I’m not sure if the tittle is misleading but I think my graphics card is not being properly detected. I normally use nvidia graphics card so all these problems are new to me. For drivers, I just used open-source drivers when installing and only change kernel from 5.10 to 5.12. I listed a couple of “problems” that I noticed the past 3 days.
When I do a neofetch it gives me: AMD ATI 03:00.0 Navi 22
What I expect is: RX 6700 XT
I expect this behavior because I have been using nvidia gpus for the past 5 years. So please let me know if this is normal.
My second problem is that I can’t get openCL working. I’m a self proclaimed part time crypto miner so I read another post which suggested installing opencl-amd
from the AUR. Now clinfo
returns a wall of text instead of a zero. So I though problem solved. But the mining software still get errors about openCL. Is it something not related to manjaro? Is it better to ask the developers of the software?
Coming from nvidia, I always used watch -n 1 nvidia-smi
to monitor stats of the graphics card. So I use radeontop
as a replacement. What I noticed here is that on the top it says UNKNOWN_CHIP. Is this normal?
I have no issues gaming with this graphics card with proton on steam
This is my second post on this forum, please let me know if need to fix my formatting or you need more information.
sudo radeontop
radeontop 1.3, running on UNKNOWN_CHIP bus 03, 120 samples/sec
Graphics pipe 0,00% │
Event Engine 0,00% │
Vertex Grouper + Tesselator 0,00% │
Texture Addresser 0,00% │
Texture Cache 0,00% │
Shader Export 0,00% │
Sequencer Instruction Cache 0,00% │
Shader Interpolator 0,00% │
Shader Memory Exchange 0,00% │
Scan Converter 0,00% │
Primitive Assembly 0,00% │
Depth Block 0,00% │
Color Block 0,00% │
Clip Rectangle 0,00% │
28M / 12248M VRAM 0,23% │
17M / 12261M GTT 0,14% │
0,10G / 1,00G Memory Clock 9,60% │
0,50G / 2,86G Shader Clock 17,51% │
clinfo
Number of platforms 1
Platform Name AMD Accelerated Parallel Processing
Platform Vendor Advanced Micro Devices, Inc.
Platform Version OpenCL 2.0 AMD-APP (3261.0)
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_icd cl_amd_event_callback
Platform Extensions function suffix AMD
Number of devices 1
Device Name gfx1031
Device Vendor Advanced Micro Devices, Inc.
Device Vendor ID 0x1002
Device Version OpenCL 2.0
Driver Version 3261.0 (HSA1.1,LC)
Device OpenCL C Version OpenCL C 2.0
Device Type GPU
Device Board Name (AMD) Navi 22
Device PCI-e ID (AMD) 0x73df
Device Topology (AMD) PCI-E, 0000:03:00.0
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Linker Available Yes
Max compute units 20
SIMD per compute unit (AMD) 4
SIMD width (AMD) 32
SIMD instruction width (AMD) 1
Max clock frequency 2855MHz
Graphics IP (AMD) 10.3
Device Partition (core)
Max number of sub-devices 20
Supported partition types None
Supported affinity domains (n/a)
Max work item dimensions 3
Max work item sizes 1024x1024x1024
Max work group size 256
Preferred work group size (AMD) 256
Max work group size (AMD) 1024
Preferred work group size multiple (kernel) 32
Wavefront width (AMD) 32
Preferred / native vector sizes
char 4 / 4
short 2 / 2
int 1 / 1
long 1 / 1
half 1 / 1 (cl_khr_fp16)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Half-precision Floating-point support (cl_khr_fp16)
Denormals No
Infinity and NANs No
Round to nearest No
Round to zero No
Round to infinity No
IEEE754-2008 fused multiply-add No
Support is emulated in software No
Single-precision Floating-point support (core)
Denormals Yes
Infinity and NANs Yes
Round to nearest Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Correctly-rounded divide and sqrt operations Yes
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Address bits 64, Little-Endian
Global memory size 12868124672 (11.98GiB)
Global free memory (AMD) 12566528 (11.98GiB) 12566528 (11.98GiB)
Global memory channels (AMD) 6
Global memory banks per channel (AMD) 4
Global memory bank width (AMD) 256 bytes
Error Correction support No
Max memory allocation 10937905968 (10.19GiB)
Unified memory for Host and Device No
Shared Virtual Memory (SVM) capabilities (core)
Coarse-grained buffer sharing Yes
Fine-grained buffer sharing Yes
Fine-grained system sharing No
Atomics No
Minimum alignment for any data type 128 bytes
Alignment of base address 1024 bits (128 bytes)
Preferred alignment for atomics
SVM 0 bytes
Global 0 bytes
Local 0 bytes
Max size for global variable 10937905968 (10.19GiB)
Preferred total size of global vars 12868124672 (11.98GiB)
Global Memory cache type Read/Write
Global Memory cache size 16384 (16KiB)
Global Memory cache line size 64 bytes
Image support Yes
Max number of samplers per kernel 29663
Max size for 1D images from buffer 134217728 pixels
Max 1D or 2D image array size 8192 images
Base address alignment for 2D image buffers 256 bytes
Pitch alignment for 2D image buffers 256 pixels
Max 2D image size 16384x16384 pixels
Max 3D image size 16384x16384x8192 pixels
Max number of read image args 128
Max number of write image args 8
Max number of read/write image args 64
Max number of pipe args 16
Max active pipe reservations 16
Max pipe packet size 2347971376 (2.187GiB)
Local memory type Local
Local memory size 65536 (64KiB)
Local memory size per CU (AMD) 65536 (64KiB)
Local memory banks (AMD) 32
Max number of constant args 8
Max constant buffer size 10937905968 (10.19GiB)
Preferred constant buffer size (AMD) 16384 (16KiB)
Max size of kernel argument 1024
Queue properties (on host)
Out-of-order execution No
Profiling Yes
Queue properties (on device)
Out-of-order execution Yes
Profiling Yes
Preferred size 262144 (256KiB)
Max size 8388608 (8MiB)
Max queues on device 1
Max events on device 1024
Prefer user sync for interop Yes
Number of P2P devices (AMD) 0
Profiling timer resolution 1ns
