So basically after three hours of streaming and playing RE8 through Steam crashes my RX 9070 XT and it takes down all of the running apps with it.
I managed to find journalctl logs for kernel.
helmi 06 06:26:45 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:5 pasid:32796)
helmi 06 06:26:45 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: Process re8.exe pid 26621 thread vkd3d_queue pid 28511
helmi 06 06:26:45 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: in page starting at address 0x00008000aedae000 from client 10
helmi 06 06:26:45 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00501430
helmi 06 06:26:45 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: Faulty UTCL2 client ID: SQC (data) (0xa)
helmi 06 06:26:45 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: MORE_FAULTS: 0x0
helmi 06 06:26:45 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: WALKER_ERROR: 0x0
helmi 06 06:26:45 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: PERMISSION_FAULTS: 0x3
helmi 06 06:26:45 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: MAPPING_ERROR: 0x0
helmi 06 06:26:45 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: RW: 0x0
helmi 06 06:26:56 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: Dumping IP State
helmi 06 06:06:51 user-pc NetworkManager[743]: <info> [1770350811.4024] dhcp4 (enp9s0f3u2): state changed new lease, address=10.140.77.237
helmi 06 06:06:51 user-pc systemd[1]: Starting Network Manager Script Dispatcher Service...
helmi 06 06:06:51 user-pc systemd[1]: Started Network Manager Script Dispatcher Service.
helmi 06 06:07:01 user-pc systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
helmi 06 06:26:56 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: Dumping IP State Completed
helmi 06 06:26:56 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: [drm] AMDGPU device coredump file has been created
helmi 06 06:26:56 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
helmi 06 06:26:56 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: ring gfx_0.0.0 timeout, signaled seq=24628686, emitted seq=24628688
helmi 06 06:26:56 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: Process re8.exe pid 26621 thread vkd3d_queue pid 28511
helmi 06 06:26:56 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: Starting gfx_0.0.0 ring reset
helmi 06 06:26:58 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: MES(1) failed to respond to msg=RESET
helmi 06 06:26:58 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: failed to reset legacy queue
helmi 06 06:26:58 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: reset via MES failed and try pipe reset -110
helmi 06 06:26:58 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: The CPFW hasn't support pipe reset yet.
helmi 06 06:26:58 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: Ring gfx_0.0.0 reset failed
helmi 06 06:26:58 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: GPU reset begin!. Source: 1
helmi 06 06:27:02 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: failed to suspend display audio
helmi 06 06:27:05 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
helmi 06 06:27:05 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: failed to unmap legacy queue
helmi 06 06:27:08 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
helmi 06 06:27:08 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: failed to unmap legacy queue
helmi 06 06:27:11 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
helmi 06 06:27:11 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: failed to unmap legacy queue
helmi 06 06:27:13 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
helmi 06 06:27:13 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: failed to unmap legacy queue
helmi 06 06:27:16 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
helmi 06 06:27:16 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: failed to unmap legacy queue
helmi 06 06:27:19 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: MES(1) failed to respond to msg=REMOVE_QUEUE
helmi 06 06:27:19 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: failed to unmap legacy queue
helmi 06 06:27:19 user-pc kernel: [drm:gfx_v12_0_hw_fini [amdgpu]] *ERROR* failed to halt cp gfx
helmi 06 06:27:19 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: MODE1 reset
helmi 06 06:27:19 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: GPU mode1 reset
helmi 06 06:27:19 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: GPU smu mode1 reset
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: GPU reset succeeded, trying to resume
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: PCIE GART of 512M enabled (table at 0x00000083DAB00000).
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: VRAM is lost due to GPU reset!
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: PSP is resuming...
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: RAP: optional rap ta ucode is not available
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: SMU is resuming...
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: smu driver if version = 0x0000002e, smu fw if version = 0x00000032, smu fw program = 0, >
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: SMU driver if version not matched
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: SMU is resumed successfully!
