Ryzen power management 400-399mhz issue
So for a while now I have had an issue on my laptop where when I plug it in the power management drops the CPU to 400 or 399mhz as reported by htop and other utils. Once it hits this low, it never comes up again unless I unplug it. I have tried multiple fixes here and nothing stays permanent. Any suggestions? I’ll do anything to be done with this issue. Honestly I am fine with being in Performance 100% of the time if I have to because this is maddening.
CPU : AMD Ryzen 5 5500U
$ uname -a
Linux skip 6.6.5-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri Dec 8 12:53:00 UTC 2023 x86_64 GNU/Linux
[sudo] password for rahlquist:
  Kernel: 6.6.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=14dde68b-b9ee-45ce-80d1-d39ad1e5964b rw
    resume=UUID=d8671092-87bc-4197-9bff-9949df40c4c0 udev.log_priority=3
    nvme_core.default_ps_max_latency_us=0
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
  Type: Laptop System: Dell product: Inspiron 15 3525 v: 1.13.0
    serial: <filter> Chassis: type: 10 v: 1.13.0 serial: <filter>
  Mobo: Dell model: 0C3WG4 v: A00 serial: <filter> UEFI: Dell v: 1.13.0
    date: 09/27/2023
  ID-1: BAT1 charge: 29.6 Wh (72.5%) condition: 40.8/40.8 Wh (100.0%)
    volts: 11.6 min: 11.2 model: BYD 0x4A,0x33,0x35,0x4D,0x00,0x00,0x00
    type: Li-ion serial: <filter> status: discharging
  System RAM: total: 16 GiB available: 14.98 GiB used: 3.68 GiB (24.5%)
  Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
    data: 64 total: 64 manufacturer: Crucial part-no: CT8G4SFS832A.M8FR
    serial: <filter>
  Device-2: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
    data: 64 total: 64 manufacturer: 80AD000080AD part-no: HMAA1GS6CJR6N-XN
    serial: <filter>
  Info: model: AMD Ryzen 5 5500U with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
    microcode: 0x8608104
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1072 high: 2347 min/max: 400/4056 base/boost: 2100/4050
    scaling: driver: amd-pstate-epp governor: powersave volts: 1.2 V
    ext-clock: 100 MHz cores: 1: 1395 2: 400 3: 2347 4: 1397 5: 1397 6: 1537
    7: 400 8: 400 9: 400 10: 400 11: 1397 12: 1394 bogomips: 50321
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Lucienne vendor: Dell driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300
    temp: 45.0 C
  Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 0c45:6d1a
    class-ID: 0e02
  Display: server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: LG Display 0x0738 built: 2022
    res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
    16.0.6 DRM 3.54 6.6.5-1-MANJARO) device-ID: 1002:164c memory: 500 MiB
    unified: no
  API: Vulkan v: 1.3.269 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.1.9-manjaro1.1
    device-ID: 1002:164c surfaces: xcb,xlib
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Dell
    link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.6.5-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.0.0 status: n/a (root, process) with: wireplumber
    status: active tools: pw-cli,wpctl
  Server-4: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2725
    class-ID: 0280
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 8087:0032
    class-ID: e001
  Local Storage: total: 1.82 TiB used: 1.04 TiB (57.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 27.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 41d 19h cycles: 877
    read-units: 6,163,981 [3.15 TB] written-units: 6,533,385 [3.34 TB]
  ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 1.04 TiB (58.3%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 14dde68b-b9ee-45ce-80d1-d39ad1e5964b
    used: 106.7 MiB (35.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 9B87-8934
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: d8671092-87bc-4197-9bff-9949df40c4c0
  Device-1: 3-1:2 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Device-2: 3-4:3 info: Microdia Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0c45:6d1a class-ID: 0e02
  System Temperatures: cpu: 48.0 C mobo: 35.0 C sodimm: SODIMM C gpu: amdgpu
    temp: 45.0 C
  Fan Speeds (rpm): cpu: 0
  Processes: 380 Uptime: 1h 53m wakeups: 1 Init: systemd v: 254
  Packages: pm: pacman pkgs: 1778 libs: 444 tools: pamac,yay pm: rpm pkgs: 0
  pm: flatpak pkgs: 0 Shell: Sudo (sudo) v: 1.9.15p2 default: Bash v: 5.2.21
  running-in: konsole inxi: 3.3.31
[rahlquist@skip ~]$
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
Are you tlp installed? You used plasma power profile ? I suggest just to test plasma wayland session as it has no pwoer profiles in it (in my installation, I think, it can be the same for you).
