I recently installed Manjaro hoping it would work with my 580 but it doesn’t and i don’t know why. It works in windows without problems so its not the GPU.
output of vulkaninfo
VULKANINFO
Vulkan Instance Version: 1.2.191
Instance Extensions: count = 19
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Layers: count = 1
VK_LAYER_NV_optimus (NVIDIA Optimus layer) Vulkan version 1.2.175, layer version 1:
Layer Extensions: count = 0
Devices: count = 2
GPU id = 0 (AMD RADV POLARIS10)
Layer-Device Extensions: count = 0
GPU id = 1 (NVIDIA GeForce GTX 1050 Ti)
Presentable Surfaces:
GPU id : 0 (AMD RADV POLARIS10):
Surface types: count = 2
VK_KHR_xcb_surface
VK_KHR_xlib_surface
Formats: count = 2
SurfaceFormat[0]:
format = FORMAT_B8G8R8A8_SRGB
colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
SurfaceFormat[1]:
format = FORMAT_B8G8R8A8_UNORM
Present Modes: count = 4
PRESENT_MODE_IMMEDIATE_KHR
PRESENT_MODE_MAILBOX_KHR
PRESENT_MODE_FIFO_KHR
PRESENT_MODE_FIFO_RELAXED_KHR
VkSurfaceCapabilitiesKHR:
minImageCount = 3
maxImageCount = 0
currentExtent:
width = 256
height = 256
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
maxImageArrayLayers = 1
supportedTransforms: count = 1
SURFACE_TRANSFORM_IDENTITY_BIT_KHR
currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
supportedCompositeAlpha: count = 2
COMPOSITE_ALPHA_OPAQUE_BIT_KHR
COMPOSITE_ALPHA_INHERIT_BIT_KHR
supportedUsageFlags: count = 5
IMAGE_USAGE_TRANSFER_SRC_BIT
IMAGE_USAGE_TRANSFER_DST_BIT
IMAGE_USAGE_SAMPLED_BIT
IMAGE_USAGE_STORAGE_BIT
IMAGE_USAGE_COLOR_ATTACHMENT_BIT
VkSurfaceCapabilities2EXT:
supportedSurfaceCounters:
None
VkSurfaceProtectedCapabilitiesKHR:
supportsProtected = false
GPU id : 1 (NVIDIA GeForce GTX 1050 Ti):
VK_KHR_xcb_surface
VK_KHR_xlib_surface
Formats: count = 2
SurfaceFormat[0]:
SurfaceFormat[1]:
Present Modes: count = 3
minImageCount = 2
maxImageCount = 8
currentExtent:
width = 256
height = 256
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
supportedCompositeAlpha: count = 1
supportedUsageFlags: count = 6
IMAGE_USAGE_INPUT_ATTACHMENT_BIT
None
Device Groups:
Group 0:
Properties:
physicalDevices: count = 1
AMD RADV POLARIS10 (ID: 0)
subsetAllocation = 0
Present Capabilities:
AMD RADV POLARIS10 (ID: 0):
Can present images from the following devices: count = 1
Present modes: count = 1
DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Group 1:
Properties:
NVIDIA GeForce GTX 1050 Ti (ID: 0)
NVIDIA GeForce GTX 1050 Ti (ID: 0):
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
apiVersion = 4202678 (1.2.182)
driverVersion = 88088577 (0x5402001)
vendorID = 0x1002
deviceID = 0x67df
deviceType = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
deviceName = AMD RADV POLARIS10
pipelineCacheUUID = 86f127e5-9b5b-fc6f-4131-70a4d6b68cc8
VkPhysicalDeviceLimits:
maxImageDimension1D = 16384
maxImageDimension2D = 16384
maxImageDimension3D = 2048
maxImageDimensionCube = 16384
maxImageArrayLayers = 2048
maxTexelBufferElements = 4294967295
maxUniformBufferRange = 4294967295
maxStorageBufferRange = 4294967295
maxPushConstantsSize = 128
maxMemoryAllocationCount = 4294967295
maxSamplerAllocationCount = 65536
bufferImageGranularity = 0x00000040
sparseAddressSpaceSize = 0xfffffffc
maxBoundDescriptorSets = 32
maxPerStageDescriptorSamplers = 8388606
maxPerStageDescriptorUniformBuffers = 8388606
maxPerStageDescriptorStorageBuffers = 8388606
maxPerStageDescriptorSampledImages = 8388606
maxPerStageDescriptorStorageImages = 8388606
maxPerStageDescriptorInputAttachments = 8388606
maxPerStageResources = 8388606
maxDescriptorSetSamplers = 8388606
maxDescriptorSetUniformBuffers = 8388606
maxDescriptorSetUniformBuffersDynamic = 16
maxDescriptorSetStorageBuffers = 8388606
maxDescriptorSetStorageBuffersDynamic = 8
maxDescriptorSetSampledImages = 8388606
maxDescriptorSetStorageImages = 8388606
maxDescriptorSetInputAttachments = 8388606
maxVertexInputAttributes = 32
maxVertexInputBindings = 32
maxVertexInputAttributeOffset = 4294967295
maxVertexInputBindingStride = 2048
maxVertexOutputComponents = 128
maxTessellationGenerationLevel = 64
maxTessellationPatchSize = 32
maxTessellationControlPerVertexInputComponents = 128
maxTessellationControlPerVertexOutputComponents = 128
maxTessellationControlPerPatchOutputComponents = 120
maxTessellationControlTotalOutputComponents = 4096
maxTessellationEvaluationInputComponents = 128
maxTessellationEvaluationOutputComponents = 128
maxGeometryShaderInvocations = 127
maxGeometryInputComponents = 64
maxGeometryOutputComponents = 128
maxGeometryOutputVertices = 256
maxGeometryTotalOutputComponents = 1024
maxFragmentInputComponents = 128
maxFragmentOutputAttachments = 8
maxFragmentDualSrcAttachments = 1
maxFragmentCombinedOutputResources = 8
maxComputeSharedMemorySize = 65536
maxComputeWorkGroupCount: count = 3
65535
65535
65535
maxComputeWorkGroupInvocations = 1024
maxComputeWorkGroupSize: count = 3
1024
1024
1024
subPixelPrecisionBits = 8
subTexelPrecisionBits = 8
mipmapPrecisionBits = 8
maxDrawIndexedIndexValue = 4294967295
maxDrawIndirectCount = 4294967295
maxSamplerLodBias = 16
maxSamplerAnisotropy = 16
maxViewports = 16
maxViewportDimensions: count = 2
16384
16384
viewportBoundsRange: count = 2
-32768
32767
viewportSubPixelBits = 8
minMemoryMapAlignment = 4096
minTexelBufferOffsetAlignment = 0x00000004
minUniformBufferOffsetAlignment = 0x00000004
minStorageBufferOffsetAlignment = 0x00000004
minTexelOffset = -32
maxTexelOffset = 31
minTexelGatherOffset = -32
maxTexelGatherOffset = 31
minInterpolationOffset = -2
maxInterpolationOffset = 2
subPixelInterpolationOffsetBits = 8
maxFramebufferWidth = 16384
maxFramebufferHeight = 16384
maxFramebufferLayers = 1024
framebufferColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferDepthSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferStencilSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferNoAttachmentsSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxColorAttachments = 8
sampledImageColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageIntegerSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageDepthSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageStencilSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
storageImageSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxSampleMaskWords = 1
timestampComputeAndGraphics = true
timestampPeriod = 40
maxClipDistances = 8
maxCullDistances = 8
maxCombinedClipAndCullDistances = 8
discreteQueuePriorities = 2
pointSizeRange: count = 2
0
8191.88
lineWidthRange: count = 2
0
8191.88
pointSizeGranularity = 0.125
lineWidthGranularity = 0.125
strictLines = false
standardSampleLocations = true
optimalBufferCopyOffsetAlignment = 0x00000080
optimalBufferCopyRowPitchAlignment = 0x00000080
nonCoherentAtomSize = 0x00000040
VkPhysicalDeviceSparseProperties:
residencyStandard2DBlockShape = true
residencyStandard2DMultisampleBlockShape = false
residencyStandard3DBlockShape = false
residencyAlignedMipSize = false
residencyNonResidentStrict = true
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
maxCustomBorderColorSamplers = 4096
VkPhysicalDeviceDepthStencilResolveProperties:
supportedDepthResolveModes: count = 4
RESOLVE_MODE_SAMPLE_ZERO_BIT
RESOLVE_MODE_AVERAGE_BIT
RESOLVE_MODE_MIN_BIT
RESOLVE_MODE_MAX_BIT
supportedStencilResolveModes: count = 3
independentResolveNone = true
independentResolve = true
VkPhysicalDeviceDescriptorIndexingProperties:
maxUpdateAfterBindDescriptorsInAllPools = 67108863
shaderUniformBufferArrayNonUniformIndexingNative = false
shaderSampledImageArrayNonUniformIndexingNative = false
shaderStorageBufferArrayNonUniformIndexingNative = false
shaderStorageImageArrayNonUniformIndexingNative = false
