I use a non admin log in most of the time while I learn, code and game. I have tried unsuccessfully to find information about this on DDG and google.
Sometimes I run into some command which requires sudo privileges. I do not know how to give myself temporary sudo privileges so I can run the command then step the privilege back down to a normal user. Is that possible?
It seems people get mad if I don’t include this so here is my inxi. If anything else is needed to answer this question just let me know. Thanks for helping.
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=532a2a90-7d4c-4de6-9edb-f10b70a99eea ro quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1
dm: GDM 40.1, SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: X570 Phantom Gaming 4 serial: <filter>
UEFI: American Megatrends v: P3.90 date: 01/26/2021
RAM: total: 15.55 GiB used: 1.83 GiB (11.8%)
Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
L2: 4 MiB bogomips: 121417
Speed: 2868 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 2868 2: 2869 3: 4259 4: 3213 5: 2874 6: 2871 7: 2873 8: 2921 9: 3590
10: 2869 11: 2870 12: 2865 13: 2867 14: 2269 15: 3582 16: 2327
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 09:00.0
chip-ID: 10de:2484 class-ID: 0300
Device-2: Sunplus Innovation Webcam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-6:4 chip-ID: 1bcf:2cb4 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 75 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sunplus Innovation Webcam type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ae v: kernel port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8812
class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
port: d000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 type: USB driver: btusb v: 0.8
bus-ID: 3-1:2 chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 596.14 GiB (64.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: FireCuda 520 SSD ZP1000GM30002 size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD
serial: <filter> rev: STNSC014 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 453.91 GiB size: 445.78 GiB (98.21%)
used: 200.92 GiB (45.1%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 532a2a90-7d4c-4de6-9edb-f10b70a99eea
used: 27.6 MiB (28.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 36AB-309B
ID-3: /run/media/justin/Windows raw-size: 476.61 GiB
size: 476.61 GiB (100.00%) used: 395.19 GiB (82.9%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows uuid: EE14AC8914AC567D
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p5 maj-min: 259:5 size: 900 MiB fs: ntfs label: Recovery
uuid: AE86ACDD86ACA6F5
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-1:2 info: China Resource Semico USB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:4c5e class-ID: 0301
Device-2: 1-2:3 info: [Maxxter] Optical gaming mouse type: Mouse,Keyboard
power: 100mA chip-ID: 18f8:0f99 class-ID: 0300
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-1:2 info: ASUSTek ASUS USB-BT500 type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 0b05:190e
Device-2: 3-5:3 info: Cyber Power System PR1500LCDRT2U UPS type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 2mA
chip-ID: 0764:0601 class-ID: 0300 serial: <filter>
Device-3: 3-6:4 info: Sunplus Innovation Webcam type: Video,Audio
power: 500mA chip-ID: 1bcf:2cb4 class-ID: 0102 serial: <filter>
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.9 C mobo: N/A gpu: nvidia temp: 37 C
Processes: 275 Uptime: 14m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1468 pacman: 1461 lib: 425 flatpak: 0
snap: 7 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.08
