Hi.
For some time I wanted to run Wayland session with my NVidia card, and run HDMI output. For the solution for this moment I’ve choose “nouveau” driver, but there is some glitches with HDMI output on Wayland (white-screen flickering some time), which isn’t appeared on X.Org with same configuration on “nouveau” driver. And for solution I’ve found run X session on another TTY (Wayland session runs on TTY2, on TTY3 I would run X session).
Basically, I’m running command on TTY3 like startx
, but all applications which I’m run here, runs on Wayland session.
I found some “solutions” which doesn’t work in this situation – run X server with argument for different display:
startx -display :3 -- :3 vt3
(something like this), and run something like
DISPLAY=:3 gnome-terminal
or
export DISPLAY=:3 && gnome-terminal
– this commands creates terminal in same Wayland session TTY, not in X session. But, I can run xterm
via applications menu from X session, and that is only one application, which I can run here, all another runs on Wayland session. I’ve checked DISPLAY
variable, and on Wayland session it has value :0
, on generated X session it has value :3
So, question – how to run applications on X session separately from Wayland, and run applications on Wayland similarly separated from X session. Is it possible, or is it any idea for solving problems like this?
