A few months back - looking to pull away from Windows I struggled to overcome OEM bios/EFI resistance but finally managed to install Manjaro.
All working fine until I tried to move the ‘Home’ directory and ended up with black screen! Accepted loss of data and re-installed Manjaro, from USB, still no good wouldn’t run, not stable.
Installed second Manjaro in a separate partition (fdisk sda5). Boot menu auto adjusted to give an additional Manjaro option, timer vanished. Old original installation (fdisk sda6) also started working!
Now no operating problems , both Manjaro installations boot and work no issues, sequence first calls boot0001 which for both, EfiBootManager shows file as EFI\Manjaro\grubx64.efi. Windows (fdisk sda3) also boots with no issues Windows, boot manager boot0000, file EFI\Microsoft\Boot\bootmgfw.efi.
Question is how best to remove the extra unwanted Manjaro installation, and tidy up the boot menu without digging myself into another hole. From what I gather three possibilities (none of which I’ve used before) *
- delete partition,
- uninstall Manjaro (think I’ve seem how to do that somewhere)
- rewind (think Ive seen that somewhere but not sure now whether that was just EfiBootManager)
Hope that all makes sense, appreciate any help.
inxi --full --admin --filter --width ✔
Kernel: 6.1.53-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=5511fda8-d2a2-4346-b1e7-0b311a071b6e rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Laptop System: Dell product: Vostro 3559 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 047TR1 v: A00 serial: <superuser required> UEFI: Dell
v: 1.2.0 date: 06/27/2016
ID-1: BAT0 charge: 8.5 Wh (25.5%) condition: 33.3/41.4 Wh (80.4%) volts: 14.7
min: 14.8 model: SMP DELL VN3N047 type: Li-ion serial: <filter>
status: discharging
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 445 high: 497 min/max: 400/2800 scaling:
driver: intel_pstate governor: powersave cores: 1: 497 2: 486 3: 400 4: 400
bogomips: 19204
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Suyin Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 064e:9209
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.7-1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 15.15 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.264 layers: N/A device: 0 type: integrated-gpu
name: Intel HD Graphics 520 (SKL GT2) driver: mesa intel v: 23.1.7-1
device-ID: 8086:1916 surfaces: xcb,xlib,wayland
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_skl
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Device-2: Logitech H600 [Wireless Headset]
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 046d:0a29 class-ID: 0300
serial: <filter>
API: ALSA v: k6.1.53-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:08b3 class-ID: 0280
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 8087:07dc
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 8 state: up address: see --recommends
Local Storage: total: 465.76 GiB used: 10.98 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPLX-00ZNTT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 10.98 GiB (23.0%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 39.0 C pch: 39.0 C mobo: 35.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 0
Processes: 175 Uptime: 1d 19h 26m wakeups: 18239 Memory: total: 16 GiB
available: 15.52 GiB used: 2.89 GiB (18.6%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1185 libs: 368 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
