffffffffffff004c2d537037445843
[   890.772] (II) AMDGPU(0): 	331e0104b57722783bc725b14b46a826
[   890.772] (II) AMDGPU(0): 	0e5054bfef80714f810081c08180a9c0
[   890.772] (II) AMDGPU(0): 	b3009500d1c074d600a0f03840403020
[   890.772] (II) AMDGPU(0): 	3a00a9504100001a000000fd0c3cf066
[   890.772] (II) AMDGPU(0): 	66c2010a202020202020000000fc004c
[   890.772] (II) AMDGPU(0): 	433439473935540a20202020000000ff
[   890.772] (II) AMDGPU(0): 	0048345a4e4330303936360a2020027c
[   890.772] (II) AMDGPU(0): 	02032df044105a3f5c23090707830100
[   890.772] (II) AMDGPU(0): 	00e305c0006d1a0000020f3cf000048b
[   890.772] (II) AMDGPU(0): 	127317e3060501e5018b849001565e00
[   890.772] (II) AMDGPU(0): 	a0a0a0295030203500a9504100001a58
[   890.772] (II) AMDGPU(0): 	4d00b8a1381440f82c4500a950410000
[   890.772] (II) AMDGPU(0): 	1e1a6800a0f0381f4030203a00a95041
[   890.772] (II) AMDGPU(0): 	00001a6fc200a0a0a0555030203500a9
[   890.772] (II) AMDGPU(0): 	504100001a0000000000000000000084
[   890.772] (II) AMDGPU(0): 	70127900000301649cf50288ff133f01
[   890.772] (II) AMDGPU(0): 	7f801f009f052e00200007002f790108
[   890.772] (II) AMDGPU(0): 	ff139f002f801f009f05530002000900
[   890.772] (II) AMDGPU(0): 	33b70008ff139f002f801f009f052800
[   890.772] (II) AMDGPU(0): 	02000900e36e0108ff094f0007801f00
[   890.772] (II) AMDGPU(0): 	9f052a002000070090c70108ff0e9f00
[   890.772] (II) AMDGPU(0): 	2f801f00370486000200090000000000
[   890.772] (II) AMDGPU(0): 	00000000000000000000000000001d90
[   890.772] (WW) AMDGPU(0): Output DisplayPort-0: Strange aspect ratio (1193/336), consider adding a quirk
[   890.772] (II) AMDGPU(0): Not using mode "5120x1440_240.00" (hsync out of range)
[   890.772] (II) AMDGPU(0): Not using mode "2560x1440_240.00" (hsync out of range)
[   890.772] (II) AMDGPU(0): Not using mode "800x600" (vrefresh out of range)
[   890.772] (II) AMDGPU(0): Printing probed modes for output DisplayPort-0
[   890.772] (II) AMDGPU(0): Modeline "5120x1440"x239.8  1939.49  5120 5248 5280 5440  1440 1473 1481 1487 +hsync -vsync (356.5 kHz UeP)
[   890.772] (II) AMDGPU(0): Modeline "3840x1080"x120.0  549.00  3840 3888 3920 4000  1080 1083 1093 1144 +hsync -vsync (137.2 kHz eP)
[   890.772] (II) AMDGPU(0): Modeline "5120x1440_120.00"x120.0  1322.75  5120 5560 6128 7136  1440 1443 1453 1545 -hsync +vsync (185.4 kHz)
[   890.772] (II) AMDGPU(0): Modeline "5120x1440"x120.0  965.60  5120 5168 5200 5280  1440 1443 1453 1524 +hsync -vsync (182.9 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "5120x1440_60.00"x60.0  624.50  5120 5496 6048 6976  1440 1443 1453 1493 -hsync +vsync (89.5 kHz)
[   890.772] (II) AMDGPU(0): Modeline "5120x1440"x60.0  469.00  5120 5168 5200 5280  1440 1443 1453 1481 +hsync -vsync (88.8 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "3840x1080"x240.0  1166.25  3840 3888 3920 4000  1080 1083 1093 1215 +hsync -vsync (291.6 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "3840x1080"x60.0  266.50  3840 3888 3920 4000  1080 1083 1093 1111 +hsync -vsync (66.6 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "2560x1440"x239.9  939.24  2560 2568 2600 2640  1440 1473 1481 1483 +hsync -vsync (355.8 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "2560x1440_120.00"x120.0  661.25  2560 2784 3064 3568  1440 1443 1448 1545 -hsync +vsync (185.3 kHz)
[   890.772] (II) AMDGPU(0): Modeline "2560x1440"x120.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "2560x1440_60.00"x60.0  312.25  2560 2752 3024 3488  1440 1443 1448 1493 -hsync +vsync (89.5 kHz)
[   890.772] (II) AMDGPU(0): Modeline "2560x1440"x60.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "2560x1080"x120.0  495.00  2560 3108 3152 3300  1080 1084 1089 1250 +hsync +vsync (150.0 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "2560x1080"x119.9  494.50  2560 3108 3152 3300  1080 1084 1089 1250 +hsync +vsync (149.9 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "2560x1080"x60.0  198.00  2560 2808 2852 3000  1080 1084 1089 1100 +hsync +vsync (66.0 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "2560x1080"x59.9  197.80  2560 2808 2852 3000  1080 1084 1089 1100 +hsync +vsync (65.9 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1920x1200"x239.8  1939.49  1920 5248 5280 5440  1200 1473 1481 1487 +hsync -vsync (356.5 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1920x1080"x120.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1920x1080"x119.9  296.70  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (134.9 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 -hsync -vsync (67.5 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1600x1200"x239.8  1939.49  1600 5248 5280 5440  1200 1473 1481 1487 +hsync -vsync (356.5 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1600x900"x60.0  108.00  1600 1624 1704 1800  900 901 904 1000 +hsync +vsync (60.0 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   890.772] (II) AMDGPU(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   890.772] (II) AMDGPU(0): EDID for output DisplayPort-1
