Rtl8821ce: Bad return status for module build on kernel: 5.8.3-2
Still have problems changing to Kernel 5.8.3-2 due to failures regarding modules returning error while dkms-build:
Install-log:
The following packages will be installed:
linux58
linux58-headers
Starting
resolving dependencies...
Packages (2) linux58-5.8.3-2 linux58-headers-5.8.3-2
Total Download Size: 95.41 MiB
Total Installed Size: 197.22 MiB
:: Retrieving packages...
downloading linux58-5.8.3-2-x86_64.pkg.tar.zst...
downloading linux58-headers-5.8.3-2-x86_64.pkg.tar.zst...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing linux58...
Optional dependencies for linux58
crda: to set the correct wireless channels of your country [installed]
installing linux58-headers...
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Install DKMS modules
==> dkms install --no-depmod -m rtl8821ce -v v5.5.2_34066.20200325 -k 5.8.3-2-MANJARO
Error! Bad return status for module build on kernel: 5.8.3-2-MANJARO (x86_64)
Consult /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m rtl8821ce -v v5.5.2_34066.20200325 -k 5.8.3-2-MANJARO' returned 10
==> dkms install --no-depmod -m rtl8821ce -v 1.0.5.r95.g69765eb -k 5.8.3-2-MANJARO
Consult /var/lib/dkms/rtl8821ce/1.0.5.r95.g69765eb/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m rtl8821ce -v 1.0.5.r95.g69765eb -k 5.8.3-2-MANJARO' returned 10
==> dkms install --no-depmod -m smartcam -v 1.4.0 -k 5.8.3-2-MANJARO
Consult /var/lib/dkms/smartcam/1.4.0/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m smartcam -v 1.4.0 -k 5.8.3-2-MANJARO' returned 10
==> depmod 5.8.3-2-MANJARO
(4/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'default'
-> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64.img
==> Starting build: 5.8.3-2-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'fallback'
-> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64-fallback.img
(5/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.8-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.8-x86_64.img
Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.7-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.7-x86_64.img
Found initrd fallback image: /boot/initramfs-5.7-x86_64-fallback.img
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
Fertig ...
/var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/make.log :
DKMS make.log for rtl8821ce-v5.5.2_34066.20200325 for kernel 5.8.3-2-MANJARO (x86_64)
Fri Aug 28 11:58:05 CEST 2020
make: uname: No such file or directory
make: pwd: No such file or directory
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/5.8.3-2-MANJARO/build M=  modules
make: make: No such file or directory
make: *** [Makefile:2244: modules] Error 127
/var/lib/dkms/rtl8821ce/1.0.5.r95.g69765eb/build/make.log:
DKMS make.log for rtl8821ce-1.0.5.r95.g69765eb for kernel 5.8.3-2-MANJARO (x86_64)
Fri Aug 28 11:58:06 CEST 2020
/var/lib/dkms/smartcam/1.4.0/build/make.log:
DKMS make.log for smartcam-1.4.0 for kernel 5.8.3-2-MANJARO (x86_64)
make: Entering directory '/usr/lib/modules/5.8.3-2-MANJARO/build'
make: gcc: No such file or directory
make: *** [Makefile:1756: /var/lib/dkms/smartcam/1.4.0/build] Error 127
make: Leaving directory '/usr/lib/modules/5.8.3-2-MANJARO/build'
And so on…
When I boot Kernel 5.8.3-2
and run ‘sudo dkms autobuild’, I get this log for module rtl8821ce:
Fr 28. Aug 12:31:53 CEST 2020
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/5.8.3-2-MANJARO/build M=/var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build  modules
make[1]: Verzeichnis „/usr/lib/modules/5.8.3-2-MANJARO/build“ wird betreten
  CC [M]  /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_ieee80211.o
  CC [M]  /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_debug.o
  CC [M]  /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_cmd.o
  CC [M]  /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_io.o
  CC [M]  /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_security.o
  CC [M]  /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_mlme.o
  CC [M]  /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_ioctl_query.o
  CC [M]  /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_ioctl_set.o
In Datei, eingebunden von /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/include/drv_types.h:79,
                 von /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_ioctl_query.c:17:
/var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/include/rtw_security.h:252:8: Fehler: Redefinition von »struct sha256_state«
  252 | struct sha256_state {
                 von /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_io.c:47:
                 von /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_security.c:17:
                 von /var/lib/dkms/rtl8821ce/v5.5.2_34066.20200325/build/core/rtw_debug.c:17:
Can someone please fix this?
I never experienced this in the past for kernel < 5.8 …
Or is there a simple workaround meanwhile?
Update: Could solve the issue with a rebuild of the 8821ce module from tomaspino
With that, WLAN and bluetooth was working again.
BUT, network speed in/out is with 5.8.3-2 not visible anymore in Ksysguard.
But, internal Vega 8 gpu is not recognized as opencl device anymore.
Had to switch back to 5.7.
Kind regards,
Jörn-Ingo Weigert
Update:
KSysGuard don’t show at all at least the WLAN network speed after the last update.
So this seems not related to my problems with building Kernel modules for 5.8 / 5.9
Hi!
Did you try with rtl8821-dkms from AUR?
It work just fine for me
I do use the rtl8821ce-dkms-git (which is based on the tomaspino repository.
That worked after an rebuild (& refetch) with kernel 5.8. U don’t know if your package do use the same code.
But due to a non working opencl support for my internal Vega 8 you in my ryzen CPU I had to change back to kernel 5.7.17(!?).
So far, I must say I haven’t experienced any problems that much than with the 5.8 kernel in it’s recent incarnations.
