I have reverted to before the updates with timeshift, where rustdesk still works. And there libcuda.so.1 is also not loaded, so that does not seem to be the problem.
To clarify ‘rustdesk will not run’: it does run but without a window, only an icon on the taskbar.
Comparing the ‘before’ and ‘after’ the difference in the debug log seems to be:
** (rustdesk:31592): WARNING **: 20:57:44.043: Failed to initialize GLArea: No available configurations for the given pixel format
So the requested debug log (after the update):
Cannot load libcuda.so.1
(rustdesk:31592): Gdk-CRITICAL **: 20:57:44.043: gdk_gl_context_make_current: assertion 'GDK_IS_GL_CONTEXT (context)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.038: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.046: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.054: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.062: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.070: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.078: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.086: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.094: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.105: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.110: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.118: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.126: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.134: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.142: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.150: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.158: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.168: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.174: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.182: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.190: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.198: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.206: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.214: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.222: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.230: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.238: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.246: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.254: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
** (rustdesk:31592): CRITICAL **: 20:57:51.262: void fl_keyboard_manager_sync_modifier_if_needed(FlKeyboardManager *, guint, double): assertion 'FL_IS_KEYBOARD_MANAGER(self)' failed
(rustdesk:31592): Gdk-CRITICAL **: 20:57:53.940: gdk_gl_context_make_current: assertion 'GDK_IS_GL_CONTEXT (context)' failed
** (rustdesk:31592): WARNING **: 20:57:53.940: Failed to uninitialize GLArea: No available configurations for the given pixel format
** (rustdesk:31592): WARNING **: 20:57:53.940: Attempted to set message handler on an FlBinaryMessenger without an engine
Try setting transparent
All those ‘void fl_keyboard_manager_sync_modifier_if_ etc’ show up when I try to close the app on the taskbar so probably not relevant?
❯ pacman -Qi rustdesk
Version : 1.5.3-1
Description : Yet another remote desktop software, written in Rust. Works out of the box, no configuration required.
Architecture : x86_64
URL : https://github.com/rustdesk/rustdesk
Licenses : AGPL-3.0-only
Groups : None
Provides : rustdesk
Depends On : gtk3 xdotool libxcb libxfixes libpulse libva libvdpau pam gst-plugins-base gst-plugin-pipewire
Optional Deps : libappindicator-gtk3: tray icon [installed]
libayatana-appindicator: tray icon [installed]
Required By : None
Optional For : None
Conflicts With : rustdesk
Replaces : None
Installed Size : 84,28 MiB
Packager : Unknown Packager
Build Date : vr 20 nov 2026 13:53:26 CET
Install Date : vr 20 nov 2026 17:12:25 CET
Install Reason : Explicitly installed
Install Script : Yes
Validated By : None
❯ pacman -Q | grep -Ei 'rustdesk|nvidia|cuda|gstreamer|gtk|fontconfig'
breeze-gtk 6.8.3-1
fontconfig 2:2.18.4-1
gst-plugin-gtk 1.28.9-3
gst-plugin-gtk4 0.15.4-2
gstreamer 1.28.9-3
gtk-layer-shell 0.10.1-1
gtk-update-icon-cache 1:4.24.1-1
gtk3 1:3.24.52-2
gtk4 1:4.24.1-1
gtkmm3 3.24.11-1
gtksourceview3 1:3.24.11+r30+gd880929f-1
gtksourceview4 4.8.4-2
kde-gtk-config 6.8.3-1
lib32-fontconfig 2:2.18.4-1
lib32-gtk3 1:3.24.52-2
libdbusmenu-gtk3 18.10.20180917-2
libnma-gtk4 1.10.6-3
libportal-gtk3 0.11.0-1
libportal-gtk4 0.11.0-1
mhwd-nvidia 620.73.04-1
mhwd-nvidia-390xx 390.157-34
mhwd-nvidia-470xx 470.256.02-23
mhwd-nvidia-580xx 580.196.07-3
nvidia-driver-assistant 0.23.48.01-7
pamac-gtk3 10.7.0-1
perl-gtk3 0.038-5
perl-gtk3-imageview 12-1
perl-gtk3-simplelist 0.21-2
rustdesk-bin 1.5.3-1
webkit2gtk-4.1 2.54.2-1
wxwidgets-gtk3 3.2.12-1
xdg-desktop-portal-gtk 1.15.3-2