[   890.772] (II) AMDGPU(0): EDID for output DisplayPort-2
[   890.772] (II) AMDGPU(0): EDID for output HDMI-A-0
[   890.772] (II) AMDGPU(0): Output DisplayPort-0 connected
[   890.772] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[   890.772] (II) AMDGPU(0): Output DisplayPort-2 disconnected
[   890.772] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[   890.772] (II) AMDGPU(0): Using user preference for initial modes
[   890.772] (II) AMDGPU(0): Output DisplayPort-0 using initial mode 5120x1440 +0+0
[   890.772] (II) AMDGPU(0): mem size init: gart size :3fe4b9000 vram size: s:3fbae5000 visible:e366000
[   890.772] (==) AMDGPU(0): DPI set to (96, 96)
[   890.772] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[   890.772] (II) Loading sub module "ramdac"
[   890.772] (II) LoadModule: "ramdac"
[   890.772] (II) Module "ramdac" already built-in
[   890.772] (II) AMDGPU(0): [DRI2] Setup complete
[   890.772] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[   890.772] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[   890.777] (II) AMDGPU(0): Front buffer pitch: 20480 bytes
[   890.777] (II) AMDGPU(0): SYNC extension fences enabled
[   890.777] (II) AMDGPU(0): Present extension enabled
[   890.777] (==) AMDGPU(0): DRI3 enabled
[   890.777] (==) AMDGPU(0): Backing store enabled
[   890.777] (II) AMDGPU(0): Direct rendering enabled
[   890.780] (II) AMDGPU(0): Use GLAMOR acceleration.
[   890.780] (II) AMDGPU(0): Acceleration enabled
[   890.780] (**) AMDGPU(0): DPMS enabled
[   890.780] (==) AMDGPU(0): Silken mouse disabled
[   890.780] (II) AMDGPU(0): Set up textured video (glamor)
[   890.780] (WW) AMDGPU(0): Option "ModeValidation" is not used
[   890.780] (WW) AMDGPU(0): Option "metamodes" is not used
[   890.780] (II) Initializing extension Generic Event Extension
[   890.781] (II) Initializing extension SHAPE
[   890.781] (II) Initializing extension MIT-SHM
[   890.781] (II) Initializing extension XInputExtension
[   890.781] (II) Initializing extension XTEST
[   890.781] (II) Initializing extension BIG-REQUESTS
[   890.781] (II) Initializing extension SYNC
[   890.781] (II) Initializing extension XKEYBOARD
[   890.781] (II) Initializing extension XC-MISC
[   890.781] (II) Initializing extension SECURITY
[   890.781] (II) Initializing extension XFIXES
[   890.781] (II) Initializing extension RENDER
[   890.781] (II) Initializing extension RANDR
[   890.781] (II) Initializing extension COMPOSITE
[   890.781] (II) Initializing extension DAMAGE
[   890.781] (II) Initializing extension MIT-SCREEN-SAVER
[   890.781] (II) Initializing extension DOUBLE-BUFFER
[   890.781] (II) Initializing extension RECORD
[   890.781] (II) Initializing extension DPMS
[   890.781] (II) Initializing extension Present
[   890.782] (II) Initializing extension DRI3
[   890.782] (II) Initializing extension X-Resource
[   890.782] (II) Initializing extension XVideo
[   890.782] (II) Initializing extension XVideo-MotionCompensation
[   890.782] (II) Initializing extension GLX
[   890.784] (II) AIGLX: Loaded and initialized radeonsi
[   890.784] (II) GLX: Initialized DRI2 GL provider for screen 0
[   890.784] (II) Initializing extension XFree86-VidModeExtension
[   890.784] (II) Initializing extension XFree86-DGA
[   890.784] (II) Initializing extension XFree86-DRI
[   890.784] (II) Initializing extension DRI2
[   890.784] (II) AMDGPU(0): Setting screen physical size to 1354 x 381
[   890.934] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[   890.934] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   890.934] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   890.934] (**) Power Button: Applying InputClass "system-keyboard"
[   890.934] (**) Power Button: Applying InputClass "Keyboard Defaults"
[   890.934] (II) LoadModule: "libinput"
[   890.934] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   890.934] (II) Module libinput: vendor="X.Org Foundation"
[   890.934] 	compiled for 1.20.8, module version = 0.30.0
[   890.934] 	Module class: X.Org XInput Driver
[   890.934] 	ABI class: X.Org XInput driver, version 24.1