shaderInputAttachmentArrayNonUniformIndexingNative = false
robustBufferAccessUpdateAfterBind = true
quadDivergentImplicitLod = false
maxPerStageDescriptorUpdateAfterBindSamplers = 8388606
maxPerStageDescriptorUpdateAfterBindUniformBuffers = 8388606
maxPerStageDescriptorUpdateAfterBindStorageBuffers = 8388606
maxPerStageDescriptorUpdateAfterBindSampledImages = 8388606
maxPerStageDescriptorUpdateAfterBindStorageImages = 8388606
maxPerStageDescriptorUpdateAfterBindInputAttachments = 8388606
maxPerStageUpdateAfterBindResources = 8388606
maxDescriptorSetUpdateAfterBindSamplers = 8388606
maxDescriptorSetUpdateAfterBindUniformBuffers = 8388606
maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 16
maxDescriptorSetUpdateAfterBindStorageBuffers = 8388606
maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindSampledImages = 8388606
maxDescriptorSetUpdateAfterBindStorageImages = 8388606
maxDescriptorSetUpdateAfterBindInputAttachments = 8388606
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
maxDiscardRectangles = 4
VkPhysicalDeviceDriverProperties:
driverID = DRIVER_ID_MESA_RADV
driverName = radv
driverInfo = Mesa 21.2.1
conformanceVersion = 1.2.3.0
VkPhysicalDeviceDrmPropertiesEXT:
hasPrimary = true
hasRender = true
primaryMajor = 226
primaryMinor = 1
renderMajor = 226
renderMinor = 129
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
denormBehaviorIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
roundingModeIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
shaderSignedZeroInfNanPreserveFloat16 = false
shaderSignedZeroInfNanPreserveFloat32 = true
shaderSignedZeroInfNanPreserveFloat64 = true
shaderDenormPreserveFloat16 = false
shaderDenormPreserveFloat32 = true
shaderDenormPreserveFloat64 = true
shaderDenormFlushToZeroFloat16 = false
shaderDenormFlushToZeroFloat32 = true
shaderDenormFlushToZeroFloat64 = true
shaderRoundingModeRTEFloat16 = false
shaderRoundingModeRTEFloat32 = true
shaderRoundingModeRTEFloat64 = true
shaderRoundingModeRTZFloat16 = false
shaderRoundingModeRTZFloat32 = true
shaderRoundingModeRTZFloat64 = true
VkPhysicalDeviceIDProperties:
deviceUUID = 00000000-0500-0000-0000-000000000000
driverUUID = 414d442d-4d45-5341-2d44-525600000000
deviceNodeMask = 0
deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
maxInlineUniformBlockSize = 4194304
maxPerStageDescriptorInlineUniformBlocks = 134217728
maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 134217728
maxDescriptorSetInlineUniformBlocks = 64
maxDescriptorSetUpdateAfterBindInlineUniformBlocks = 64
VkPhysicalDeviceLineRasterizationPropertiesEXT:
lineSubPixelPrecisionBits = 4
VkPhysicalDeviceMaintenance3Properties:
maxPerSetDescriptors = 22369621
maxMemoryAllocationSize = 0xfffffffc
VkPhysicalDeviceMultiDrawPropertiesEXT:
maxMultiDrawCount = 2048
VkPhysicalDeviceMultiviewProperties:
maxMultiviewViewCount = 8
maxMultiviewInstanceIndex = 2147483647
VkPhysicalDevicePCIBusInfoPropertiesEXT:
pciDomain = 0
pciBus = 5
pciDevice = 0
pciFunction = 0
VkPhysicalDevicePointClippingProperties:
pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_ALL_CLIP_PLANES
VkPhysicalDeviceProtectedMemoryProperties:
protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
provokingVertexModePerPipeline = true
transformFeedbackPreservesTriangleFanProvokingVertex = true
VkPhysicalDevicePushDescriptorPropertiesKHR:
maxPushDescriptors = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
robustStorageBufferAccessSizeAlignment = 0x00000004
robustUniformBufferAccessSizeAlignment = 0x00000004
VkPhysicalDeviceSampleLocationsPropertiesEXT:
sampleLocationSampleCounts: count = 3
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxSampleLocationGridSize:
width = 2
height = 2
sampleLocationCoordinateRange: count = 2
0
0.9375
sampleLocationSubPixelBits = 4
variableSampleLocations = false
VkPhysicalDeviceSamplerFilterMinmaxProperties:
filterMinmaxSingleComponentFormats = true
filterMinmaxImageComponentMapping = false
VkPhysicalDeviceSubgroupProperties:
subgroupSize = 64
supportedStages: count = 8
SHADER_STAGE_VERTEX_BIT
SHADER_STAGE_TESSELLATION_CONTROL_BIT
SHADER_STAGE_TESSELLATION_EVALUATION_BIT
SHADER_STAGE_GEOMETRY_BIT
SHADER_STAGE_FRAGMENT_BIT
SHADER_STAGE_COMPUTE_BIT
SHADER_STAGE_ALL_GRAPHICS
SHADER_STAGE_ALL
supportedOperations: count = 8
SUBGROUP_FEATURE_BASIC_BIT
SUBGROUP_FEATURE_VOTE_BIT
SUBGROUP_FEATURE_ARITHMETIC_BIT
SUBGROUP_FEATURE_BALLOT_BIT
SUBGROUP_FEATURE_SHUFFLE_BIT
SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
SUBGROUP_FEATURE_CLUSTERED_BIT
SUBGROUP_FEATURE_QUAD_BIT
quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
minSubgroupSize = 64
maxSubgroupSize = 64
maxComputeWorkgroupSubgroups = 4294967295
requiredSubgroupSizeStages:
None
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
storageTexelBufferOffsetAlignmentBytes = 0x00000004
storageTexelBufferOffsetSingleTexelAlignment = true
uniformTexelBufferOffsetAlignmentBytes = 0x00000004
uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
maxTransformFeedbackStreams = 4
maxTransformFeedbackBuffers = 4
maxTransformFeedbackBufferSize = 0xffffffff
maxTransformFeedbackStreamDataSize = 512
maxTransformFeedbackBufferDataSize = 512
maxTransformFeedbackBufferDataStride = 512
transformFeedbackQueries = true
transformFeedbackStreamsLinesTriangles = true
transformFeedbackRasterizationStreamSelect = false
transformFeedbackDraw = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
maxVertexAttribDivisor = 4294967295
VkPhysicalDeviceVulkan11Properties:
deviceNodeMask = 0
subgroupSize = 64
subgroupSupportedStages: count = 8
SHADER_STAGE_ALL
subgroupSupportedOperations: count = 8
subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
driverName = radv
framebufferIntegerColorSampleCounts: count = 1
SAMPLE_COUNT_1_BIT
Device Extensions: count = 121
VK_AMD_buffer_marker : extension revision 1
VK_AMD_device_coherent_memory : extension revision 1
VK_AMD_draw_indirect_count : extension revision 2
VK_AMD_gcn_shader : extension revision 1
VK_AMD_memory_overallocation_behavior : extension revision 1
VK_AMD_mixed_attachment_samples : extension revision 1
VK_AMD_rasterization_order : extension revision 1
VK_AMD_shader_ballot : extension revision 1
VK_AMD_shader_core_properties : extension revision 2
VK_AMD_shader_core_properties2 : extension revision 1
VK_AMD_shader_explicit_vertex_parameter : extension revision 1
VK_AMD_shader_fragment_mask : extension revision 1
VK_AMD_shader_image_load_store_lod : extension revision 1
VK_AMD_shader_info : extension revision 1
VK_AMD_shader_trinary_minmax : extension revision 1
VK_AMD_texture_gather_bias_lod : extension revision 1
VK_EXT_4444_formats : extension revision 1
VK_EXT_buffer_device_address : extension revision 2
VK_EXT_calibrated_timestamps : extension revision 2
VK_EXT_color_write_enable : extension revision 1
VK_EXT_conditional_rendering : extension revision 2
VK_EXT_custom_border_color : extension revision 12
VK_EXT_depth_clip_enable : extension revision 1
VK_EXT_depth_range_unrestricted : extension revision 1
VK_EXT_descriptor_indexing : extension revision 2
VK_EXT_discard_rectangles : extension revision 1
VK_EXT_display_control : extension revision 1
VK_EXT_extended_dynamic_state : extension revision 1
VK_EXT_extended_dynamic_state2 : extension revision 1
VK_EXT_external_memory_dma_buf : extension revision 1
VK_EXT_external_memory_host : extension revision 1
VK_EXT_global_priority : extension revision 2
VK_EXT_global_priority_query : extension revision 1
VK_EXT_host_query_reset : extension revision 1
VK_EXT_image_robustness : extension revision 1
VK_EXT_index_type_uint8 : extension revision 1
VK_EXT_inline_uniform_block : extension revision 1
VK_EXT_line_rasterization : extension revision 1
