I’m trying to compile and run aldo on my Pinebook Pro. Everything worked well on my ARM64 Pinephone under Mobian OS, but I’m getting a runtime error on my Pinebook Pro with Manjaro:
terminate called after throwing an instance of 'libaudiostream::AudioException’
what(): std::exception
Aborted (core dumped)
In the runtime setup menu, I setup aldo to use the default sound device, which is “default”:
Soundcard device name/file [default]:
The default worked under Mobian on my Pinephone.
aldo:
https://www.nongnu.org/aldo/
I’m running the latest stable Manjaro on my Pinebook Pro and it is up to date. Any suggestions are most appreciated.
P.S.
I have libao 1.2.2-5 (required) and alsa-OSS 1.1.8-4