[   890.934] (II) Using input driver 'libinput' for 'Power Button'
[   890.934] (**) Power Button: always reports core events
[   890.934] (**) Option "Device" "/dev/input/event1"
[   890.934] (**) Option "_source" "server/udev"
[   890.935] (II) event1  - Power Button: is tagged by udev as: Keyboard
[   890.935] (II) event1  - Power Button: device is a keyboard
[   890.935] (II) event1  - Power Button: device removed
[   890.962] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[   890.962] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   890.962] (**) Option "xkb_model" "pc105"
[   890.962] (**) Option "xkb_layout" "us"
[   890.962] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   890.972] (II) event1  - Power Button: is tagged by udev as: Keyboard
[   890.972] (II) event1  - Power Button: device is a keyboard
[   890.972] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[   890.972] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   890.972] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   890.972] (**) Power Button: Applying InputClass "system-keyboard"
[   890.972] (**) Power Button: Applying InputClass "Keyboard Defaults"
[   890.972] (II) Using input driver 'libinput' for 'Power Button'
[   890.972] (**) Power Button: always reports core events
[   890.972] (**) Option "Device" "/dev/input/event0"
[   890.972] (**) Option "_source" "server/udev"
[   890.972] (II) event0  - Power Button: is tagged by udev as: Keyboard
[   890.972] (II) event0  - Power Button: device is a keyboard
[   890.973] (II) event0  - Power Button: device removed
[   891.015] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[   891.015] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[   891.015] (**) Option "xkb_model" "pc105"
[   891.015] (**) Option "xkb_layout" "us"
[   891.015] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   891.015] (II) event0  - Power Button: is tagged by udev as: Keyboard
[   891.015] (II) event0  - Power Button: device is a keyboard
[   891.016] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event4)
[   891.016] (II) No input driver specified, ignoring this device.
[   891.016] (II) This device may have been added with another device file.
[   891.016] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event5)
[   891.016] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event6)
[   891.017] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event7)
[   891.017] (II) No input driver specified, ignoring this device.
[   891.017] (II) This device may have been added with another device file.
[   891.017] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event8)
[   891.017] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event9)
[   891.017] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse (/dev/input/event17)
[   891.018] (**) Logitech G502 HERO Gaming Mouse: Applying InputClass "evdev pointer catchall"
[   891.018] (**) Logitech G502 HERO Gaming Mouse: Applying InputClass "libinput pointer catchall"
[   891.018] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse'
[   891.018] (**) Logitech G502 HERO Gaming Mouse: always reports core events
[   891.018] (**) Option "Device" "/dev/input/event17"
[   891.018] (**) Option "_source" "server/udev"
[   891.072] (II) event17 - Logitech G502 HERO Gaming Mouse: is tagged by udev as: Mouse
[   891.072] (II) event17 - Logitech G502 HERO Gaming Mouse: device set to 2400 DPI
[   891.072] (II) event17 - Logitech G502 HERO Gaming Mouse: device is a pointer
[   891.072] (II) event17 - Logitech G502 HERO Gaming Mouse: device removed
[   891.375] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-2/5-2:1.0/0003:046D:C08B.0003/input/input17/event17"
[   891.375] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse" (type: MOUSE, id 8)
[   891.375] (**) Option "AccelerationScheme" "none"
[   891.375] (**) Logitech G502 HERO Gaming Mouse: (accel) selected scheme none/0
[   891.375] (**) Logitech G502 HERO Gaming Mouse: (accel) acceleration factor: 2.000
[   891.375] (**) Logitech G502 HERO Gaming Mouse: (accel) acceleration threshold: 4
[   891.432] (II) event17 - Logitech G502 HERO Gaming Mouse: is tagged by udev as: Mouse
[   891.432] (II) event17 - Logitech G502 HERO Gaming Mouse: device set to 2400 DPI
[   891.432] (II) event17 - Logitech G502 HERO Gaming Mouse: device is a pointer
[   891.433] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse (/dev/input/mouse0)
[   891.433] (II) No input driver specified, ignoring this device.
[   891.433] (II) This device may have been added with another device file.
