So i was browsing and suddenly pc crashed had to manually restart but after i did that not getting any display signal, so i re seated the gpu it worked but dont have any crash logs in journal. Was using 5.12 kernel at the time. So i wonder is my gpu dying or its just a bug? Also did few heaven and furmark stress tests on win10 no crash, no glitches. Just it bothers me that i got no logs in the journal.
System: Kernel: 5.11.16-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.4 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: H97-PRO GAMER v: Rev X.0x serial: <filter> UEFI: American Megatrends v: 2503 date: 02/26/2016
CPU: Info: Quad Core model: Intel Core i7-4790 bits: 64 type: MT MCP arch: Haswell rev: 3 cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57619
Speed: 897 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 897 2: 3303 3: 1102 4: 864 5: 1026 6: 2398 7: 1048
8: 3601
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus-ID: 01:00.0
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: modesetting resolution: 1920x1080
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.40.0 5.11.16-2-MANJARO LLVM 11.1.0) v: 4.6 Mesa 21.0.3
direct render: Yes
Audio: Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Sapphire Limited driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Device-3: Yamaha Steinberg UR22mkII type: USB driver: snd-usb-audio bus-ID: 3-13.1:6
Sound Server-1: ALSA v: k5.11.16-2-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.26 running: yes
Network: Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel port: f040 bus-ID: 00:19.0
RAID: Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 bus-ID: 00:1f.2
Device-1: md126 type: mdraid level: raid-0 status: active size: 465.77 GiB
Info: report: N/A blocks: 488391680 chunk-size: 128k
Components: Online: 0: sdb 1: sda
Device-2: md127 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 5488 chunk-size: N/A
Components: Online: N/A Spare: 0: sda 1: sdb
Drives: Local Storage: total: raw: 1.59 TiB usable: 1.14 TiB used: 8.49 GiB (0.7%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
ID-3: /dev/sdc vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB
ID-4: /dev/sdd vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 227.88 GiB used: 8.49 GiB (3.7%) fs: ext4 dev: /dev/sdd2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/sdd1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1694
Info: Processes: 241 Uptime: 1m Memory: 23.43 GiB used: 1.42 GiB (6.1%) Init: systemd Compilers: gcc: 10.2.0
Packages: 1205 Shell: Bash v: 5.1.0 inxi: 3.3.04