VK_EXT_memory_budget : extension revision 1
VK_EXT_memory_priority : extension revision 1
VK_EXT_multi_draw : extension revision 1
VK_EXT_pci_bus_info : extension revision 2
VK_EXT_physical_device_drm : extension revision 1
VK_EXT_pipeline_creation_cache_control : extension revision 3
VK_EXT_pipeline_creation_feedback : extension revision 1
VK_EXT_private_data : extension revision 1
VK_EXT_provoking_vertex : extension revision 1
VK_EXT_queue_family_foreign : extension revision 1
VK_EXT_robustness2 : extension revision 1
VK_EXT_sample_locations : extension revision 1
VK_EXT_sampler_filter_minmax : extension revision 2
VK_EXT_scalar_block_layout : extension revision 1
VK_EXT_shader_atomic_float : extension revision 1
VK_EXT_shader_demote_to_helper_invocation : extension revision 1
VK_EXT_shader_image_atomic_int64 : extension revision 1
VK_EXT_shader_stencil_export : extension revision 1
VK_EXT_shader_subgroup_ballot : extension revision 1
VK_EXT_shader_subgroup_vote : extension revision 1
VK_EXT_shader_viewport_index_layer : extension revision 1
VK_EXT_subgroup_size_control : extension revision 2
VK_EXT_texel_buffer_alignment : extension revision 1
VK_EXT_transform_feedback : extension revision 1
VK_EXT_vertex_attribute_divisor : extension revision 3
VK_EXT_ycbcr_image_arrays : extension revision 1
VK_GOOGLE_decorate_string : extension revision 1
VK_GOOGLE_hlsl_functionality1 : extension revision 1
VK_GOOGLE_user_type : extension revision 1
VK_KHR_16bit_storage : extension revision 1
VK_KHR_8bit_storage : extension revision 1
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_buffer_device_address : extension revision 1
VK_KHR_copy_commands2 : extension revision 1
VK_KHR_create_renderpass2 : extension revision 1
VK_KHR_dedicated_allocation : extension revision 3
VK_KHR_deferred_host_operations : extension revision 4
VK_KHR_depth_stencil_resolve : extension revision 1
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_device_group : extension revision 4
VK_KHR_draw_indirect_count : extension revision 1
VK_KHR_driver_properties : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_imageless_framebuffer : extension revision 1
VK_KHR_incremental_present : extension revision 2
VK_KHR_maintenance1 : extension revision 2
VK_KHR_maintenance2 : extension revision 1
VK_KHR_maintenance3 : extension revision 1
VK_KHR_multiview : extension revision 1
VK_KHR_pipeline_executable_properties : extension revision 1
VK_KHR_push_descriptor : extension revision 2
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 3
VK_KHR_sampler_ycbcr_conversion : extension revision 14
VK_KHR_separate_depth_stencil_layouts : extension revision 1
VK_KHR_shader_atomic_int64 : extension revision 1
VK_KHR_shader_clock : extension revision 1
VK_KHR_shader_draw_parameters : extension revision 1
VK_KHR_shader_float16_int8 : extension revision 1
VK_KHR_shader_float_controls : extension revision 4
VK_KHR_shader_non_semantic_info : extension revision 1
VK_KHR_shader_subgroup_extended_types : extension revision 1
VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
VK_KHR_shader_terminate_invocation : extension revision 1
VK_KHR_spirv_1_4 : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_swapchain : extension revision 70
VK_KHR_swapchain_mutable_format : extension revision 1
VK_KHR_timeline_semaphore : extension revision 2
VK_KHR_uniform_buffer_standard_layout : extension revision 1
VK_KHR_variable_pointers : extension revision 1
VK_KHR_vulkan_memory_model : extension revision 3
VK_KHR_workgroup_memory_explicit_layout : extension revision 1
VK_KHR_zero_initialize_workgroup_memory : extension revision 1
VK_NV_compute_shader_derivatives : extension revision 1
VK_VALVE_mutable_descriptor_type : extension revision 1
VkQueueFamilyProperties:
queueProperties[0]:
minImageTransferGranularity = (1,1,1)
queueCount = 1
queueFlags = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
timestampValidBits = 64
present support = false
queueProperties[1]:
queueCount = 4
queueFlags = QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 3
memoryHeaps[0]:
size = 8321499136 (0x1f0000000) (7.75 GiB)
budget = 8287051776 (0x1edf26000) (7.72 GiB)
usage = 0 (0x00000000) (0.00 B)
flags: count = 1
MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryHeaps[1]:
size = 8589934592 (0x200000000) (8.00 GiB)
budget = 8569409536 (0x1fec6d000) (7.98 GiB)
flags:
None
memoryHeaps[2]:
size = 268435456 (0x10000000) (256.00 MiB)
budget = 249274368 (0x0edba000) (237.73 MiB)
flags: count = 1
memoryTypes: count = 4
memoryTypes[0]:
heapIndex = 0
propertyFlags = 0x0001: count = 1
MEMORY_PROPERTY_DEVICE_LOCAL_BIT
usable for:
IMAGE_TILING_OPTIMAL:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
FORMAT_D16_UNORM_S8_UINT
FORMAT_D32_SFLOAT_S8_UINT
IMAGE_TILING_LINEAR:
color images
memoryTypes[1]:
heapIndex = 1
propertyFlags = 0x0006: count = 2
MEMORY_PROPERTY_HOST_VISIBLE_BIT
MEMORY_PROPERTY_HOST_COHERENT_BIT
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
memoryTypes[2]:
heapIndex = 2
propertyFlags = 0x0007: count = 3
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
memoryTypes[3]:
heapIndex = 1
propertyFlags = 0x000e: count = 3
MEMORY_PROPERTY_HOST_CACHED_BIT
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
VkPhysicalDeviceFeatures:
robustBufferAccess = true
fullDrawIndexUint32 = true
imageCubeArray = true
independentBlend = true
geometryShader = true
tessellationShader = true
sampleRateShading = true
dualSrcBlend = true
logicOp = true
multiDrawIndirect = true
drawIndirectFirstInstance = true
depthClamp = true
depthBiasClamp = true
fillModeNonSolid = true
depthBounds = true
wideLines = true
largePoints = true
alphaToOne = false
multiViewport = true
samplerAnisotropy = true
textureCompressionETC2 = false
textureCompressionASTC_LDR = false
textureCompressionBC = true
occlusionQueryPrecise = true
pipelineStatisticsQuery = true
vertexPipelineStoresAndAtomics = true
fragmentStoresAndAtomics = true
shaderTessellationAndGeometryPointSize = true
shaderImageGatherExtended = true
shaderStorageImageExtendedFormats = true
shaderStorageImageMultisample = true
shaderStorageImageReadWithoutFormat = true
shaderStorageImageWriteWithoutFormat = true
shaderUniformBufferArrayDynamicIndexing = true
shaderSampledImageArrayDynamicIndexing = true
shaderStorageBufferArrayDynamicIndexing = true
shaderStorageImageArrayDynamicIndexing = true
shaderClipDistance = true
shaderCullDistance = true
shaderFloat64 = true
shaderInt64 = true
shaderInt16 = true
shaderResourceResidency = true
shaderResourceMinLod = true
sparseBinding = true
sparseResidencyBuffer = true
sparseResidencyImage2D = true
sparseResidencyImage3D = false
sparseResidency2Samples = false
sparseResidency4Samples = false
sparseResidency8Samples = false
sparseResidency16Samples = false
sparseResidencyAliased = true
variableMultisampleRate = true
inheritedQueries = true
VkPhysicalDevice16BitStorageFeatures:
storageBuffer16BitAccess = true
uniformAndStorageBuffer16BitAccess = true
storagePushConstant16 = true
storageInputOutput16 = false
VkPhysicalDevice4444FormatsFeaturesEXT:
formatA4R4G4B4 = true
formatA4B4G4R4 = true
VkPhysicalDevice8BitStorageFeatures:
storageBuffer8BitAccess = true
uniformAndStorageBuffer8BitAccess = true
storagePushConstant8 = true
VkPhysicalDeviceBufferDeviceAddressFeatures:
bufferDeviceAddress = true
bufferDeviceAddressCaptureReplay = true
bufferDeviceAddressMultiDevice = false
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
colorWriteEnable = true
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
conditionalRendering = true
inheritedConditionalRendering = false
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