[   891.433] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse Keyboard (/dev/input/event18)
[   891.433] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[   891.433] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[   891.433] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[   891.433] (**) Logitech G502 HERO Gaming Mouse Keyboard: Applying InputClass "Keyboard Defaults"
[   891.433] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse Keyboard'
[   891.433] (**) Logitech G502 HERO Gaming Mouse Keyboard: always reports core events
[   891.433] (**) Option "Device" "/dev/input/event18"
[   891.433] (**) Option "_source" "server/udev"
[   891.434] (II) event18 - Logitech G502 HERO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[   891.434] (II) event18 - Logitech G502 HERO Gaming Mouse Keyboard: device is a keyboard
[   891.434] (II) event18 - Logitech G502 HERO Gaming Mouse Keyboard: device removed
[   891.482] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-2/5-2:1.1/0003:046D:C08B.0004/input/input18/event18"
[   891.482] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse Keyboard" (type: KEYBOARD, id 9)
[   891.482] (**) Option "xkb_model" "pc105"
[   891.482] (**) Option "xkb_layout" "us"
[   891.482] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   891.483] (II) event18 - Logitech G502 HERO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[   891.483] (II) event18 - Logitech G502 HERO Gaming Mouse Keyboard: device is a keyboard
[   891.483] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse Consumer Control (/dev/input/event19)
[   891.483] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[   891.483] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[   891.483] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[   891.483] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "Keyboard Defaults"
[   891.483] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse Consumer Control'
[   891.483] (**) Logitech G502 HERO Gaming Mouse Consumer Control: always reports core events
[   891.483] (**) Option "Device" "/dev/input/event19"
[   891.483] (**) Option "_source" "server/udev"
[   891.484] (II) event19 - Logitech G502 HERO Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[   891.484] (II) event19 - Logitech G502 HERO Gaming Mouse Consumer Control: device is a keyboard
[   891.484] (II) event19 - Logitech G502 HERO Gaming Mouse Consumer Control: device removed
[   891.548] (II) libinput: Logitech G502 HERO Gaming Mouse Consumer Control: needs a virtual subdevice
[   891.548] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-2/5-2:1.1/0003:046D:C08B.0004/input/input19/event19"
[   891.548] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse Consumer Control" (type: MOUSE, id 10)
[   891.548] (**) Option "AccelerationScheme" "none"
[   891.548] (**) Logitech G502 HERO Gaming Mouse Consumer Control: (accel) selected scheme none/0
[   891.548] (**) Logitech G502 HERO Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
[   891.548] (**) Logitech G502 HERO Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
[   891.549] (II) event19 - Logitech G502 HERO Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[   891.549] (II) event19 - Logitech G502 HERO Gaming Mouse Consumer Control: device is a keyboard
[   891.550] (II) config/udev: Adding input device Logitech G502 HERO Gaming Mouse System Control (/dev/input/event20)
[   891.550] (**) Logitech G502 HERO Gaming Mouse System Control: Applying InputClass "evdev keyboard catchall"
[   891.550] (**) Logitech G502 HERO Gaming Mouse System Control: Applying InputClass "libinput keyboard catchall"
[   891.550] (**) Logitech G502 HERO Gaming Mouse System Control: Applying InputClass "system-keyboard"
[   891.550] (**) Logitech G502 HERO Gaming Mouse System Control: Applying InputClass "Keyboard Defaults"
[   891.550] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse System Control'
[   891.550] (**) Logitech G502 HERO Gaming Mouse System Control: always reports core events
[   891.550] (**) Option "Device" "/dev/input/event20"
[   891.550] (**) Option "_source" "server/udev"
[   891.550] (II) event20 - Logitech G502 HERO Gaming Mouse System Control: is tagged by udev as: Keyboard
[   891.550] (II) event20 - Logitech G502 HERO Gaming Mouse System Control: device is a keyboard
[   891.550] (II) event20 - Logitech G502 HERO Gaming Mouse System Control: device removed
[   891.695] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-2/5-2:1.1/0003:046D:C08B.0004/input/input20/event20"
[   891.695] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse System Control" (type: KEYBOARD, id 11)
[   891.695] (**) Option "xkb_model" "pc105"
[   891.695] (**) Option "xkb_layout" "us"
[   891.695] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   891.696] (II) event20 - Logitech G502 HERO Gaming Mouse System Control: is tagged by udev as: Keyboard
[   891.696] (II) event20 - Logitech G502 HERO Gaming Mouse System Control: device is a keyboard
[   891.696] (II) config/udev: Adding input device HyperX Alloy Elite RGB HyperX Alloy Elite RGB (/dev/input/event21)
[   891.696] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB: Applying InputClass "evdev keyboard catchall"
[   891.696] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB: Applying InputClass "libinput keyboard catchall"
