Hi,
I’m trying to connect to my Manjaro via ssh, using my iphone. No need for ssh-keys for now. Both are in the same wifi.
If I run sshd -t, I get sshd: no hostkeys available -- exiting.
If I run sudo sshd -t no output
Then I started the servive via sudo systemctl start sshd
If I check the status, it shows “active (running)”
In my /etc/ssh I have a bunch of key-pairs there
On my iphone I first tried installing the “ish” app. There, I can apk add the openssh package. But if I try ssh user@ip I get connection time out. If I try to ping the ip, “Host is unreachable”
I also tried using the “blink” app. I also get connection time out.
Is there anything I should do in my modem to allow connections? Or I am missing some other configuration in my Manjaro?
