I just reinstalled after a year of being in “away” and the wifi still doesn’t work on my laptop so I have my phone USB Tethered to the laptop. Here’s my laptop information with “inxi -Fxz”
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.16.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X509DA_D509DA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X509DA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X509DA.306 date: 10/11/2019
ID-1: BAT0 charge: 25.3 Wh (91.3%) condition: 27.7/32.1 Wh (86.4%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery status: Charging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
charge: 55% (should be ignored) status: Discharging
Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L2: 2 MiB
bogomips: 33551
Speed: 1226 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1226 2: 1224 3: 1224 4: 1225 5: 1276 6: 1343 7: 1224 8: 1226
Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 03:00.0
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-2.2:5
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati
unloaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.10.36-2-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
bus-ID: 03:00.5
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.27 running: no
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: N/A port: f000 bus-ID: 01:00.0
IF-ID-1: enp3s0f3u4 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Xiaomi Mi/Redmi series (RNDIS) type: USB driver: rndis_host
v: kernel bus-ID: 1-4:4
Device-2: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-2.1:4
Report: ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 238.47 GiB used: 7.93 GiB (3.3%)
ID-1: /dev/nvme0n1 vendor: Western Digital
model: PC SN520 SDAPNUW-256G-1102 size: 238.47 GiB temp: 37.9 C
ID-1: / size: 233.38 GiB used: 7.93 GiB (3.4%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 64.5 C mobo: 64.0 C gpu: amdgpu temp: 64.0 C
Fan Speeds (RPM): cpu: 2800
Processes: 238 Uptime: 25m Memory: 5.81 GiB used: 1.26 GiB (21.6%)
Init: systemd Compilers: gcc: N/A Packages: 1091 Shell: Bash v: 5.1.8
inxi: 3.3.04