[   891.696] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB: Applying InputClass "system-keyboard"
[   891.696] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB: Applying InputClass "Keyboard Defaults"
[   891.696] (II) Using input driver 'libinput' for 'HyperX Alloy Elite RGB HyperX Alloy Elite RGB'
[   891.696] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB: always reports core events
[   891.696] (**) Option "Device" "/dev/input/event21"
[   891.696] (**) Option "_source" "server/udev"
[   891.697] (II) event21 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB: is tagged by udev as: Keyboard
[   891.697] (II) event21 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB: device is a keyboard
[   891.697] (II) event21 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB: device removed
[   891.802] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-4/5-4:1.0/0003:0951:16BE.0005/input/input23/event21"
[   891.802] (II) XINPUT: Adding extended input device "HyperX Alloy Elite RGB HyperX Alloy Elite RGB" (type: KEYBOARD, id 12)
[   891.802] (**) Option "xkb_model" "pc105"
[   891.802] (**) Option "xkb_layout" "us"
[   891.802] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   891.803] (II) event21 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB: is tagged by udev as: Keyboard
[   891.803] (II) event21 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB: device is a keyboard
[   891.803] (II) config/udev: Adding input device HyperX Alloy Elite RGB HyperX Alloy Elite RGB (/dev/input/event22)
[   891.803] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB: Applying InputClass "evdev keyboard catchall"
[   891.803] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB: Applying InputClass "libinput keyboard catchall"
[   891.803] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB: Applying InputClass "system-keyboard"
[   891.803] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB: Applying InputClass "Keyboard Defaults"
[   891.803] (II) Using input driver 'libinput' for 'HyperX Alloy Elite RGB HyperX Alloy Elite RGB'
[   891.803] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB: always reports core events
[   891.803] (**) Option "Device" "/dev/input/event22"
[   891.803] (**) Option "_source" "server/udev"
[   891.804] (II) event22 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB: is tagged by udev as: Keyboard
[   891.804] (II) event22 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB: device is a keyboard
[   891.804] (II) event22 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB: device removed
[   891.882] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-4/5-4:1.1/0003:0951:16BE.0006/input/input24/event22"
[   891.882] (II) XINPUT: Adding extended input device "HyperX Alloy Elite RGB HyperX Alloy Elite RGB" (type: KEYBOARD, id 13)
[   891.882] (**) Option "xkb_model" "pc105"
[   891.882] (**) Option "xkb_layout" "us"
[   891.882] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   891.883] (II) event22 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB: is tagged by udev as: Keyboard
[   891.883] (II) event22 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB: device is a keyboard
[   891.883] (II) config/udev: Adding input device HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse (/dev/input/event23)
[   891.883] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse: Applying InputClass "evdev pointer catchall"
[   891.883] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse: Applying InputClass "libinput pointer catchall"
[   891.883] (II) Using input driver 'libinput' for 'HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse'
[   891.883] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse: always reports core events
[   891.883] (**) Option "Device" "/dev/input/event23"
[   891.883] (**) Option "_source" "server/udev"
[   891.884] (II) event23 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse: is tagged by udev as: Mouse
[   891.884] (II) event23 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse: device is a pointer
[   891.884] (II) event23 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse: device removed
[   892.015] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-4/5-4:1.2/0003:0951:16BE.0007/input/input25/event23"
[   892.015] (II) XINPUT: Adding extended input device "HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse" (type: MOUSE, id 14)
[   892.016] (**) Option "AccelerationScheme" "none"
[   892.016] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse: (accel) selected scheme none/0
[   892.016] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse: (accel) acceleration factor: 2.000
[   892.016] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse: (accel) acceleration threshold: 4
[   892.016] (II) event23 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse: is tagged by udev as: Mouse
[   892.016] (II) event23 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse: device is a pointer
[   892.017] (II) config/udev: Adding input device HyperX Alloy Elite RGB HyperX Alloy Elite RGB Mouse (/dev/input/mouse1)
[   892.017] (II) No input driver specified, ignoring this device.
[   892.017] (II) This device may have been added with another device file.