customBorderColors = true
customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
shaderInputAttachmentArrayDynamicIndexing = true
shaderUniformTexelBufferArrayDynamicIndexing = true
shaderStorageTexelBufferArrayDynamicIndexing = true
shaderUniformBufferArrayNonUniformIndexing = true
shaderSampledImageArrayNonUniformIndexing = true
shaderStorageBufferArrayNonUniformIndexing = true
shaderStorageImageArrayNonUniformIndexing = true
shaderInputAttachmentArrayNonUniformIndexing = true
shaderUniformTexelBufferArrayNonUniformIndexing = true
shaderStorageTexelBufferArrayNonUniformIndexing = true
descriptorBindingUniformBufferUpdateAfterBind = true
descriptorBindingSampledImageUpdateAfterBind = true
descriptorBindingStorageImageUpdateAfterBind = true
descriptorBindingStorageBufferUpdateAfterBind = true
descriptorBindingUniformTexelBufferUpdateAfterBind = true
descriptorBindingStorageTexelBufferUpdateAfterBind = true
descriptorBindingUpdateUnusedWhilePending = true
descriptorBindingPartiallyBound = true
descriptorBindingVariableDescriptorCount = true
runtimeDescriptorArray = true
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
extendedDynamicState2 = true
extendedDynamicState2LogicOp = true
extendedDynamicState2PatchControlPoints = false
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
extendedDynamicState = true
VkPhysicalDeviceGlobalPriorityQueryFeaturesEXT:
globalPriorityQuery = true
VkPhysicalDeviceHostQueryResetFeatures:
hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeaturesEXT:
robustImageAccess = true
VkPhysicalDeviceImagelessFramebufferFeatures:
imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
inlineUniformBlock = true
descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
rectangularLines = false
bresenhamLines = true
smoothLines = false
stippledRectangularLines = false
stippledBresenhamLines = true
stippledSmoothLines = false
VkPhysicalDeviceMemoryPriorityFeaturesEXT:
memoryPriority = true
VkPhysicalDeviceMultiDrawFeaturesEXT:
multiDraw = true
VkPhysicalDeviceMultiviewFeatures:
multiview = true
multiviewGeometryShader = true
multiviewTessellationShader = true
VkPhysicalDevicePipelineCreationCacheControlFeaturesEXT:
pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
pipelineExecutableInfo = true
VkPhysicalDevicePrivateDataFeaturesEXT:
privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
provokingVertexLast = true
transformFeedbackPreservesProvokingVertex = true
VkPhysicalDeviceRobustness2FeaturesEXT:
robustBufferAccess2 = true
robustImageAccess2 = true
nullDescriptor = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
shaderBufferFloat32Atomics = true
shaderBufferFloat32AtomicAdd = false
shaderBufferFloat64Atomics = true
shaderBufferFloat64AtomicAdd = false
shaderSharedFloat32Atomics = true
shaderSharedFloat32AtomicAdd = true
shaderSharedFloat64Atomics = true
shaderSharedFloat64AtomicAdd = false
shaderImageFloat32Atomics = true
shaderImageFloat32AtomicAdd = false
sparseImageFloat32Atomics = true
sparseImageFloat32AtomicAdd = false
VkPhysicalDeviceShaderAtomicInt64Features:
shaderBufferInt64Atomics = true
shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
shaderSubgroupClock = true
shaderDeviceClock = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
shaderFloat16 = false
shaderInt8 = true
VkPhysicalDeviceShaderImageAtomicInt64FeaturesEXT:
shaderImageInt64Atomics = true
sparseImageInt64Atomics = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderSubgroupUniformControlFlowFeaturesKHR:
shaderSubgroupUniformControlFlow = true
VkPhysicalDeviceShaderTerminateInvocationFeaturesKHR:
shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
subgroupSizeControl = true
computeFullSubgroups = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeatures:
timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
transformFeedback = true
geometryStreams = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
variablePointersStorageBuffer = true
variablePointers = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
vertexAttributeInstanceRateDivisor = true
vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkan11Features:
multiview = true
VkPhysicalDeviceVulkan12Features:
samplerMirrorClampToEdge = true
drawIndirectCount = true
shaderInt8 = true
descriptorIndexing = true
samplerFilterMinmax = true
vulkanMemoryModel = true
vulkanMemoryModelDeviceScope = true
vulkanMemoryModelAvailabilityVisibilityChains = false
shaderOutputViewportIndex = true
shaderOutputLayer = true
subgroupBroadcastDynamicId = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
workgroupMemoryExplicitLayout = true
workgroupMemoryExplicitLayoutScalarBlockLayout = true
workgroupMemoryExplicitLayout8BitAccess = true
workgroupMemoryExplicitLayout16BitAccess = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
ycbcrImageArrays = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeaturesKHR:
shaderZeroInitializeWorkgroupMemory = true
GPU1:
apiVersion = 4202671 (1.2.175)
driverVersion = 1972355136 (0x758fc040)
vendorID = 0x10de
deviceID = 0x1c82
deviceName = NVIDIA GeForce GTX 1050 Ti
pipelineCacheUUID = 6a8d2dc4-e6c3-d42d-9a13-07c5a0189e52
maxImageDimension1D = 32768
maxImageDimension2D = 32768
maxImageDimension3D = 16384
maxImageDimensionCube = 32768
maxTexelBufferElements = 134217728
maxUniformBufferRange = 65536
maxPushConstantsSize = 256
maxSamplerAllocationCount = 4000
bufferImageGranularity = 0x00000400
sparseAddressSpaceSize = 0xffffffffff
maxPerStageDescriptorSamplers = 1048576
maxPerStageDescriptorUniformBuffers = 15
maxPerStageDescriptorStorageBuffers = 1048576
maxPerStageDescriptorSampledImages = 1048576
maxPerStageDescriptorStorageImages = 1048576
maxPerStageDescriptorInputAttachments = 1048576
maxPerStageResources = 4294967295
maxDescriptorSetSamplers = 1048576
maxDescriptorSetUniformBuffers = 90
maxDescriptorSetUniformBuffersDynamic = 15
maxDescriptorSetStorageBuffers = 1048576
maxDescriptorSetStorageBuffersDynamic = 16
maxDescriptorSetSampledImages = 1048576
maxDescriptorSetStorageImages = 1048576
maxDescriptorSetInputAttachments = 1048576
maxVertexInputAttributeOffset = 2047
maxTessellationControlTotalOutputComponents = 4216
maxGeometryShaderInvocations = 32
maxGeometryInputComponents = 128
maxGeometryOutputVertices = 1024
maxFragmentCombinedOutputResources = 16
maxComputeSharedMemorySize = 49152
2147483647
65535
65535
maxComputeWorkGroupInvocations = 1536
1536
1024
64
maxSamplerLodBias = 15
maxViewports = 16
32768
32768
-65536
65536
minMemoryMapAlignment = 64
minTexelBufferOffsetAlignment = 0x00000010
minUniformBufferOffsetAlignment = 0x00000100
minStorageBufferOffsetAlignment = 0x00000010
minTexelOffset = -8
maxTexelOffset = 7
minInterpolationOffset = -0.5
maxInterpolationOffset = 0.4375
subPixelInterpolationOffsetBits = 4
maxFramebufferWidth = 32768
maxFramebufferHeight = 32768
maxFramebufferLayers = 2048
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferStencilSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
framebufferNoAttachmentsSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageStencilSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
timestampPeriod = 1
1
2047.94
1
64
pointSizeGranularity = 0.0625
lineWidthGranularity = 0.0625
strictLines = true
optimalBufferCopyOffsetAlignment = 0x00000001
optimalBufferCopyRowPitchAlignment = 0x00000001
residencyStandard2DMultisampleBlockShape = true
residencyStandard3DBlockShape = true
VkPhysicalDeviceBlendOperationAdvancedPropertiesEXT:
advancedBlendMaxColorAttachments = 8
advancedBlendIndependentBlend = false
advancedBlendNonPremultipliedSrcColor = true
advancedBlendNonPremultipliedDstColor = true
advancedBlendCorrelatedOverlap = true
