Difficulty: ★★★☆☆
Update 5th June 2021:
The AUR Package has been updated
and this instructions are no longer necessary.
The Alfa AWUS1900 Wi-Fi USB Adapter uses the RTL8814AU Chipset and the drivers are not included in Linux kernel 5.11. (the one used to test this tutorial)
AUR
Both available versions (rtl8813au-dksm-git and rtl8814au-aircrack-dkms-git) are out of date and not working well or even at all!
GitHub
However, there is an active Github-Repository here and the Readme gives great instructions, and the Wifi-Card works very well after following these instructions.
Package
If you prefer installing the driver via the package manager, one could use a PKGBUILD like this:
# Maintainer: zebulon <zeb (at)zebulon(dot)org(dot)uk>
# Contributor: NovaMoon <novamoon1 (at)gmail(dot)com>
# Contributor: Erikas Rudinskas <erikmnkl (at)gmail(dot)com>
# Contributor: André Menrath <andre.menrath (at) posteo.de>
pkgname=rtl8814au-dkms-git
_pkgbase=rtl8814au
pkgver=5.8.5.1
pkgrel=1
pkgdesc="RTL8814AU wifi chipset driver with firmware version 5.8.5.1"
arch=('x86_64')
url="https://github.com/morrownr/rtl8814au"
license=('GPL2')
depends=('dkms')
makedepends=('git')
conflicts=("${_pkgbase}")
source=("git+https://github.com/morrownr/8814au.git")
sha256sums=('SKIP')
package() {
cd ${srcdir}/8814au/
mkdir -p ${pkgdir}/usr/src/${_pkgbase}-${pkgver}
cp -rf . ${pkgdir}/usr/src/${_pkgbase}-${pkgver}
mkdir -p ${pkgdir}/etc/modprobe.d
cp -f 8814au.conf ${pkgdir}/etc/modprobe.d
Instructions:
- create a new empty folder
- paste this content into a file named
PKGBUILD - navigate to this folder and open it in a terminal
- type
makepkgto compile the package. - open the file
rtl8814au-dkms-git-5.8.5.1-1-x86_64.pkg.tar.zstwith your package manager in order to install it.
