I have These specifications:
Manjaro sway
CPU: Intel i5-4460 (4) @ 3.400GHz
GPU: Intel HD Graphics
Architecture: 64-bit
Memory: 4GB
wine version: wine-6.8
When i do $ wine setup.exe
it shows this
Runtime Error( at 361:3970): Out of string range.
after pressing ok it shows this
Runtime Error( at 316:415):
Internal Error: An attempt was made to access Wizardform before it has been created
Terminal output:
0104:fixme:win:DisableProcessWindowsGhosting : stub
0104:fixme:graphics:ShutdownBlockReasonDestroy (00010086): stub
0104:fixme:graphics:ShutdownBlockReasonCreate (00010086, L"Installing"): stub
0104:fixme:msg:ChangeWindowMessageFilterEx 00010094 c05e 1 00000000
0104:fixme:msg:ChangeWindowMessageFilterEx 00020094 c05e 1 00000000
0104:fixme:win:WINNLSEnableIME hwnd 000100A2 enable 0: stub!
0104:fixme:win:WINNLSEnableIME hwnd 000100A2 enable -1: stub!
0104:err:module:open_builtin_so_file failed to load .so lib “/usr/lib32/wine/i386-unix/winepulse.drv.so”
ALSA lib dlmisc.c:339:(snd_dlobj_cache_get0) Cannot open shared library libasound_module_pcm_pulse.so (libpulse.so.0: cannot open shared object file: No such file or directory)
0110:fixme:winhttp:request_set_option 0 (null) (null)
0114:err:winediag:gnutls_initialize failed to load libgnutls, no support for encryption
0114:err:winediag:gnutls_initialize failed to load libgnutls, no support for pfx import/export
0114:err:winediag:gnutls_initialize Failed to load libgnutls, secure connections will not be available.
0114:err:secur32:SECUR32_initSchannelSP no schannel support, expect problems
Please help me