advancedBlendAllOperations = true
VkPhysicalDeviceConservativeRasterizationPropertiesEXT:
primitiveOverestimationSize = 0
maxExtraPrimitiveOverestimationSize = 0.75
extraPrimitiveOverestimationSizeGranularity = 0.25
primitiveUnderestimation = false
conservativePointAndLineRasterization = true
degenerateTrianglesRasterized = true
degenerateLinesRasterized = false
fullyCoveredFragmentShaderInputVariable = false
conservativeRasterizationPostDepthCoverage = true
maxCustomBorderColorSamplers = 4000
maxUpdateAfterBindDescriptorsInAllPools = 4294967295
shaderUniformBufferArrayNonUniformIndexingNative = true
shaderSampledImageArrayNonUniformIndexingNative = true
shaderStorageBufferArrayNonUniformIndexingNative = true
shaderStorageImageArrayNonUniformIndexingNative = true
shaderInputAttachmentArrayNonUniformIndexingNative = true
quadDivergentImplicitLod = true
maxPerStageDescriptorUpdateAfterBindSamplers = 1048576
maxPerStageDescriptorUpdateAfterBindUniformBuffers = 15
maxPerStageDescriptorUpdateAfterBindStorageBuffers = 1048576
maxPerStageDescriptorUpdateAfterBindSampledImages = 1048576
maxPerStageDescriptorUpdateAfterBindStorageImages = 1048576
maxPerStageDescriptorUpdateAfterBindInputAttachments = 1048576
maxPerStageUpdateAfterBindResources = 4294967295
maxDescriptorSetUpdateAfterBindSamplers = 1048576
maxDescriptorSetUpdateAfterBindUniformBuffers = 90
maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 15
maxDescriptorSetUpdateAfterBindStorageBuffers = 1048576
maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 16
maxDescriptorSetUpdateAfterBindSampledImages = 1048576
maxDescriptorSetUpdateAfterBindStorageImages = 1048576
maxDescriptorSetUpdateAfterBindInputAttachments = 1048576
maxDiscardRectangles = 8
driverID = DRIVER_ID_NVIDIA_PROPRIETARY
driverName = NVIDIA
driverInfo = 470.63.01
conformanceVersion = 1.2.6.0
hasPrimary = true
hasRender = true
primaryMajor = 226
primaryMinor = 0
renderMajor = 226
renderMinor = 128
shaderSignedZeroInfNanPreserveFloat16 = true
shaderDenormPreserveFloat16 = true
shaderDenormPreserveFloat32 = false
shaderDenormPreserveFloat64 = false
shaderDenormFlushToZeroFloat32 = false
shaderDenormFlushToZeroFloat64 = false
shaderRoundingModeRTEFloat16 = true
deviceUUID = 0349def6-777d-b3dd-ad68-71f0fb99139c
driverUUID = 9a1307c5-a018-9e52-8ced-e0ca9de9bb38
deviceNodeMask = 1
maxInlineUniformBlockSize = 256
maxPerStageDescriptorInlineUniformBlocks = 32
maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 32
maxDescriptorSetInlineUniformBlocks = 32
maxDescriptorSetUpdateAfterBindInlineUniformBlocks = 32
lineSubPixelPrecisionBits = 8
maxPerSetDescriptors = 4294967295
maxMemoryAllocationSize = 0xffe00000
maxMultiviewViewCount = 32
maxMultiviewInstanceIndex = 134217727
pciDomain = 0
pciBus = 4
pciDevice = 0
pciFunction = 0
pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
robustStorageBufferAccessSizeAlignment = 0x00000001
robustUniformBufferAccessSizeAlignment = 0x00000100
sampleLocationSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
width = 1
height = 1
0
0.9375
variableSampleLocations = true
filterMinmaxImageComponentMapping = true
subgroupSize = 32
SHADER_STAGE_ALL
supportedOperations: count = 9
SUBGROUP_FEATURE_PARTITIONED_BIT_NV
minSubgroupSize = 32
maxSubgroupSize = 32
maxComputeWorkgroupSubgroups = 3145728
requiredSubgroupSizeStages: count = 8
SHADER_STAGE_ALL
storageTexelBufferOffsetAlignmentBytes = 0x00000010
uniformTexelBufferOffsetAlignmentBytes = 0x00000010
maxTimelineSemaphoreValueDifference = 2147483647
maxTransformFeedbackBufferSize = 0xffffffffffffffff
maxTransformFeedbackStreamDataSize = 2048
maxTransformFeedbackBufferDataStride = 2048
transformFeedbackStreamsLinesTriangles = false
transformFeedbackRasterizationStreamSelect = true
deviceNodeMask = 1
subgroupSize = 32
SHADER_STAGE_ALL
subgroupSupportedOperations: count = 9
driverName = NVIDIA
framebufferIntegerColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
Device Extensions: count = 119
VK_EXT_blend_operation_advanced : extension revision 2
VK_EXT_calibrated_timestamps : extension revision 1
VK_EXT_conservative_rasterization : extension revision 1
VK_EXT_fragment_shader_interlock : extension revision 1
VK_EXT_post_depth_coverage : extension revision 1
VK_EXT_separate_stencil_usage : extension revision 1
VK_EXT_tooling_info : extension revision 1
VK_EXT_vertex_input_dynamic_state : extension revision 2
VK_KHR_synchronization2 : extension revision 1
VK_NVX_multiview_per_view_attributes : extension revision 1
VK_NV_clip_space_w_scaling : extension revision 1
VK_NV_coverage_reduction_mode : extension revision 1
VK_NV_dedicated_allocation : extension revision 1
VK_NV_dedicated_allocation_image_aliasing : extension revision 1
VK_NV_device_diagnostic_checkpoints : extension revision 2
VK_NV_device_diagnostics_config : extension revision 1
VK_NV_device_generated_commands : extension revision 3
VK_NV_fill_rectangle : extension revision 1
VK_NV_fragment_coverage_to_color : extension revision 1
VK_NV_framebuffer_mixed_samples : extension revision 1
VK_NV_geometry_shader_passthrough : extension revision 1
VK_NV_inherited_viewport_scissor : extension revision 1
VK_NV_sample_mask_override_coverage : extension revision 1
VK_NV_shader_sm_builtins : extension revision 1
VK_NV_shader_subgroup_partitioned : extension revision 1
VK_NV_viewport_array2 : extension revision 1
VK_NV_viewport_swizzle : extension revision 1
queueProperties[0]:
queueCount = 16
present support = true
queueProperties[1]:
queueCount = 2
queueFlags = QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
queueProperties[2]:
queueCount = 8
memoryHeaps[0]:
size = 4294967296 (0x100000000) (4.00 GiB)
budget = 3727228928 (0xde290000) (3.47 GiB)
flags: count = 1
memoryHeaps[1]:
size = 101258139648 (0x1793749800) (94.30 GiB)
budget = 101258139648 (0x1793749800) (94.30 GiB)
flags:
None
memoryHeaps[2]:
size = 257949696 (0x0f600000) (246.00 MiB)
budget = 250544128 (0x0eef0000) (238.94 MiB)
usage = 7405568 (0x00710000) (7.06 MiB)
flags: count = 1
memoryTypes: count = 11
memoryTypes[0]:
heapIndex = 1
propertyFlags = 0x0000:
None
usable for:
None
color images
(non-sparse, non-transient)
memoryTypes[1]:
heapIndex = 1
None
usable for:
color images
(non-sparse)
None
memoryTypes[2]:
heapIndex = 1
None
usable for:
FORMAT_D16_UNORM
None
memoryTypes[3]:
heapIndex = 1
None
usable for:
FORMAT_X8_D24_UNORM_PACK32
FORMAT_D24_UNORM_S8_UINT
None
memoryTypes[4]:
heapIndex = 1
None
usable for:
FORMAT_D32_SFLOAT
None
memoryTypes[5]:
heapIndex = 1
None
usable for:
None
memoryTypes[6]:
heapIndex = 1
None
usable for:
FORMAT_S8_UINT
None
memoryTypes[7]:
heapIndex = 0
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
color images
memoryTypes[8]:
heapIndex = 1
usable for:
None
color images
memoryTypes[9]:
heapIndex = 1
usable for:
None
color images
memoryTypes[10]:
heapIndex = 2
usable for:
None
color images
dualSrcBlend = true
logicOp = true
depthClamp = true
depthBounds = true
wideLines = true
largePoints = true
alphaToOne = true
shaderInt64 = true
shaderInt16 = true
sparseResidencyImage3D = true
sparseResidency2Samples = true
sparseResidency4Samples = true
sparseResidency8Samples = true
sparseResidency16Samples = true
VkPhysicalDeviceBlendOperationAdvancedFeaturesEXT:
advancedBlendCoherentOperations = true
bufferDeviceAddressCaptureReplay = false
bufferDeviceAddressMultiDevice = true
inheritedConditionalRendering = true
descriptorBindingUniformBufferUpdateAfterBind = false
extendedDynamicState2PatchControlPoints = true
VkPhysicalDeviceFragmentShaderInterlockFeaturesEXT:
fragmentShaderSampleInterlock = true
fragmentShaderPixelInterlock = true
fragmentShaderShadingRateInterlock = true
rectangularLines = true