[   892.017] (II) config/udev: Adding input device HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control (/dev/input/event24)
[   892.017] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control: Applying InputClass "evdev keyboard catchall"
[   892.017] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control: Applying InputClass "libinput keyboard catchall"
[   892.017] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control: Applying InputClass "system-keyboard"
[   892.017] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control: Applying InputClass "Keyboard Defaults"
[   892.017] (II) Using input driver 'libinput' for 'HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control'
[   892.017] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control: always reports core events
[   892.017] (**) Option "Device" "/dev/input/event24"
[   892.017] (**) Option "_source" "server/udev"
[   892.018] (II) event24 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control: is tagged by udev as: Keyboard
[   892.018] (II) event24 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control: device is a keyboard
[   892.018] (II) event24 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control: device removed
[   892.069] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-4/5-4:1.2/0003:0951:16BE.0007/input/input26/event24"
[   892.069] (II) XINPUT: Adding extended input device "HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control" (type: KEYBOARD, id 15)
[   892.069] (**) Option "xkb_model" "pc105"
[   892.069] (**) Option "xkb_layout" "us"
[   892.069] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   892.069] (II) event24 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control: is tagged by udev as: Keyboard
[   892.069] (II) event24 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB System Control: device is a keyboard
[   892.070] (II) config/udev: Adding input device HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control (/dev/input/event25)
[   892.070] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: Applying InputClass "evdev keyboard catchall"
[   892.070] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: Applying InputClass "libinput keyboard catchall"
[   892.070] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: Applying InputClass "system-keyboard"
[   892.070] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: Applying InputClass "Keyboard Defaults"
[   892.070] (II) Using input driver 'libinput' for 'HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control'
[   892.070] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: always reports core events
[   892.070] (**) Option "Device" "/dev/input/event25"
[   892.070] (**) Option "_source" "server/udev"
[   892.071] (II) event25 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: is tagged by udev as: Keyboard
[   892.071] (II) event25 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: device is a keyboard
[   892.071] (II) event25 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: device removed
[   892.095] (II) libinput: HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: needs a virtual subdevice
[   892.095] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-4/5-4:1.2/0003:0951:16BE.0007/input/input27/event25"
[   892.095] (II) XINPUT: Adding extended input device "HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control" (type: MOUSE, id 16)
[   892.095] (**) Option "AccelerationScheme" "none"
[   892.095] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: (accel) selected scheme none/0
[   892.095] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: (accel) acceleration factor: 2.000
[   892.095] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: (accel) acceleration threshold: 4
[   892.096] (II) event25 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: is tagged by udev as: Keyboard
[   892.096] (II) event25 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: device is a keyboard
[   892.096] (II) config/udev: Adding input device HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard (/dev/input/event26)
[   892.096] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard: Applying InputClass "evdev keyboard catchall"
[   892.096] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard: Applying InputClass "libinput keyboard catchall"
[   892.096] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard: Applying InputClass "system-keyboard"
[   892.096] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard: Applying InputClass "Keyboard Defaults"
[   892.096] (II) Using input driver 'libinput' for 'HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard'
[   892.096] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard: always reports core events
[   892.096] (**) Option "Device" "/dev/input/event26"
[   892.096] (**) Option "_source" "server/udev"
[   892.097] (II) event26 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard: is tagged by udev as: Keyboard
[   892.097] (II) event26 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard: device is a keyboard
[   892.097] (II) event26 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard: device removed
[   892.122] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-4/5-4:1.2/0003:0951:16BE.0007/input/input29/event26"
[   892.122] (II) XINPUT: Adding extended input device "HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard" (type: KEYBOARD, id 17)
[   892.122] (**) Option "xkb_model" "pc105"
[   892.122] (**) Option "xkb_layout" "us"
[   892.122] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   892.123] (II) event26 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard: is tagged by udev as: Keyboard
[   892.123] (II) event26 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB Keyboard: device is a keyboard
[   892.123] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event10)
[   892.123] (II) No input driver specified, ignoring this device.
[   892.123] (II) This device may have been added with another device file.
[   892.123] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event11)
[   892.123] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event12)
[   892.124] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event13)
[   892.124] (II) No input driver specified, ignoring this device.
[   892.124] (II) This device may have been added with another device file.
[   892.124] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event14)
[   892.124] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event15)
[   892.124] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event16)
[   892.124] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event3)
[   892.124] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[   892.124] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[   892.124] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[   892.124] (**) Eee PC WMI hotkeys: Applying InputClass "Keyboard Defaults"
[   892.124] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[   892.124] (**) Eee PC WMI hotkeys: always reports core events
[   892.124] (**) Option "Device" "/dev/input/event3"
[   892.124] (**) Option "_source" "server/udev"
[   892.125] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[   892.125] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[   892.125] (II) event3  - Eee PC WMI hotkeys: device removed
[   892.175] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input3/event3"
[   892.175] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 18)
[   892.175] (**) Option "xkb_model" "pc105"
[   892.175] (**) Option "xkb_layout" "us"
[   892.175] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   892.176] (II) event3  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[   892.176] (II) event3  - Eee PC WMI hotkeys: device is a keyboard
[   892.176] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[   892.176] (II) No input driver specified, ignoring this device.
[   892.176] (II) This device may have been added with another device file.