Profiling timer offset since Epoch (AMD) 0ns (Thu Jan 1 01:00:00 1970)
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
Thread trace supported (AMD) No
Number of async queues (AMD) 8
Max real-time compute queues (AMD) 8
Max real-time compute units (AMD) 20
printf() buffer size 4194304 (4MiB)
Built-in kernels (n/a)
Device Extensions cl_khr_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_media_ops cl_amd_media_ops2 cl_khr_image2d_from_buffer cl_khr_subgroups cl_khr_depth_images cl_amd_copy_buffer_p2p cl_amd_assembly_program
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) AMD Accelerated Parallel Processing
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [AMD]
clCreateContext(NULL, ...) [default] Success [AMD]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
Device Name gfx1031
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1)
Device Name gfx1031
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
Device Name gfx1031
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.3.0
ICD loader Profile OpenCL 3.0
Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.12-x86_64
root=UUID=ae0dc959-cd8b-4a6b-a14b-ba43a83f73af rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=88a536fe-0385-4e9e-b44c-aeb07981424f udev.log_priority=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z390-F GAMING v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 1502 date: 02/21/2020
Device-1: hidpp_battery_0 model: Logitech M705 serial: <filter> charge: 55%
rechargeable: yes status: Discharging
RAM: total: 31.2 GiB used: 2.48 GiB (8.0%)
Info: 8-Core model: Intel Core i9-9900K bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: C (12)
microcode: DE cache: L2: 16 MiB bogomips: 115232
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 3934
3: 3126 4: 2292 5: 1745 6: 867 7: 800 8: 800 9: 800 10: 800 11: 800 12: 905
13: 800 14: 801 15: 799 16: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep
smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3e98 class-ID: 0300
Device-2: AMD Navi 22 vendor: Gigabyte driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati,intel unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3280x1080 s-dpi: 96 s-size: 865x285mm (34.1x11.2")
s-diag: 911mm (35.9")
Monitor-1: DP1 res: 1920x1080 dpi: 90 size: 540x300mm (21.3x11.8")
diag: 618mm (24.3")
Monitor-2: HDMI2 res: 1360x768 hz: 60 dpi: 54 size: 640x360mm (25.2x14.2")
diag: 734mm (28.9")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
Device-2: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
chip-ID: 1002:ab28 class-ID: 0403
Device-3: RODE Microphones RØDE NT-USB Mini type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:2 chip-ID: 19f7:0015
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 2.96 TiB used: 45.73 GiB (1.5%)
model: WDS250G3X0C-00SJG0 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 111110WD scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
rotation: SSD serial: <filter> rev: 030 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EZRZ-00Z5HB0
rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: GPT
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24D5MT rev: 1.00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 899.22 GiB size: 899.22 GiB (100.00%)
used: 45.73 GiB (5.1%) fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: ae0dc959-cd8b-4a6b-a14b-ba43a83f73af
used: 588 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 8409-E12E
ID-3: /home raw-size: 899.22 GiB size: 899.22 GiB (100.00%)
ID-4: /var/cache raw-size: 899.22 GiB size: 899.22 GiB (100.00%)
ID-5: /var/log raw-size: 899.22 GiB size: 899.22 GiB (100.00%)
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 88a536fe-0385-4e9e-b44c-aeb07981424f
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 450 MiB fs: <superuser required>
label: Herstel uuid: E2188F8D188F6001
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 100 MiB fs: <superuser required>
label: N/A uuid: E48F-B69B
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 231.8 GiB fs: <superuser required>
label: N/A uuid: C690A88590A87D95
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 540 MiB fs: <superuser required>
label: N/A uuid: 54522D0A522CF282
ID-6: /dev/sdb1 maj-min: 8:17 size: 300 MiB fs: <superuser required>
label: N/A uuid: EE80-425F
ID-7: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
ID-8: /dev/sdb3 maj-min: 8:19 size: 1.82 TiB fs: <superuser required>
label: System uuid: C020A4E820A4E69E
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-3:2 info: RODE Microphones RØDE NT-USB Mini type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 19f7:0015 class-ID: 0300
serial: <filter>
Hub-2: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-6.4:5 info: ASUSTek AURA MOTHERBOARD type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:18a3 class-ID: 0300 serial: <filter>
Hub-3: 1-9:4 info: Microchip (formerly SMSC) USB2734 ports: 5 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2734 class-ID: 0900
Device-1: 1-9.5:12 info: Microchip (formerly SMSC) Hub Controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip-ID: 0424:274c class-ID: 0300
Device-2: 1-13:6 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 1-14:7 info: ASUSTek ROG Claymore Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0b05:184d class-ID: 0300
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-5: 2-9:2 info: Microchip (formerly SMSC) USB5734 ports: 5 rev: 3.1
speed: 5 Gb/s chip-ID: 0424:5734 class-ID: 0900
System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 39.0 C
mem: 38.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 365 Uptime: 3m wakeups: 3 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1260 lib: 328 flatpak: 0
Shell: Bash v: 5.1.8 running-in: terminator inxi: 3.3.04
