Team,
For X-Plane, I use a radio panel, however, this Saitek Radio Panel is being detected as a mouse, which means it is making clicks. I tried setting up a rule in #/usrshare/X11/xorg.conf.d/50-saitekpanels.conf:
Section "InputClass"
Identifier "Saitek Radio"
MatchProduct "Saitek Pro Flight Radio Panel"
Option "ButtonMapping" "0 0 0 0 0 0 0 0"
EndSection
Using the above causes the OS to not boot.
Option "Ignore" "true"
EndSection
Allows the system to boot, but did not stop the device from acting like a mouse.
Since these have not worked. I checked MHWD and got this as the output from MHWD:
22: USB 00.0: 0000 Unclassified device
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-6/1-6.4/1-6.4:1.0
SysFS BusID: 1-6.4:1.0
Hardware Class: unknown
Model: "Saitek PLC Pro Flight Radio Panel"
Hotplug: USB
Vendor: usb 0x06a3 "Saitek PLC"
Device: usb 0x0d05 "Pro Flight Radio Panel"
Revision: "1.07"
Driver: "usbhid"
Driver Modules: "usbhid"
Device File: /dev/input/event27
Device Files: /dev/input/event27, /dev/input/by-id/usb-Logitech_Logitech_Flight_Radio_Panel-event-mouse, /dev/input/by-path/pci-0000:02:00.0-usb-0:6.4:1.0-event-mouse
Device Number: char 13:91
Speed: 12 Mbps
Module Alias: "usb:v06A3p0D05d0107dc00dsc00dp00ic03isc00ip00in00"
Driver Info #0:
Driver Status: usbhid is active
Driver Activation Cmd: "modprobe usbhid"
Attached to: #11 (Hub)
Is there a proper way to change what MHWD is seeing? I tried removing the mouse events and they auto regenerate.