smoothLines = true
stippledRectangularLines = true
stippledSmoothLines = true
multiview = true
privateData = true
shaderBufferFloat32AtomicAdd = true
shaderBufferFloat64AtomicAdd = true
shaderSharedFloat64AtomicAdd = true
shaderImageFloat32AtomicAdd = true
sparseImageFloat32AtomicAdd = true
shaderInt8 = true
VkPhysicalDeviceSynchronization2FeaturesKHR:
synchronization2 = true
VkPhysicalDeviceVertexInputDynamicStateFeaturesEXT:
vertexInputDynamicState = true
multiview = true
shaderInt8 = true
vulkanMemoryModelAvailabilityVisibilityChains = true
output of glxinfo
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_libglvnd,
GLX_EXT_stereo_tree, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_NV_copy_image, GLX_NV_delay_before_swap, GLX_NV_float_buffer,
GLX_NV_multigpu_context, GLX_NV_robustness_video_memory_purge,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_swap_control,
GLX_SGI_video_sync
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_stereo_tree, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_copy_buffer,
GLX_NV_multigpu_context, GLX_NV_multisample_coverage,
GLX_NV_robustness_video_memory_purge, GLX_NV_swap_group,
GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_stereo_tree,
GLX_SGI_video_sync
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 4096 MB
Total available memory: 4096 MB
Currently available dedicated video memory: 3545 MB
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 470.63.01
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_multi_draw_indirect, GL_AMD_seamless_cubemap_per_texture,
GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
GL_ARB_ES3_2_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_bindless_texture,
GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_compute_shader, GL_ARB_compute_variable_group_size,
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_ARB_direct_state_access, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_fragment_shader_interlock,
GL_ARB_framebuffer_no_attachments, GL_ARB_framebuffer_object,
GL_ARB_framebuffer_sRGB, GL_ARB_geometry_shader4,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image, GL_ARB_gl_spirv,
GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex, GL_ARB_imaging,
GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_occlusion_query2, GL_ARB_parallel_shader_compile,
GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
GL_ARB_post_depth_coverage, GL_ARB_program_interface_query,
GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
GL_ARB_sample_locations, GL_ARB_sample_shading, GL_ARB_sampler_objects,
GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,
GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops,
GL_ARB_shader_atomic_counters, GL_ARB_shader_ballot,
GL_ARB_shader_bit_encoding, GL_ARB_shader_clock,
GL_ARB_shader_draw_parameters, GL_ARB_shader_group_vote,
GL_ARB_shader_image_load_store, GL_ARB_shader_image_size,
GL_ARB_shader_objects, GL_ARB_shader_precision,
GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine,
GL_ARB_shader_texture_image_samples, GL_ARB_shader_texture_lod,
GL_ARB_shader_viewport_layer_array, GL_ARB_shading_language_100,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_sparse_buffer,
GL_ARB_sparse_texture, GL_ARB_sparse_texture2,
GL_ARB_sparse_texture_clamp, GL_ARB_spirv_extensions,
GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader,
GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
GL_ARB_texture_buffer_range, GL_ARB_texture_compression,
GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_filter_anisotropic, GL_ARB_texture_filter_minmax,
GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
GL_ARB_texture_stencil8, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_64bit,
GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_draw_buffers,
GL_ATI_texture_float, GL_ATI_texture_mirror_once,
GL_EXTX_framebuffer_mixed_formats, GL_EXT_Cg_shader, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_bindable_uniform, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_depth_bounds_test, GL_EXT_direct_state_access,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
GL_EXT_framebuffer_sRGB, GL_EXT_geometry_shader4,
GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
GL_EXT_import_sync_object, GL_EXT_memory_object, GL_EXT_memory_object_fd,
GL_EXT_multi_draw_arrays, GL_EXT_multiview_texture_multisample,
GL_EXT_multiview_timer_query, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp,
GL_EXT_post_depth_coverage, GL_EXT_provoking_vertex,
GL_EXT_raster_multisample, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_semaphore, GL_EXT_semaphore_fd, GL_EXT_separate_shader_objects,
GL_EXT_separate_specular_color, GL_EXT_shader_image_load_formatted,
GL_EXT_shader_image_load_store, GL_EXT_shader_integer_mix,
GL_EXT_shadow_funcs, GL_EXT_sparse_texture2, GL_EXT_stencil_two_side,
GL_EXT_stencil_wrap, GL_EXT_texture3D, GL_EXT_texture_array,
GL_EXT_texture_buffer_object, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_filter_minmax,
GL_EXT_texture_integer, GL_EXT_texture_lod, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_R8, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shadow_lod, GL_EXT_texture_shared_exponent,
GL_EXT_texture_storage, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback2, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_EXT_vertex_attrib_64bit, GL_EXT_window_rectangles,
GL_EXT_x11_sync_object, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_KHR_blend_equation_advanced,
GL_KHR_blend_equation_advanced_coherent, GL_KHR_context_flush_control,
GL_KHR_debug, GL_KHR_no_error, GL_KHR_parallel_shader_compile,
GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
GL_KHR_shader_subgroup, GL_KTX_buffer_region,
GL_NVX_blend_equation_advanced_multi_draw_buffers,
GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop,
GL_NVX_progress_fence, GL_NV_ES1_1_compatibility,
GL_NV_ES3_1_compatibility, GL_NV_alpha_to_coverage_dither_control,
GL_NV_bindless_multi_draw_indirect,
GL_NV_bindless_multi_draw_indirect_count, GL_NV_bindless_texture,
GL_NV_blend_equation_advanced, GL_NV_blend_equation_advanced_coherent,
GL_NV_blend_minmax_factor, GL_NV_blend_square, GL_NV_clip_space_w_scaling,
GL_NV_command_list, GL_NV_compute_program5, GL_NV_conditional_render,
GL_NV_conservative_raster, GL_NV_conservative_raster_dilate,
GL_NV_conservative_raster_pre_snap_triangles, GL_NV_copy_depth_to_color,
GL_NV_copy_image, GL_NV_depth_buffer_float, GL_NV_depth_clamp,
GL_NV_draw_texture, GL_NV_draw_vulkan_image, GL_NV_explicit_multisample,
GL_NV_feature_query, GL_NV_fence, GL_NV_fill_rectangle,
GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_coverage_to_color,
GL_NV_fragment_program, GL_NV_fragment_program2,
GL_NV_fragment_program_option, GL_NV_fragment_shader_interlock,
GL_NV_framebuffer_mixed_samples, GL_NV_framebuffer_multisample_coverage,
GL_NV_geometry_shader4, GL_NV_geometry_shader_passthrough,
GL_NV_gpu_multicast, GL_NV_gpu_program4, GL_NV_gpu_program4_1,
GL_NV_gpu_program5, GL_NV_gpu_program5_mem_extended,
GL_NV_gpu_program_fp64, GL_NV_gpu_shader5, GL_NV_half_float,
GL_NV_internalformat_sample_query, GL_NV_light_max_exponent,
GL_NV_memory_attachment, GL_NV_memory_object_sparse,
GL_NV_multisample_coverage, GL_NV_multisample_filter_hint,
GL_NV_occlusion_query, GL_NV_packed_depth_stencil,
GL_NV_parameter_buffer_object, GL_NV_parameter_buffer_object2,
GL_NV_path_rendering, GL_NV_path_rendering_shared_edge,
GL_NV_pixel_data_range, GL_NV_point_sprite, GL_NV_primitive_restart,
GL_NV_query_resource, GL_NV_query_resource_tag, GL_NV_register_combiners,
GL_NV_register_combiners2, GL_NV_robustness_video_memory_purge,