[   892.178] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[   892.178] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[   892.178] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[   892.178] (**) Logitech G502 HERO Gaming Mouse Consumer Control: Applying InputClass "Keyboard Defaults"
[   892.178] (II) Using input driver 'libinput' for 'Logitech G502 HERO Gaming Mouse Consumer Control'
[   892.178] (**) Logitech G502 HERO Gaming Mouse Consumer Control: always reports core events
[   892.178] (**) Option "Device" "/dev/input/event19"
[   892.178] (**) Option "_source" "_driver/libinput"
[   892.178] (II) libinput: Logitech G502 HERO Gaming Mouse Consumer Control: is a virtual subdevice
[   892.178] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-2/5-2:1.1/0003:046D:C08B.0004/input/input19/event19"
[   892.178] (II) XINPUT: Adding extended input device "Logitech G502 HERO Gaming Mouse Consumer Control" (type: KEYBOARD, id 19)
[   892.178] (**) Option "xkb_model" "pc105"
[   892.178] (**) Option "xkb_layout" "us"
[   892.178] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[   892.178] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: Applying InputClass "evdev keyboard catchall"
[   892.178] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: Applying InputClass "libinput keyboard catchall"
[   892.178] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: Applying InputClass "system-keyboard"
[   892.178] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: Applying InputClass "Keyboard Defaults"
[   892.178] (II) Using input driver 'libinput' for 'HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control'
[   892.178] (**) HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: always reports core events
[   892.178] (**) Option "Device" "/dev/input/event25"
[   892.178] (II) libinput: HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control: is a virtual subdevice
[   892.178] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb5/5-4/5-4:1.2/0003:0951:16BE.0007/input/input27/event25"
[   892.178] (II) XINPUT: Adding extended input device "HyperX Alloy Elite RGB HyperX Alloy Elite RGB Consumer Control" (type: KEYBOARD, id 20)
[   895.738] (II) AMDGPU(0): EDID vendor "SAM", prod id 28755
[   895.738] (II) AMDGPU(0): Using hsync ranges from config file
[   895.738] (II) AMDGPU(0): Using vrefresh ranges from config file
[   895.738] (II) AMDGPU(0): Printing DDC gathered Modelines:
[   895.738] (II) AMDGPU(0): Modeline "3840x1080"x0.0  549.00  3840 3888 3920 4000  1080 1083 1093 1144 +hsync -vsync (137.2 kHz eP)
[   895.738] (II) AMDGPU(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "2560x1080"x0.0  198.00  2560 2808 2852 3000  1080 1084 1089 1100 +hsync +vsync (66.0 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "3840x1080"x0.0  266.50  3840 3888 3920 4000  1080 1083 1093 1111 +hsync -vsync (66.6 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "2560x1440"x0.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1920x1080"x0.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1280x800"x0.0   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   895.738] (II) AMDGPU(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   895.738] (WW) AMDGPU(0): Output DisplayPort-0: Strange aspect ratio (1193/336), consider adding a quirk
[   895.929] (II) AMDGPU(0): EDID vendor "SAM", prod id 28755
[   895.929] (II) AMDGPU(0): Using hsync ranges from config file
[   895.929] (II) AMDGPU(0): Using vrefresh ranges from config file
[   895.929] (II) AMDGPU(0): Printing DDC gathered Modelines:
[   895.929] (II) AMDGPU(0): Modeline "3840x1080"x0.0  549.00  3840 3888 3920 4000  1080 1083 1093 1144 +hsync -vsync (137.2 kHz eP)
[   895.929] (II) AMDGPU(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "2560x1080"x0.0  198.00  2560 2808 2852 3000  1080 1084 1089 1100 +hsync +vsync (66.0 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "3840x1080"x0.0  266.50  3840 3888 3920 4000  1080 1083 1093 1111 +hsync -vsync (66.6 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "2560x1440"x0.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1920x1080"x0.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1280x800"x0.0   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   895.929] (II) AMDGPU(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   895.929] (WW) AMDGPU(0): Output DisplayPort-0: Strange aspect ratio (1193/336), consider adding a quirk
[   896.002] (II) AMDGPU(0): EDID vendor "SAM", prod id 28755
[   896.002] (II) AMDGPU(0): Using hsync ranges from config file
[   896.002] (II) AMDGPU(0): Using vrefresh ranges from config file
[   896.002] (II) AMDGPU(0): Printing DDC gathered Modelines:
[   896.002] (II) AMDGPU(0): Modeline "3840x1080"x0.0  549.00  3840 3888 3920 4000  1080 1083 1093 1144 +hsync -vsync (137.2 kHz eP)
[   896.002] (II) AMDGPU(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "2560x1080"x0.0  198.00  2560 2808 2852 3000  1080 1084 1089 1100 +hsync +vsync (66.0 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "3840x1080"x0.0  266.50  3840 3888 3920 4000  1080 1083 1093 1111 +hsync -vsync (66.6 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "2560x1440"x0.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1920x1080"x0.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1280x800"x0.0   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   896.002] (II) AMDGPU(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   896.002] (WW) AMDGPU(0): Output DisplayPort-0: Strange aspect ratio (1193/336), consider adding a quirk
