Hello
in order to install Proton VPN from the AUR,i need to add a PGP key to Pacman:
is it safe,any drawback?
Hello
not exactly
If your package manager fails to fetch or import the key
pamac import key for us as with many aur packages
That tutorial is incorrect. You don’t add it to Pacman’s keyring, you add it to your personal keyring:
gpg --recv-key A88441BD4864F95BEE08E63A71EB474019940E11
If you use an AUR helper like Pamac or Yay, it will handle importing the key.
i already tried it in a VM,and it fails to import the key,so i added it manually.
as i understand from your answers,it’s a normal step that happens regularly with many AUR packages,
and i need to run @Yochanan command and skip the 2 other commands they gave?
with AUR: never use pacman-key but gpg
http://allanmcrae.com/2015/01/two-pgp-keyrings-for-package-management-in-arch-linux/
pamac and yay can import developer keys for us (sometime name server is bad…)
read aur page is always good https://aur.archlinux.org/packages/protonvpn/#comment-810551, other way to install key
the VM i ran was Arch and didn’t have Pamac,so i guess on manjaro it will be able to take care of it.
i read the article you provided;
so do i still need to run gpg --lsign <KEYID>? and what about gpg --finger <KEYID> ?
i read the AUR page,but this one:
https://aur.archlinux.org/packages/protonvpn-gui/
No, those commands are not necessary.
with command pacman-key
instead of gpg
Thank you both