GL_NV_sample_locations, GL_NV_sample_mask_override_coverage,
GL_NV_shader_atomic_counters, GL_NV_shader_atomic_float,
GL_NV_shader_atomic_float64, GL_NV_shader_atomic_fp16_vector,
GL_NV_shader_atomic_int64, GL_NV_shader_buffer_load,
GL_NV_shader_storage_buffer_object, GL_NV_shader_subgroup_partitioned,
GL_NV_shader_thread_group, GL_NV_shader_thread_shuffle,
GL_NV_stereo_view_rendering, GL_NV_texgen_reflection,
GL_NV_texture_barrier, GL_NV_texture_compression_vtc,
GL_NV_texture_env_combine4, GL_NV_texture_multisample,
GL_NV_texture_rectangle, GL_NV_texture_rectangle_compressed,
GL_NV_texture_shader, GL_NV_texture_shader2, GL_NV_texture_shader3,
GL_NV_timeline_semaphore, GL_NV_transform_feedback,
GL_NV_transform_feedback2, GL_NV_uniform_buffer_unified_memory,
GL_NV_vdpau_interop, GL_NV_vdpau_interop2, GL_NV_vertex_array_range,
GL_NV_vertex_array_range2, GL_NV_vertex_attrib_integer_64bit,
GL_NV_vertex_buffer_unified_memory, GL_NV_vertex_program,
GL_NV_vertex_program1_1, GL_NV_vertex_program2,
GL_NV_vertex_program2_option, GL_NV_vertex_program3,
GL_NV_viewport_array2, GL_NV_viewport_swizzle, GL_OVR_multiview,
GL_OVR_multiview2, GL_S3_s3tc, GL_SGIS_generate_mipmap,
GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SGIX_shadow,
GL_SUN_slice_accum
OpenGL version string: 4.6.0 NVIDIA 470.63.01
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
GL_ARB_color_buffer_float, GL_ARB_compatibility,
GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
GL_ARB_compute_variable_group_size, GL_ARB_conditional_render_inverted,
GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_SUN_slice_accum
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 470.63.01
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
GL_ANDROID_extension_pack_es31a, GL_EXT_EGL_image_external_wrap_modes,
GL_EXT_base_instance, GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
GL_EXT_buffer_storage, GL_EXT_clear_texture, GL_EXT_clip_control,
GL_EXT_clip_cull_distance, GL_EXT_color_buffer_float,
GL_EXT_color_buffer_half_float, GL_EXT_compressed_ETC1_RGB8_sub_texture,
GL_EXT_conservative_depth, GL_EXT_copy_image, GL_EXT_debug_label,
GL_EXT_depth_clamp, GL_EXT_discard_framebuffer,
GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers_indexed,
GL_EXT_draw_elements_base_vertex, GL_EXT_draw_transform_feedback,
GL_EXT_float_blend, GL_EXT_frag_depth, GL_EXT_geometry_point_size,
GL_EXT_geometry_shader, GL_EXT_gpu_shader5, GL_EXT_map_buffer_range,
GL_EXT_memory_object, GL_EXT_memory_object_fd, GL_EXT_multi_draw_indirect,
GL_EXT_multisample_compatibility, GL_EXT_multisampled_render_to_texture,
GL_EXT_multisampled_render_to_texture2,
GL_EXT_multiview_texture_multisample, GL_EXT_multiview_timer_query,
GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
GL_EXT_post_depth_coverage, GL_EXT_primitive_bounding_box,
GL_EXT_raster_multisample, GL_EXT_render_snorm, GL_EXT_robustness,
GL_EXT_sRGB, GL_EXT_sRGB_write_control, GL_EXT_semaphore,
GL_EXT_shader_group_vote, GL_EXT_shader_implicit_conversions,
GL_EXT_shader_integer_mix, GL_EXT_shader_io_blocks,
GL_EXT_shader_non_constant_global_initializers, GL_EXT_shader_texture_lod,
GL_EXT_shadow_samplers, GL_EXT_sparse_texture, GL_EXT_sparse_texture2,
GL_EXT_tessellation_point_size, GL_EXT_tessellation_shader,
GL_EXT_texture_border_clamp, GL_EXT_texture_buffer,
GL_EXT_texture_compression_bptc, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map_array, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_filter_minmax, GL_EXT_texture_format_BGRA8888,
GL_EXT_texture_mirror_clamp_to_edge, GL_EXT_texture_norm16,
GL_EXT_texture_query_lod, GL_EXT_texture_rg, GL_EXT_texture_sRGB_R8,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shadow_lod,
GL_EXT_texture_storage, GL_EXT_texture_view, GL_EXT_unpack_subimage,
GL_EXT_window_rectangles, GL_KHR_blend_equation_advanced,
GL_KHR_shader_subgroup, GL_KHR_texture_compression_astc_hdr,
GL_KHR_texture_compression_astc_ldr,
GL_KHR_texture_compression_astc_sliced_3d,
GL_NVX_blend_equation_advanced_multi_draw_buffers, GL_NV_bgr,
GL_NV_bindless_texture, GL_NV_blend_equation_advanced,
GL_NV_blend_equation_advanced_coherent, GL_NV_blend_minmax_factor,
GL_NV_clip_space_w_scaling, GL_NV_conditional_render,
GL_NV_conservative_raster, GL_NV_conservative_raster_pre_snap_triangles,
GL_NV_copy_buffer, GL_NV_copy_image, GL_NV_draw_buffers,
GL_NV_draw_instanced, GL_NV_draw_texture, GL_NV_draw_vulkan_image,
GL_NV_explicit_attrib_location, GL_NV_fbo_color_attachments,
GL_NV_fill_rectangle, GL_NV_fragment_coverage_to_color,
GL_NV_fragment_shader_interlock, GL_NV_framebuffer_blit,
GL_NV_framebuffer_mixed_samples, GL_NV_framebuffer_multisample,
GL_NV_generate_mipmap_sRGB, GL_NV_geometry_shader_passthrough,
GL_NV_gpu_shader5, GL_NV_image_formats, GL_NV_instanced_arrays,
GL_NV_internalformat_sample_query, GL_NV_memory_attachment,
GL_NV_memory_object_sparse, GL_NV_non_square_matrices,
GL_NV_occlusion_query_samples, GL_NV_pack_subimage, GL_NV_packed_float,
GL_NV_packed_float_linear, GL_NV_path_rendering,
GL_NV_path_rendering_shared_edge, GL_NV_pixel_buffer_object,
GL_NV_polygon_mode, GL_NV_read_buffer, GL_NV_read_depth,
GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_NV_sRGB_formats,
GL_NV_shader_atomic_fp16_vector, GL_NV_shader_noperspective_interpolation,
GL_NV_shader_subgroup_partitioned, GL_NV_shadow_samplers_array,
GL_NV_shadow_samplers_cube, GL_NV_stereo_view_rendering,
GL_NV_texture_array, GL_NV_texture_barrier, GL_NV_texture_border_clamp,
GL_NV_texture_compression_latc, GL_NV_texture_compression_s3tc,
GL_NV_texture_compression_s3tc_update, GL_NV_timeline_semaphore,
GL_NV_timer_query, GL_NV_viewport_array, GL_NV_viewport_array2,
GL_NV_viewport_swizzle, GL_OES_compressed_ETC1_RGB8_texture,
GL_OES_copy_image, GL_OES_depth24, GL_OES_depth32, GL_OES_depth_texture,
GL_OES_depth_texture_cube_map, GL_OES_draw_buffers_indexed,
GL_OES_draw_elements_base_vertex, GL_OES_element_index_uint,
GL_OES_fbo_render_mipmap, GL_OES_geometry_point_size,
GL_OES_geometry_shader, GL_OES_get_program_binary, GL_OES_gpu_shader5,
GL_OES_mapbuffer, GL_OES_packed_depth_stencil,
GL_OES_primitive_bounding_box, GL_OES_rgb8_rgba8, GL_OES_sample_shading,
GL_OES_sample_variables, GL_OES_shader_image_atomic,
GL_OES_shader_io_blocks, GL_OES_shader_multisample_interpolation,
GL_OES_standard_derivatives, GL_OES_tessellation_point_size,
GL_OES_tessellation_shader, GL_OES_texture_border_clamp,
GL_OES_texture_buffer, GL_OES_texture_cube_map_array,
GL_OES_texture_float, GL_OES_texture_float_linear,
GL_OES_texture_half_float, GL_OES_texture_half_float_linear,
GL_OES_texture_npot, GL_OES_texture_stencil8,
GL_OES_texture_storage_multisample_2d_array, GL_OES_texture_view,
GL_OES_vertex_array_object, GL_OES_vertex_half_float,
GL_OES_viewport_array, GL_OVR_multiview, GL_OVR_multiview2,
GL_OVR_multiview_multisampled_render_to_texture
132 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
output of inxi -xxxv8
System: Host: grayson-hpz420-blazeit Kernel: 5.13.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=49a7cc79-374d-4ee5-9db8-c1d594744f7b rw quiet
cryptdevice=UUID=d93f18c7-bfc0-4a67-b16a-77309a6c87fe:luks-d93f18c7-bfc0-4a67-b16a-77309a6c87fe
root=/dev/mapper/luks-d93f18c7-bfc0-4a67-b16a-77309a6c87fe apparmor=1 security=apparmor
resume=/dev/mapper/luks-f517a028-05f4-4f68-8493-568853f36d95 udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop System: Hewlett-Packard product: HP Z420 Workstation v: N/A serial: <superuser required> Chassis:
type: 6 serial: <superuser required>
Mobo: Hewlett-Packard model: 1589 v: 0.00 serial: <superuser required> UEFI: Hewlett-Packard v: J61 v03.69
date: 03/25/2014
Battery: Message: No system battery data found. Is one present?