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: program CP_MES_CNTL : 0x4000000
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: program CP_MES_CNTL : 0xc000000
helmi 06 06:27:20 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x0A000700
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: ring sdma0 uses VM inv eng 9 on hub 0
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: ring sdma1 uses VM inv eng 10 on hub 0
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
helmi 06 06:27:21 user-pc flatpak[37589]: amdgpu: The CS has cancelled because the context is lost. This context is innocent.
helmi 06 06:27:21 user-pc steam[25183]: radv/amdgpu: The CS has been cancelled because the context is lost. This context is innocent.
helmi 06 06:27:21 user-pc steam[25183]: radv: GPUVM fault detected at address 0x8000aedae000.
helmi 06 06:27:21 user-pc steam[25183]: GCVM_L2_PROTECTION_FAULT_STATUS: 0x501430
helmi 06 06:27:21 user-pc steam[25183]: CLIENT_ID: (SQC (data)) 0xa
helmi 06 06:27:21 user-pc steam[25183]: MORE_FAULTS: 0
helmi 06 06:27:21 user-pc steam[25183]: WALKER_ERROR: 0
helmi 06 06:27:21 user-pc steam[25183]: PERMISSION_FAULTS: 3
helmi 06 06:27:21 user-pc steam[25183]: MAPPING_ERROR: 0
helmi 06 06:27:21 user-pc steam[25183]: RW: 0
helmi 06 06:27:21 user-pc kwin_wayland[1203]: 0x3: GL_CONTEXT_LOST in context lost
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: GPU reset(1) succeeded!
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: [drm] device wedged, but recovered through reset
helmi 06 06:27:21 user-pc kernel: amdgpu 0000:07:00.0: amdgpu: [drm] *ERROR* Failed to initialize parser -125!
helmi 06 06:27:21 user-pc kwin_wayland[1203]: A graphics reset not attributable to the current GL context occurred.
helmi 06 06:27:21 user-pc systemd-coredump[70537]: Process 37589 (obs) of user 1000 terminated abnormally with signal 6/ABRT, processing...
helmi 06 06:27:21 user-pc systemd[1]: Started Process Core Dump (PID 70537/UID 0).
helmi 06 06:27:21 user-pc kwin_wayland[1203]: BlurConfig::instance called after the first use - ignoring
helmi 06 06:27:21 user-pc kwin_wayland[1203]: GlideConfig::instance called after the first use - ignoring
helmi 06 06:27:21 user-pc kwin_wayland[1203]: KscreenConfig::instance called after the first use - ignoring
helmi 06 06:27:21 user-pc kwin_wayland[1203]: OverviewConfig::instance called after the first use - ignoring
helmi 06 06:27:21 user-pc kwin_wayland[1203]: SlideConfig::instance called after the first use - ignoring
helmi 06 06:27:21 user-pc kwin_wayland[1203]: SlidingPopupsConfig::instance called after the first use - ignoring
helmi 06 06:27:21 user-pc kwin_wayland[1203]: WindowViewConfig::instance called after the first use - ignoring
helmi 06 06:27:21 user-pc kwin_wayland[1203]: ZoomConfig::instance called after the first use - ignoring
helmi 06 06:27:21 user-pc kwin_wayland[1203]: Could not delete render time query because no context is current
helmi 06 06:27:21 user-pc lact[10675]: 2026-02-06T04:27:21.441775Z INFO lact_daemon: got kernel drm subsystem event, reloading GPUs
helmi 06 06:27:21 user-pc plasmashell[1470]: QRhiGles2: Context is lost.
helmi 06 06:27:21 user-pc plasmashell[1470]: Graphics device lost, cleaning up scenegraph and releasing RHI
helmi 06 06:27:21 user-pc flatpak[58684]: Crash Annotation GraphicsCriticalError: |[0][GFX1-]: GFX: CanvasTranslator failed creating WebGL shared conte>
helmi 06 06:27:21 user-pc lact[10675]: 2026-02-06T04:27:21.466016Z INFO lact_daemon::server::handler: initialized amdgpu controller for GPU 1002:7550->
helmi 06 06:27:21 user-pc lact[10675]: 2026-02-06T04:27:21.466031Z INFO lact_daemon::server::handler: GPU list reloaded with 1 devices, reapplying con>
helmi 06 06:27:21 user-pc lact[10675]: 2026-02-06T04:27:21.475582Z INFO lact_daemon::server::handler: configuration applied