[   897.964] (II) AMDGPU(0): EDID vendor "SAM", prod id 28755
[   897.964] (II) AMDGPU(0): Using hsync ranges from config file
[   897.964] (II) AMDGPU(0): Using vrefresh ranges from config file
[   897.964] (II) AMDGPU(0): Printing DDC gathered Modelines:
[   897.964] (II) AMDGPU(0): Modeline "3840x1080"x0.0  549.00  3840 3888 3920 4000  1080 1083 1093 1144 +hsync -vsync (137.2 kHz eP)
[   897.964] (II) AMDGPU(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "2560x1080"x0.0  198.00  2560 2808 2852 3000  1080 1084 1089 1100 +hsync +vsync (66.0 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "3840x1080"x0.0  266.50  3840 3888 3920 4000  1080 1083 1093 1111 +hsync -vsync (66.6 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "2560x1440"x0.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1920x1080"x0.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1280x800"x0.0   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   897.964] (II) AMDGPU(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   897.964] (WW) AMDGPU(0): Output DisplayPort-0: Strange aspect ratio (1193/336), consider adding a quirk
[   900.027] (II) AMDGPU(0): EDID vendor "SAM", prod id 28755
[   900.027] (II) AMDGPU(0): Using hsync ranges from config file
[   900.027] (II) AMDGPU(0): Using vrefresh ranges from config file
[   900.027] (II) AMDGPU(0): Printing DDC gathered Modelines:
[   900.027] (II) AMDGPU(0): Modeline "3840x1080"x0.0  549.00  3840 3888 3920 4000  1080 1083 1093 1144 +hsync -vsync (137.2 kHz eP)
[   900.027] (II) AMDGPU(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "2560x1080"x0.0  198.00  2560 2808 2852 3000  1080 1084 1089 1100 +hsync +vsync (66.0 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "3840x1080"x0.0  266.50  3840 3888 3920 4000  1080 1083 1093 1111 +hsync -vsync (66.6 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "2560x1440"x0.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1920x1080"x0.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1280x800"x0.0   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   900.027] (II) AMDGPU(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   900.027] (WW) AMDGPU(0): Output DisplayPort-0: Strange aspect ratio (1193/336), consider adding a quirk
[   915.031] (II) AMDGPU(0): EDID vendor "SAM", prod id 28755
[   915.031] (II) AMDGPU(0): Using hsync ranges from config file
[   915.031] (II) AMDGPU(0): Using vrefresh ranges from config file
[   915.031] (II) AMDGPU(0): Printing DDC gathered Modelines:
[   915.031] (II) AMDGPU(0): Modeline "3840x1080"x0.0  549.00  3840 3888 3920 4000  1080 1083 1093 1144 +hsync -vsync (137.2 kHz eP)
[   915.031] (II) AMDGPU(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "2560x1080"x0.0  198.00  2560 2808 2852 3000  1080 1084 1089 1100 +hsync +vsync (66.0 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "3840x1080"x0.0  266.50  3840 3888 3920 4000  1080 1083 1093 1111 +hsync -vsync (66.6 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "2560x1440"x0.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1920x1080"x0.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1280x800"x0.0   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   915.031] (II) AMDGPU(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   915.031] (WW) AMDGPU(0): Output DisplayPort-0: Strange aspect ratio (1193/336), consider adding a quirk
[   957.267] (II) AMDGPU(0): EDID vendor "SAM", prod id 28755
[   957.267] (II) AMDGPU(0): Using hsync ranges from config file
[   957.267] (II) AMDGPU(0): Using vrefresh ranges from config file
[   957.267] (II) AMDGPU(0): Printing DDC gathered Modelines:
[   957.267] (II) AMDGPU(0): Modeline "3840x1080"x0.0  549.00  3840 3888 3920 4000  1080 1083 1093 1144 +hsync -vsync (137.2 kHz eP)
[   957.268] (II) AMDGPU(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "2560x1080"x0.0  198.00  2560 2808 2852 3000  1080 1084 1089 1100 +hsync +vsync (66.0 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "3840x1080"x0.0  266.50  3840 3888 3920 4000  1080 1083 1093 1111 +hsync -vsync (66.6 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "2560x1440"x0.0  497.75  2560 2608 2640 2720  1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1920x1080"x0.0  297.00  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1280x800"x0.0   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[   957.268] (II) AMDGPU(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[   957.268] (WW) AMDGPU(0): Output DisplayPort-0: Strange aspect ratio (1193/336), consider adding a quirk
[  1086.900] (EE) event22 - HyperX Alloy Elite RGB HyperX Alloy Elite RGB: client bug: event processing lagging behind by 14ms, your system is too slow
Any help would be very appreciated. As someone who has been using Linux exclusively for years, this is getting close to making me throw my hands up in there and give up. Thanks in advance!