Memory: RAM: total: 125.74 GiB used: 2.52 GiB (2.0%)
PCI Slots: Permissions: Unable to run dmidecode. Root privileges required.
CPU: Info: 6-Core model: Intel Xeon E5-1650 v2 bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3E (62)
stepping: 4 microcode: 42E cache: L2: 12 MiB bogomips: 83835
Speed: 1903 MHz min/max: 1200/3900 MHz Core speeds (MHz): 1: 1903 2: 2085 3: 3031 4: 3493 5: 1875 6: 1944 7: 3492
8: 3492 9: 3166 10: 1509 11: 2252 12: 2344
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 dca
de ds_cpl dtes64 dtherm dts epb ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm
lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: eVga.com. driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 04:00.0 chip-ID: 10de:1c82 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus-ID: 05:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 90 s-size: 474x303mm (18.7x11.9") s-diag: 563mm (22.1")
Monitor-1: HDMI-0 res: 1680x1050 hz: 60 dpi: 90 size: 473x296mm (18.6x11.7") diag: 558mm (22")
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Audio: Device-1: Intel C600/X79 series High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1d20 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus-ID: 04:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Device-3: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Sapphire Limited driver: snd_hda_intel
v: kernel bus-ID: 05:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.13.15-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Network: Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard driver: e1000e v: kernel port: f040 bus-ID: 00:19.0
chip-ID: 8086:1502 class-ID: 0200
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: a0:d3:c1:0c:0b:a1
IP v4: 10.8.101.210/24 type: dynamic noprefixroute scope: global broadcast: 10.8.101.255
IP v6: fe80::2fa6:d746:ac91:6e22/64 type: noprefixroute scope: link
WAN IP: 47.33.172.169
Bluetooth: Message: No bluetooth data found.
Logical: Message: No logical block device data found.
Device-1: luks-d93f18c7-bfc0-4a67-b16a-77309a6c87fe maj-min: 254:0 type: LUKS dm: dm-0 size: 3.5 TiB
Components:
p-1: sdc2 maj-min: 8:34 size: 3.5 TiB
Device-2: luks-f517a028-05f4-4f68-8493-568853f36d95 maj-min: 254:1 type: LUKS dm: dm-1 size: 138.31 GiB
Components:
p-1: sdc3 maj-min: 8:35 size: 138.31 GiB
RAID: Message: No RAID data found.
Drives: Local Storage: total: 9.78 TiB used: 12.17 GiB (0.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HUP722020APA330 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: BFG8VPGF rev: A36C scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ABD075 size: 698.64 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: 15AMW063T rev: 2C scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD40EZAZ-00SF3B0 size: 3.64 TiB block-size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: WD-WX32DC0HKCF0 rev: 0A80 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: 86SSTEW1T rev: 3D scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: <unknown> type: HDD rpm: 5400 serial: 78THTVV6T rev: 1D scheme: GPT
ID-6: /dev/sdf maj-min: 8:80 vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: <unknown> type: HDD rpm: 5400 serial: 55KMW4F0T rev: 1A scheme: GPT
ID-7: /dev/sdg maj-min: 8:96 vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: <unknown> type: HDD rpm: 5400 serial: 25DXTGI1T rev: 2J scheme: GPT
Partition: ID-1: / raw-size: 3.5 TiB size: 3.45 TiB (98.40%) used: 12.17 GiB (0.3%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-d93f18c7-bfc0-4a67-b16a-77309a6c87fe label: N/A uuid: 49a7cc79-374d-4ee5-9db8-c1d594744f7b
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 440 KiB (0.1%) fs: vfat dev: /dev/sdc1
maj-min: 8:33 label: NO_LABEL uuid: 7B75-89C3
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 138.31 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-f517a028-05f4-4f68-8493-568853f36d95 label: swap uuid: c0e81836-21a7-41e0-9e37-8ec4440d1e33
Unmounted: ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ext4 label: N/A uuid: 957a03eb-8194-46bb-8b19-8ee4e72096ba
ID-2: /dev/sdb1 maj-min: 8:17 size: 698.64 GiB fs: vfat label: N/A uuid: 4F45-F319
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:0024
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:0024
Device-1: 2-1.1:3 info: Razer USA DeathAdder Elite type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1532:005c class-ID: 0300
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 3-2:2 info: Valve Wireless Steam Controller type: Keyboard,HID driver: hid-steam,usbhid interfaces: 5
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 28de:1142 class-ID: 0300
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors: System Temperatures: cpu: 23.0 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 32 C fan: 35% device: amdgpu temp: 34.0 C watts: 33.06
Repos: Packages: pacman: 1211 lib: 331 flatpak: 0
1: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
2: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
3: https://manjaro.osmir.ch/stable/$repo/$arch
Processes: CPU top: 5 of 309
1: cpu: 9.3% command: firefox pid: 1648 mem: 414.5 MiB (0.3%)
2: cpu: 5.0% command: plasma-systemmonitor pid: 2013 mem: 171.2 MiB (0.1%)
3: cpu: 4.2% command: firefox pid: 1978 mem: 203.7 MiB (0.1%)
4: cpu: 2.4% command: kwin_x11 pid: 1342 mem: 118.4 MiB (0.0%)
5: cpu: 2.2% command: xorg pid: 835 mem: 135.3 MiB (0.1%)
Memory top: 5 of 309
1: mem: 414.5 MiB (0.3%) command: firefox pid: 1648 cpu: 9.3%
2: mem: 268.1 MiB (0.2%) command: plasmashell pid: 1402 cpu: 1.4%
3: mem: 203.7 MiB (0.1%) command: firefox pid: 1978 cpu: 4.2%
4: mem: 171.2 MiB (0.1%) command: plasma-systemmonitor pid: 2013 cpu: 5.0%
5: mem: 135.3 MiB (0.1%) command: xorg pid: 835 cpu: 2.2%
Info: Processes: 309 Uptime: 11m wakeups: 0 Init: systemd v: 249 tool: systemctl Compilers: gcc: N/A Shell: Zsh v: 5.8
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
