Hello,
Would like to know a safe way to remove everything related to snap packs and snapd.
I do not have any snaps installed on my system.
Pamac GUI has always had snap support disabled.
I red the forum and the Arch Wiki.
I get this:
sudo pacman -Rns snapd
[sudo] password for jesuslinux:
checking dependencies...
:: removing snapd breaks dependency 'snapd' required by libpamac-snap-plugin
:: removing snapd breaks dependency 'snapd' required by manjaro-tools-iso-git
Did not use:
pamac remove --no-save snapd
Because I’m afraid of breaking pamac GUI of something.
I red this thread:
Just want to make sure how to do it and remove everything snap related.
Thanks.
Molski
2
$ sudo pacman -Rns snapd
$ sudo pacman -Rns snapd libpamac-snap-plugin
:: pacui optionally requires snapd: Needed for for Snap update support
:: pamac-gtk optionally requires libpamac-snap-plugin: for Snap support
Packages (2) libpamac-snap-plugin-11.7.3-7 snapd-2.72-1
Total Removed Size: 69.10 MiB
:: Do you want to remove these packages? [Y/n]
I’d feel fine doing that. You just have to add manjaro-tools-iso-git.
Can you clarify that please?
Molski
5
In other words.
sudo pacman -Rns snapd libpamac-snap-plugin manjaro-tools-iso-git
I just showed you what I got by I adding the dependency blocking it’s removal on my system.
(I don’t have manjaro-tools-iso-git installed.)
And I'm tired.
Well, I’ve never uninstalled the snap feature – I’ve never activated it, either – but, let’s see if this logic holds true:
Snapd is probably being used by pamac:
- Make sure the “Snap” feature is disabled in Pamac-Manager (Add/Remove Software GUI).
- Reboot
- Uninstall Snapd
- If it works – Profit!
If it doesn’t work – It’s not the end of the world as we know it!
I should mention that simply disabling the Snap feature in Pamac should be all you need to do. There is no real need to uninstall anything.
