Greetings,
I’ve freshly installed Manjaro (plasma) on my old Samsung Chromebook Pro (Caroline / Intel m3-6y30) and everything works great except the integrated speakers. Manjaro can’t detect them at all, but when I connect my bluetooth headset, the sound comes out alright. 3.5mm jack doesn’t work though. I’ve tried the solutions suggested on ArchWiki (even though they’re for different boards/chipsets) but haven’t had any luck. I’ve tried looking through various forums as well to no avail, so I’d greatly appreciate any help you could offer.
Attaching my inxi -Fazy output:
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=99b8a3a3-6529-4938-8c82-caff5916bc35 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Google product: Caroline v: 1.0
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Google model: Caroline v: 1.0 serial: <superuser required>
BIOS: coreboot v: N/A date: 07/20/2018
ID-1: BAT0 charge: 5.9 Wh (16.6%) condition: 35.5/39.1 Wh (91.0%) volts: 7.1
min: 7.6 model: SDI 4352D51 type: Li-ion serial: <filter>
status: discharging cycles: 142
Info: model: Intel Core m3-6Y30 bits: 64 type: MT MCP arch: Skylake
level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 600 min/max: 400/2200 scaling: driver: intel_pstate
governor: powersave cores: 1: 600 2: 600 3: 600 4: 600 bogomips: 7203
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 515 driver: i915 v: kernel arch: Gen-9
process: Intel 14n built: 2015-16 ports: active: eDP-1 empty: DP-1, DP-2,
HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:191e class-ID: 0300
Device-2: Silicon Motion 720p HD Camera type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 2232:1082 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2400x1600 s-dpi: 96 s-size: 635x423mm (25.00x16.65")
s-diag: 763mm (30.04")
Monitor-1: eDP-1 model: Sharp LQ123P1JX31 built: 2016 res: 2400x1600
hz: 60 dpi: 235 gamma: 1.2 size: 259x173mm (10.2x6.81") diag: 311mm (12.3")
ratio: 3:2 modes: 2400x1600
OpenGL: renderer: Mesa Intel HD Graphics 515 (SKL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_soc_skl v: kernel
alternate: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0401
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.58 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-3:2 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 29.12 GiB used: 11.79 GiB (40.5%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: HP model: DF4032 size: 29.12 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
rev: 0x8 scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-1: / raw-size: 29.12 GiB size: 28.49 GiB (97.85%) used: 11.79 GiB (41.4%)
fs: ext4 dev: /dev/mmcblk0p1 maj-min: 179:1
ID-1: swap-1 type: file size: 512 MiB used: 329.2 MiB (64.3%) priority: -2
file: /swapfile
System Temperatures: cpu: 50.0 C pch: 39.5 C mobo: N/A
Processes: 193 Uptime: 43m wakeups: 33 Memory: 3.73 GiB used: 3.31 GiB
(88.8%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1143 libs: 334
tools: pamac Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.22
and for convenience inxi -Aa
thank you in advance
