Hello
i doubt there is a list of safe to remove preinstalled softwares,
and since I’m new to Linux i don’t want to mess things up by removing packages and their dependencies which another program might rely on.
is there a benefit from removing those besides not having to DL updates for them?
Thuderbird for example i have no intention on using.
in this reddit post : https://www.reddit.com/r/ManjaroLinux/comments/hfjrqt/is_it_safe_to_remove_these_qt_apps_and_also_those/
a person wants to remove some apps that are meant for qt development and some one points out it might be needed by spectacle
(found this:“The development applications are pat of the QT package, Manjaro and Arch do NOT have a separate package or packages for them. If you uninstall QT you will also have to remove qbittorrent and any other QT based applications like manjaro-settings-manager, etc.”)
here there is an unanswered similar question:
https://classicforum.manjaro.org/index.php?topic=31945.0
