Hey,
I want to run RClone Mount Service at startup, and when I’m gonna add the correct user i’m getting this error
● manage-rclone.service - Mount all RClone drives
Loaded: loaded (/etc/systemd/system/manage-rclone.service; enabled; preset: disabled)
Active: activating (auto-restart) (Result: exit-code) since Sun 2023-12-24 14:31:37 CET; 6s ago
Process: 25867 ExecStart=/usr/bin/rclone --vfs-cache-mode writes mount MyMountDrive: ~/MyMountDrive --config /home/tobi>
Main PID: 25867 (code=exited, status=1/FAILURE)
CPU: 95ms
Here is my config file:
[Unit]
Description=Mount all RClone drives
AssertPathIsDirectory=~/MyMountDrive
After=network-online.target
[Service]
Type=simple
User=tobias
Group=tobias
ExecStart= /usr/bin/rclone --vfs-cache-mode writes mount MyMountDrive: ~/MyMountDrive --config /home/tobias/.config/rclone/rclone.conf
ExecStop=/bin/fusermount -u ~/MyMountDrive
Restart=always
RestartSec=10
[Install]
WantedBy=multi-user.target
When i’m run this command just in my terminal, it’s working
Does someone knows the error?
Hi @NachoImperium,
AFAIK you should use absolute paths in units, not relative or with aliases, like yours with the ~.
Hope this helps!
Hello @NachoImperium
Try this:
File: ~/.config/systemd/user/mount-rclone.service
[Unit]
Wants=network-online.target
[Service]
Type=simple
ExecStartPre=-/usr/bin/mkdir -p %h/MyMountDrive
ExecStart=/usr/bin/rclone mount \
--vfs-cache-mode writes \
--config %h/.config/rclone/rclone.conf \
--umask 022 \
--allow-other \
MyMountDrive:%h/MyMountDrive
ExecStop=/bin/fusermount -u %h/MyMountDrive
Restart=always
RestartSec=10
[Install]
WantedBy=default.target
Or probably use this template: Rclone systemd user service · GitHub
Run it: systemctl --user start mount-rclone.service
Hey,
sorry for my late reply, I don’t have this directory:
Only “~/.config/” this exists.
The path is correct and if it doesn’t exist, then what would one do? One would create the folders. Or?
Just FYI, I also use rclone, and:
$ stat ~/.config/systemd/user/mount-rclone.service
stat: cannot statx '/home/mirdarthos/.config/systemd/user/mount-rclone.service': No such file or directory
i think it has to be created first…
