Hi
Few days ago I bought RX 6650 XT and now I have trouble to configure it to get most of it.
Basically my FPS are very low. I’m using mesa-git, lib32-mesa-git and kernel 5.17.6
Is there something more I have to do to unlock full potential of this card?
you can go to Testing branch
Switched to testing branch. No luck. Also recompiled mesa-git and libdrm-git. My GPU is recognized in system info but in Path of Exile for example, still low FPS
openSUSE Tumbleweed is only distro which working well with this GPU from the fresh install and gives me full FPS. However I would like to stay on manjaro if possible
are you using
Steam ? Proton ?
Lutris ?
GOG ?
Wine ?
Ah right. It’s steam with proton.
Check this
AMDGPU - ArchWikiand_Sea_Islands(CIK)_support
This might also reveal something useful [ Solved ] Random performance AMDGPU 6600 XT / Kernel & Hardware / Arch Linux Forums
Ok. I solved this.
Just updated linux-firmware from Git and everything back to normal. Performance is great.
Did not expect that, firmware may have impact on performance.
