I have a dual booted system with Windows 10. I have been using windows for a couple of months. However, today I decided to boot into manjaro. Unfortunately, when I tried to connect to my wifi, I wasn’t able to do so as the Network Manager was indicating “wifi disabled”. However, the wifi works fine on windows.
I’ve disable fast boot on windows. I’ve also disabled MAC randomization on manjaro by adding the following lines to /etc/NetworkManager/NetworkManager.conf
[device]
wifi.scan-rand-mac-address=no
Even this didn’t helped.
Can someone please help me and tell me how to make wifi work again.
Diagnostic information:
a. nmtui
does not show Wireless connection options.
b. nmcli device
shows
DEVICE TYPE STATE CONNECTION
eno1 ethernet connected Wired connection 1
wlp4s0 wifi unavailable --
lo loopback unmanaged --
c. sudo dmesg | grep rtw
shows
[ 1.849797] rtw_8822ce 0000:04:00.0: enabling device (0000 -> 0003)
[ 1.851187] rtw_8822ce 0000:04:00.0: Firmware version 9.9.4, H2C version 15
[ 1.851257] rtw_8822ce 0000:04:00.0: Firmware version 9.9.10, H2C version 15
[ 2.213437] rtw_8822ce 0000:04:00.0 wlp4s0: renamed from wlan0
d. lsmod | grep rtw
shows
rtw88_8822ce 16384 0
rtw88_8822c 471040 1 rtw88_8822ce
rtw88_pci 28672 1 rtw88_8822ce
rtw88_core 217088 2 rtw88_pci,rtw88_8822c
mac80211 1167360 2 rtw88_pci,rtw88_core
cfg80211 1040384 2 rtw88_core,mac80211
e. rfkill list all
shows
0: ideapad_wlan: Wireless LAN
Soft blocked: yes
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
When I run sudo rfkill unblock all && rfkill list all
I get
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
This does not help, even if I restart NetworkManager after doing this.
e. inxi -Nazy
shows
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 2000
bus-ID: 04:00.0 chip-ID: 10ec:c822 class-ID: 0280
f. uname -a
shows
Linux manjaro 5.12.16-1-MANJARO #1 SMP PREEMPT Sun Jul 11 13:23:34 UTC 2021 x86_64 GNU/Linux
I also have 5.10 kernel. Wifi doesn’t work in either of the kernels.
g. journalctl -p 3 -xb
shows
-- Journal begins at Tue 2021-07-20 00:25:30 IST, ends at Tue 2021-07-20 02:03:34 IST. --` `Jul 20 01:40:20 manjaro kernel:
h. ip link
shows
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether 54:05:db:e7:cb:ab brd ff:ff:ff:ff:ff:ff
altname enp3s0
3: wlp4s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 30:c9:ab:8b:99:2d brd ff:ff:ff:ff:ff:ff
Even if I do sudo ip link set wlp4s0 up
I am unable to bring wifi up.
i. lspci | grep RTL
shows
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
04:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
Thanks a lot. Any help is appreciated!
