Hi!
Same problem here. ![]()
Your post has been moved to a dedicated topic, giving you the opportunity to describe your issue in detail, and provide any information that will help others to help you.
You can start with providing system information as described (below); and please, do not simply post the inxi output without any context. Members are expected to fully describe their issue in a manner that is both coherent and actionable.
Manjaro forum has guidelines for presentation - particularly, presentation of code and command output. Links are also provided (below) to resources that should be helpful.
Please note that adding your own Support issue to another member’s topic is generally discouraged; as are so-called “Me too” posts, which add nothing useful to the flow.
This topic has been temporarily unlisted (hidden from view) until you have finished editing your first as needed.
Moderation staff will relist the topic when it’s deemed satisfactory, at which time, I’m sure someone will help when they are able.
Please change the topic title so that it better reflects the issue at hand. ![]()
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly; ![]()
inxi --filter --verbosity=8
or the short form:
inxi -zv8
