postcd
1
Manjaro stable with 5.15.12-1-MANJARO
CTDB - clustered TDB database
-c to check
$ sudo visudo -c
/etc/sudoers: parsed OK
/etc/sudoers.d/10-installer: parsed OK
/etc/sudoers.d/ctdb: bad permissions, should be mode 0440
/etc/sudoers.d/zfs: parsed OK
$ stat /etc/sudoers.d/ctdb
File: /etc/sudoers.d/ctdb
Size: 100 Blocks: 8 IO Block: 4096 regular file
Device: 254,0 Inode: 1313102 Links: 1
Access: (0600/-rw-------) Uid: ( 0/ root) Gid: ( 0/ root)
Modify: 2021-12-12 16:59:40.000000000 +0100
is this something that should be fixed in Manjaro? If so where to report this so it can be fixed for everyone?
This is the only file default present on Manjaro installations.
This is the reason why one should only use visudo to modify such files.
There is no ctdb package so you are using a third party - poorly written - PKGBUILD.
Consult the author.
I stand corrected
xabbu
3
This file is part of the samba
package.
The Arch PKGBUILD explicitly sets the permissions like this.
svntogit-packages/PKGBUILD at packages/samba · archlinux/svntogit-packages · GitHub
Upstream Arch packages FS#69114 : [samba] 4.13.3-2 visudo reports incorrect permissions (archlinux.org) issue.
patch from issue attachment.
200c200
< chmod 600 ${pkgdir}/etc/sudoers.d/ctdb
> chmod 400 ${pkgdir}/etc/sudoers.d/ctdb
system
Closed
5
